Old 09-08-2021, 10:29 PM #1
Toystory2's Avatar
Toystory2 Toystory2 is offline
Toystory2 will become famous soon enough
Toystory2's Avatar
Odd noise when shifting into drive and turning AC on
I’ve noticed a noise whenever I’m idling and in drive with the brakes on like at a traffic light or drive thru. Hard to describe it, but it sounds like metal vibrating against metal coming from underneath. If I shift to neutral it will stop. Doesn’t seem to happen if I’m driving down the road either.
I also noticed that if I turn the ac on while in this situation, it causes the noise. But if I turn the ac on in neutral, there is no noise.
Not sure if it’s ac related or what. Any ideas?
Toystory2 is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 10:57 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
There are heat shields at some areas of the exhaust, many times the heat shield/s can become loose and rattle, this is more noticeable when the engine is under load, i.e. when in gear, AC is on etc., check your heat shield/s to start.
2004 Limited V8
Old 09-09-2021, 09:24 AM #3
Toystory2's Avatar
Toystory2's Avatar
Yea that’s what it sounds like… sort of like a thin metal piece rattling. I will definitely check that out! Thank you @AuSeeker as always!
Old 09-09-2021, 09:51 AM #4
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
A friend of mine has just eliminated some noises like OP describes from his old 2002 Toyota RAV4 - it was indeed the exhaust heat shields/clamps, and also one of the disc brake water splash guards.
It makes sense to me that it only happens in D, with the additional load on the engine, and more 'force' being transmitted throughout the driveline than when in N
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 01:30 PM #5
Toystory2's Avatar
Toystory2's Avatar
Thanks for the suggestions! I’ll check those. Been driving me crazy lol
Old 09-13-2021, 07:00 PM #6
Toystory2's Avatar
Toystory2's Avatar
Wonder why this seems to happen only in an idling state? I have driven slowly with the windows down and didn’t hear it.
Old 09-13-2021, 07:05 PM #7
SurferUK's Avatar
SurferUK's Avatar
Resonance! If it was a manual/stick shift, I bet it would rattle every time you pulled away without perfect technique. I had that exact issue on my Suzuki. No noise except when pulling away and revs dropped too low.
Old 09-13-2021, 09:23 PM #8
Toystory2's Avatar
Toystory2's Avatar
Interesting…thanks for the input. Now to find the source of this noise.
Old 09-14-2021, 06:50 AM #9
SurferUK's Avatar
SurferUK's Avatar
Hope it's an easy fix, let us know how you get on
Old 10-16-2021, 06:45 PM #10
Toystory2's Avatar
Toystory2's Avatar
Found a loose heat shield going up toward the engine. The shield has broken loose around the bolt so I was gonna put a big washer back on it, but broke the little bolt off! Now not sure what to do?
Odd noise when shifting into drive and turning AC on-0c50cb46-8fca-4c6a-8be8-1e960194fe4d-jpeg
Old 10-16-2021, 06:52 PM #11
SurferUK's Avatar
SurferUK's Avatar
Glad it was a minor issue. See if you can get some grips on the remaining stub, and unscrew it
Old 10-16-2021, 10:01 PM #12
Toystory2's Avatar
Toystory2's Avatar
Hmm I think there may be enough to grab it. Worth a shot, thanks for the tip.
Old 10-17-2021, 05:37 PM #13
Toystory2's Avatar
Toystory2's Avatar
Unfortunately not enough bolt left to get ahold of. Should I try drilling it out?
Old 10-19-2021, 07:22 AM #14
jwong1208 jwong1208 is offline
jwong1208 is on a distinguished road
few options here, 1.) drill it out and replace with bolt & nut. 2.) bend heat shield away so it wont rattle
jwong1208 is offline   Reply With QuoteReply With Quote
Old 10-19-2021, 08:29 PM #15
Toystory2's Avatar
Toystory2's Avatar
Thanks, I like option 2 Odd noise when shifting into drive and turning AC on
drive , metal , noise , noticed , turn
Grinding/creaking noise when shifting from reverse to drive omelette 5th gen T4Rs 22 08-15-2023 06:24 AM
Weird squeaking noise when shifting into drive HanIsa97 4th Gen T4Rs 1 08-31-2017 11:33 AM
Shifting from Neutral to Drive Clemsonfan15 General Discussions 22 11-18-2008 02:18 AM
shifting from reverse to drive - v8 4wd V8Limited4wd Problems & Warranty Issues 1 03-13-2008 08:44 PM
