Old 09-09-2021, 12:49 PM #1
4Runner4Runner4's Avatar
4Runner4Runner4 4Runner4Runner4 is offline
4Runner4Runner4 is on a distinguished road
Help- I made a big mistake
I installed the Daystar 2.5 kit (front and rear) a year ago. It was perfect; my rig was level.
This year, I needed new front struts because my front tires were cupping badly and I had a nasty steering wheel shake at 55-70 mph.
I had my local Toyota dealer service center install Bilstein 5100’s and set them at 0”. But after install, my front is a solid 2” higher than the rear.
Shouldn’t it be the same height? Help, I accidentally squatted my 4Runner.
2007 4.0L 2Runner SR5
250,000 miles, and adding 4000 more per month!
4Runner4Runner4 is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 12:58 PM #2
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
This usually results from an idiot installing the spring perch on the strut upside down. Show us a pic of the strut please.
techno is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 01:50 PM #3
venomj venomj is offline
venomj is on a distinguished road
Are you still using the old springs?
venomj is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 02:29 PM #4
riverwolf riverwolf is offline
riverwolf is on a distinguished road
As techno said, we need to see what your installation looks like. You told them to use the 0" perch, but they could have used a different perch setting, unless you've confirmed yourself.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 03:18 PM #5
montijo505's Avatar
montijo505's Avatar
Pictures of the shock where the bottom of the spring meets the perch will help immensely here
Old 09-09-2021, 04:25 PM #6
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Did they leave the spacer in there? The rear also looks low, especially since the daystar 2.5/1.5 kit lifts the rear too
Like others said, check if perches are upside down.
This is upside down
This is right side up
y=mx+b is offline   Reply With QuoteReply With Quote
Old 09-10-2021, 09:34 PM #7
t4rky t4rky is offline
t4rky is on a distinguished road
hope you get this solved!
t4rky is offline   Reply With QuoteReply With Quote
Old 09-10-2021, 11:49 PM #8
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
Yep , probably those spring seats are upside down... Looks like the kid who does oil changes got promoted a little early...
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 06:38 AM #9
Unfortunately, it looks like my spring perches were installed correctly.
I am seeing that the Daystar lift spacers are indeed retained (and I never asked for those to be removed). But that should not affect the ride height considering my 4Runner was level prior to the Bilstein 5100 installation and the struts are set at 0”… right?
Old 09-13-2021, 06:39 AM #10
Old 09-13-2021, 10:27 AM #11
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Hmm, might need to double-check they're actually set at 0" - I think you should be able to see the additional notches above the 0 setting, but dont see any above that lower perch, so it might actually be set for max lift. Picture angle seems to obscure it a bit, so its hard to tell from those pics.
I'd take a pic of mine (they're at 0) but its caked with sand and mud right now.
Easy solution: remove the spacers.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 10:48 AM #12
Thank you! I’ll take some more pictures and angles shortly. Will the height notches in question be located above the spring perch (inside the spring) or below it?
Can the height be adjusted without removing the strut, like on an adjustable coilover, or is it only adjustable during removal?
I will also try to full-drop a rear wheel soon and take a picture of that setup to post here and inquire if there’s anything weird going on back there which might be causing the squat. I’m completely dumbfounded how this could have happened, and I’m loathing every mile spent the road while driving a squatted 4Runner.
Tires are 285/70/r17, offset on Synergy 2” spacers… just in case that’s a factor.
Old 09-13-2021, 11:00 AM #13
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
jcaino nailed it, looks like you're set on the highest notch (I'm set to 0 and can see additional notches above the perch).
You'll need to remove them in order to adjust the height setting, unfortunately. Hopefully the mistake was on the mechanic's end and they'll make it right.
eleven14 is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 11:06 AM #14
montijo505's Avatar
montijo505's Avatar
As stated, there should be I think 2 notches in the shock body visible above the perch. It doesn’t look like there is. So take it back and have it set to “0” or remove the spacers and see where that leaves you.
Old 09-13-2021, 11:39 AM #15
OP, here are the 5100's installation instructions to help you visualize what's happening. As has been mentioned, the strut will need to be disassembled to change the height. A C-clip is placed into one of the four grooves and the lower spring perch sits on that clip. Spring pressure has to be removed to release the lower perch to expose the C-clip.
front , help- , install , rear , year
I made a mistake... Cwright26 Maintenance/Detailing 8 10-04-2020 09:06 PM
I made a huge mistake... aelarson General Discussions 19 04-22-2017 10:01 AM
Discount Tire made a mistake...but...? Goyo 5th gen T4Rs 18 08-01-2012 09:13 AM
PepBoys made a big mistake! perfectmax 4th Gen T4Rs 14 12-02-2005 05:11 PM
Pep boys made a big mistake! perfectmax Classic T4Rs 3 12-02-2005 03:44 PM
