Old 09-05-2021, 03:10 PM #16
Toystory2's Avatar
Toystory2 Toystory2 is offline
Toystory2 will become famous soon enough
Toystory2's Avatar
First big DIY for a beginner
Decided to bypass the AbS bracket for now and use a 19mm wrench to get in there. It was a bit rough, but got the UCA nut off. Now I am trying to figure out how to pull the long bolt out on the passenger side. You can pull it almost out but then it hits a metal line going to the radiator. Tried bending the line slightly but still wouldn’t fit. Don’t wanna bend that line anymore than I have to.
Toystory2 is offline   Reply With QuoteReply With Quote
Old 09-05-2021, 08:51 PM #17
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
Originally Posted by Toystory2 View Post
Yep, made sure to buy the shocks preassembled with coil. Thanks for the reminder about the orientation of the shocks.
That is absolutely hilarious about the upside down shock �� that is totally something I would do.
I appreciate it! I am in the western mountains of NC… what bout you?
Yea, it's amazing what little things you can goof up on, even when you're trying not to. I'm near Rocky Mount. Work in Raleigh. I love the mts (beach too). Anytime we go, we usually go to the Boone area. I've been mountain biking in Pisgah, but haven't made it that far west in quite a while.
EDIT:
Not sure if it matter now but I found an old thread where someone loosened a hold-down on that AC line blocking your bolt on the pass side. Mentioned here:
https://www.toyota-4runner.org/2828203-post20.html
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 05:34 PM #18
Toystory2's Avatar
Toystory2's Avatar
EDIT:
Oh nice, Boone is a pretty area. I’m. I’m not too far from Pisgah. Thanks for the link. That’s what I had to do, but got it in there finally.
Old 09-06-2021, 05:40 PM #19
Toystory2's Avatar
Toystory2's Avatar
It took nearly 3 days, but got both upper control arms done (with some assistance on the second one).
Rusted, stuck-on bolts and one of the UCA bolts were the biggest problems, other than that it was pretty straightforward.
Learned a lot and thanks to everyone’s help on the forum.
It already drives better and squeaks less ��
Next up will be the lower arms and shocks.
Edit: Pittman ball joint separator was a must have. Be careful that things pops like a gun shot.
Old 09-18-2021, 06:01 PM #20
Toystory2's Avatar
Toystory2's Avatar
Happy to say this project is finally done. Got the lower arms and front rear shocks on today. A newly made friend that is also a mechanic was a huge help in this.
Toughest parts were one seized control arm and top rear shock nuts.
Thankfully we had a sawzall, grinder, and air hammer to assist.
Unfortunately this did not resolve my squeaking sound that happens when going over bumps and dips. Any idea what else could be causing it?
Old 09-18-2021, 08:54 PM #21
montijo505's Avatar
montijo505's Avatar
You check the bushings on the sway bar yet?
Old 09-18-2021, 09:18 PM #22
Toystory2's Avatar
Toystory2's Avatar
Not yet, but that will be the first on the list of suspects!
alignment , arms , big , evening , shocks
4WD Beginner Help, please jsindorf 3rd gen T4Rs 9 01-14-2016 10:37 PM
offroading beginner ghastings93 Off-Roading 7 06-26-2013 04:27 PM
HID beginner help jillianj 4th Gen T4Rs 62 06-27-2011 12:26 PM
Beginner Mistake NIKBPIK 4th Gen T4Rs 5 08-05-2009 10:00 PM
4x4 beginner question OmarT4R Off-Roading 11 11-26-2004 01:07 AM
