Old 08-22-2021, 03:28 AM #1
DavidK99 DavidK99 is offline
DavidK99 is on a distinguished road
SR5 V8 Load Limit For Camping — Too Much Weight?
I own a 2007 SR5 V8 4Runner (great car). My wife and I have gotten into car camping lately and have several trips planned. I installed heavy duty crossbars on the roof rack, and they now carry a 160 lb “hard shell” roof tent. (It has definitely reduced fuel economy, but doesn’t seem to affect the ride much or create wind noise.)
Besides the roof tent, we carry a lot of other stuff — 10 gallons of water, a big cooler, a large battery backup system, 4 totes filled with hiking, cycling, and camping items, and a bunch of other items. I removed the bottom sections of the rear seats to make more space back there. In addition I have a bike rack on the trailer receiver that carries 2 bikes.
I’ve done the math and all together I believe the roof tent, bike rack and bikes, plus everything else total about 1000 lbs. Plus the two of us, of course.
I certainly feel the difference when driving around with all that stuff, and drive slower and more gently. That said, am I over-doing it; is this a problem?
My manual shows maximum load capacity as 950 lbs. with 5 occupants and 1050 lbs. with 7 occupants. I don’t understand the different numbers, and my car doesn’t seat 7 people. But either way, the 1000 lb. load plus the two of us is nearly 1400 lbs.
Is that dangerous; is it bad for the car? Should I look into heavy duty tires, or beef up the suspension in some way? Should I cut back on my packing list? Should I adjust tire pressure? Any other comments?
In the next year we hope to drive about 5000 miles loaded like that. Thanks in advance for any advice.
DavidK99 is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 06:32 AM #2
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
I’m just going from memory but I thought the payload on these was closer to 1,500lbs with a tow capacity of 7,000lbs. They weight about 4,500lbs and have a GVM of 6,000lbs.
It would be wise to look at the load rating and overall condition of your tires. Maybe bring less stuff too.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 07:59 AM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
From what I've read on this site there are many who carry close to what you are AND they have replacement front/rear steel bumpers and a rear mounted oversize tire and other stuff. Are they overloaded? I would say yes. You may be too, but not to the extent of some. Make sure you have good tires and inflate them properly.
Old 08-22-2021, 10:19 AM #4
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
The numbers you want to look for are the GVWR (Gross Vehicle Weight Rating) and GVW (Gross Vehicle Weight). GVWR is the maximum weight the single unit (the 4runner including tongue weight but not trailer weight) can safely support. The GVW is the actual vehicle weight and will change as its loaded with gear. the GVWR on my 2005 v6 is 5580lbs. I don't think the empty GVW is listed, but it is somewhere around 4,300 - 4,600lbs IIRC. You would have to weight it empty to see for real. Then also weigh it full to see if the actual loaded weight to compare to the GVWR and ensure you're under that limit.
CAT scales are like $12 for initial weigh and $3 for reweigh within 24hrs
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 10:28 AM #5
southern_runner southern_runner is offline
southern_runner is on a distinguished road
7 occupant listing is probably for the 3rd row option? Like someone suggested, next time you load her up you could have the vehicle weighed. Might call a weigh station ahead of time and find out how/when/where they want you to come.
southern_runner is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 01:09 PM #6
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
I wouldn't worry about it. Make sure the tires are in good shape, brakes are good, and if the suspension sags or rides bad loaded down upgrade it. I've ridden loaded down like that on multiple 3k, 5k, and 10k mile road trips in my 3rd gen. And it's armored, bumpers, etc. for even more extra weight. But it does have upgraded suspension and LT tires.
I don't think you need to upgrade tires, suburbans and other heavy large SUVs come with P rated tires to my knowledge, and those have a higher weight rating than what you're doing with a 4th gen. Maybe adjust tire pressure up a little bit if anything.
You are aware of it and cognizant that there is extra weight in the vehicle, and that is good. If something seems off while driving it look into upgrading/replacing that component.
So long as you don't have 3,000 lbs of lead bricks or something crazy in the back I wouldn't worry about the weight in my opinion.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 08-23-2021, 10:01 PM #7
Many thanks for the replies. Consensus seems to be that I'm probably ok with that amount of weight, which is good to know. I'm going to have my mechanic thoroughly check the suspension next week. (And maybe replace the shocks because the car has felt a little bouncy to me lately, even with a normal load.)
I'm also going to try to eliminate a few items to get the weight down a bit (and reduce clutter a bit.)
Thanks again.
Old 08-27-2021, 03:05 PM #8
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
Let's calculate what added weight you have in your list. This is just an estimate.
250lbs - you and your wife
200lbs - cross bars and roof tent
90lbs - 10 gallons of water
45 lbs - battery backup
40 lbs - big cooler with food
100lbs - camping items totes
30 lbs - bike rack
60 lbs - 2 bikes
ok, that's around less than 1000 lbs.
I would say with all that weight, you are okay for that road trip. Make sure to increase your tire pressure at 35 so that your tires can handle heavier load. Always check your tire pressure to avoid running too low. For your family's safety, make sure the tires are not older than 5 years old too.
I think you will be fine driving at normal speed or whatever is the speed limit. I drove around 5000 miles round trip with 4 people and a loaded trunk up to the roof and an additional loaded enclosed hitch cargo box, driving at the recommended speed limit. Tire pressure at 35psi and was using OEM tires. it increases to 38 while driving. And most of all, say a prayer before you drive.
4r-4ever is offline   Reply With QuoteReply With Quote
Old 09-05-2021, 11:47 PM #9
Fern's Avatar
Fern Fern is offline
Fern will become famous soon enough Fern will become famous soon enough
Fern's Avatar
How does the vehicle sit and drive when fully loaded? Might want to look into upgrading the rear springs.
2005 4R V8 4x
Fern is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 11:25 AM #10
i'm surprised it was not squatting too much. just a little bit. if i remove the hitch enclosed carrier and replace it with a roof cargo box, i would think it would be level. i guess you are right, i can put a rear support to help that spring with the load. it drove fine so far at highway speeds, 80s on other areas.
Old 09-13-2021, 04:51 PM #11
Flyer Flyer is offline
Flyer will become famous soon enough
Next time you buy tires, maybe look at the weight rating of C rated tires vs what you have now (probably P?). Get something with a decent weight rating and a bit over what you have now. Don't go to Ds or Es though.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
Flyer is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 09:58 PM #12
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
David,
this is a hard question to answer objectively but it sounds like you're aware of the weight and taking appropriate precautions. I don't load my 4runner like you do but I do overload my 80 series landcruiser and I'm actually over the GVWR. It's taller and drives like a lumbering cow but I try to be careful. It's rather top heavy but it a fun rig to take camping, especially when I move daily.
I think the rear diff is the weak points in our 4runners so if you can find a 8.2 rear end, perhaps that'll reduce your apprehensions?
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
car , lbs , rack , roof , tent
roof rack weight limit? USSEnterprise 3rd gen T4Rs 23 06-04-2021 01:25 PM
Rear hatch weight limit MacLaddy 3rd gen T4Rs 9 09-30-2019 02:56 PM
Weight limit of slide out tray? smallcrap 5th gen T4Rs 25 06-09-2013 07:39 PM
Low(er) TE Cargo Weight Limit dsfra 5th gen T4Rs 17 12-20-2012 11:46 AM
Hitch weight limit t4r4life 3rd gen T4Rs 1 07-15-2010 09:07 PM
