Old 09-09-2021, 06:11 PM #1
Urbanite Urbanite is offline
Urbanite is on a distinguished road
Voltage Drops When Engine Warms Up
I noticed my voltage dropping when engine has been warm for like 30 minutes or so. When starting rig, my voltmeter, connected directly to battery terminals, reads 14.1, and then hovers around 13.9 but like 30 minutes later it drops to 13.5-13.6. When I run A/C it even drops to 13.4, have yet to see anything lower. My battery and alternator are kinda new. I have no flickering lights and otherwise all seems normal. What could it be, or is this normal?
Urbanite is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 08:23 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
100% normal, and operating as expected.
Old 09-09-2021, 10:45 PM #3
I thought anything below 13.7V could be an indication alternator is on its way out. Could you explain your point that my scenario is normal. Thx.
Old 09-10-2021, 09:48 AM #4
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
it just the operating temp.
is your alternator a rebuild for high output or just the replacement you get at the auto store.
if you are using high output, are you running a shorter belt.
agm battery? they will require a higher charge voltage.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 09-10-2021, 11:03 AM #5
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
The normal output voltage range is 13.2 to 14.2
There is a shot of the relevant maintenance manual page in one of the threads around here.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 09-10-2021, 12:26 PM #6
Alternator is a lifetime warranty rebuilt Denso which I got at Napa Auto Parts 3 months ago. It's not a high output alt, and battery is not an AGM, also 3 months old.
Old 09-10-2021, 01:58 PM #7
Bumbo's Avatar
Bumbo's Avatar
That is false.
State of charge and temperate compensation matter when charging a lead battery. The voltage will be variable depending on those two conditions.
Voltage alone is a poor indicator of alternator health. There are more appropriate industry standard tests for this including looking at AC ripple and load testing. If you can't get the rated amps out of the device, that would be a much larger concern.
Anything over 13v you are basically still charging the battery when you consider maintenance / float voltages are generally about 13v +/-
For a DIY approach, you are better off using an amp clamp meter, throwing a huge load on the truck, and measuring it's output in amps to make sure its functioning as expected.
battery , drops , minutes , normal , voltage
Voltage of Battery with Engine Running JP4RNR 4th Gen T4Rs 16 12-25-2022 01:17 AM
Voltage drops thegipper 3rd gen T4Rs 20 01-25-2022 12:42 AM
Any way to lock doors while it warms up? DAF54 5th gen T4Rs 13 02-06-2020 09:49 AM
Voltage Drops Out..... Ol'Blue 3rd gen T4Rs 75 11-11-2015 01:46 PM
No power until engine warms up mrpanic7 4th Gen T4Rs 30 04-02-2012 01:28 PM
