Old 09-07-2021, 06:37 PM #1
DirtySouth89's Avatar
DirtySouth89 DirtySouth89 is offline
DirtySouth89 will become famous soon enough
EMERGENCY help: brake failure, VSC lights, and continuous alarm?
I just drove my 2006 V8 to a corner store at the end of the block, 300 yards max. Everything was fine, as always. Then when I got back into the truck to go home, I noticed that the red E-brake light was on (not engaged though), also the orange VSC/trac lights. Then it began making a howling continuous alarm beep. Then about 100 yards into the trip I noticed the regular foot brakes DON'T WORK. I have no braking. Luckily the 300 yard trip back to my house is *slightly* uphill. I just gave it weak gas and crawled home, then let gravity stop at the curb in front of my house.
Help!?
2006 SportEdition V8 | 2009 Honda Accord EX-L
DirtySouth89 is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 06:42 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I'll ask the obvious, any sign of brake fluid leakage? How does fluid level in reservoir look?
Old 09-07-2021, 06:50 PM #3
Oh sh-t. Yeah I would say this is some evidence. Good call. This is the driveway spot it was in until my recent drive.
EMERGENCY help: brake failure, VSC lights, and continuous alarm?-brake-leak-jpg
Old 09-07-2021, 06:54 PM #4
And yeah the brake fluid reservoir is empty. WTF
Old 09-07-2021, 07:11 PM #5
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
You have a leak in your (hydraulic) braking system. Easiest way to find it is to look for wet spots on the truck above where that puddle is. If you've never worked on a brake system yourself, have it towed to somebody you trust. Do not drive it.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 07:18 PM #6
Real Name: Skip
Real Name: Skip
Find and fix the leak, refill the master cylinder and then bleed the brakes.
Just an FYI, learn how to use the parking brake, downshifting and slowing down ahead of time to be able to stop, it's a skill I and most everyone I knew growing up in the 1960s knew how to do, and it can save your life or at the very least help you avoid an accident!!
I had to use this skill about 4 years ago with my T4R on a late Thanksgiving night when a brake line burst on my driver's front wheel, nothing was opened and no wreckers were available, no traffic to speak of and I drove 90 miles home without any issues stopping and getting my truck home with no brakes other than the parking brake.
2004 Limited V8
Old 09-08-2021, 07:39 AM #7
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
damn.. how high is your life insurance policy???
jk of course. But on a serious note I'd be curious to find out what exactly failed.
aemravan is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 08:20 AM #8
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
Check the hard lines at each front caliper, then check the lines on the left side above the rear diff.. then spread out from there..
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 06:43 PM #9
Thanks for the advice everyone but we are well beyond my wrenching capabilities. And with a life-or-death system (braking). I'll be having AAA tow this to a shop, then let you know.
Old 09-13-2021, 11:41 AM #10
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
when i was checking my brake lines a year or 2 ago, saw some corrosion in the front brake caliper line and replaced it. removed the old line, went to store to buy the replacement line. also, last year, my rear brake lines were corroded too, had to buy it from toyota and replaced it. better to buy the toyota ones so that you don't have to waste time. just remove the old one and replace witht he new one. i had to replace the hoses in the rear too.
for everyone with old 4runners, check your brake lines for corrosion and replace it for your peace of mind.
4r-4ever is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 11:48 AM #11
Anyone have the part number or link to replace the front caliper hardlines with braided lines?
2005 4Runner SE V8
Old 09-13-2021, 02:48 PM #12
the hardline that connects from the caliper to the hose, you can get it from autozone or advance, just get the right length and correct fitting. i had to remove my old one and bring to the store so they can check the correct thread or fitting, then you just have to bend it, very easy. the hose, i'll check what i have.
Old 09-13-2021, 02:50 PM #13
Yeah, im looking for an upgrade to not use a hardline and use stainless braided instead if its available.
2005 4Runner SE V8
Old 09-13-2021, 03:48 PM #14
the hardline is quite needed. i've checked before thinking the same thing. just plug and play.
Old 10-20-2021, 12:12 PM #15
So yeah, rusted brake line
It took me a week of it sitting before I got around to towing it to a Toyota/Lexus shop. Then it spent almost 4 weeks there waiting on the backordered brake line. I've now got it back fixed. Thanks everyone.
back , home , house , noticed , trip
Help: VSC/TRAC/ABS/BRAKE lights on plus loud, continuous alarm? dannyg 4th Gen T4Rs 39 06-24-2022 07:52 PM
ABS/VSC TRAC/Brake Lights and Audible Alarm T4Rfirefighter 3rd gen T4Rs 11 10-30-2017 03:31 PM
ABS, VSC Trac, and Brake idiot lights on, audible alarm. What gives? Kardolf 4th Gen T4Rs 5 09-11-2015 02:48 PM
2003 4RUNNER. trip to car wash causes brake failure, alarms and all lights going craz gentlejax 4th Gen T4Rs 26 03-15-2015 12:25 PM
VSC, ABS and brake lights on with audible alarm- Help gmccune13 4th Gen T4Rs 5 11-07-2014 07:09 PM
