Old 09-13-2021, 11:31 AM #1
tduy87 tduy87 is offline
tduy87 is on a distinguished road
Rear vibration after calipers/rotors/pads replacement!
Good morning,
Over the past weekend, I changed out my rear calipers/rotors/pads on my 2004 4runner SR5 due to seized calipers. The rear passenger's side rotors came off easy using the two bolts method. However, the rear driver's side was a real pain to take off. I managed to broke it lose by putting a screwdriver on the adjuster and beating the front of the rotors until it came lose. Since this was the first time I'm doing rear brake jobs, I forgot to count how many clicks on the adjuster I turned down. After putting on the new rotor, I re-adjusted the brake shoe by turning the adjuster wheel up but I think I may have adjusted it too much because the shoes are touching the rotor tight where it took effort to spin the hub freely. I torqued down my lug nuts to spec.
This morning when I drove to work, I get a rear end vibration going 60mph+ like symptoms of an unbalanced tires. I just got new wheels so I know my tires are balanced.
Would the vibration be because of brake shoe adjusted too tight where it drags on the rotor?
tduy87 is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 11:44 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Maybe. Jack up the rear and turn your wheels by hand and see if they turn relatively freely and listen for park brake rubbing. Adjust as necessary. I assume you bled your brakes after caliper replacement.
Old 09-13-2021, 05:56 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I'm at a lost understanding WHY if you tightened the parking brake adjuster too tight, why didn't you simply back off on the adjuster until you had it adjusted correctly, that's why it's called an "adjuster" so it can be adjusted just right!!!
2004 Limited V8
Old 09-13-2021, 07:16 PM #4
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Check the emergency brake springs and pins, the pins get rusty and when you force the rotor off it pulls on the springs which in turn pull the pins due to them being weaker. When they get like that they scrape the axle hub.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 11:35 PM #5
Finest Finest is offline
Finest is on a distinguished road
I'd imagine it would take all of 5 minutes to remove the rear wheels and rotate the parking brake down a few clicks and test by rotating the hubs, they should spin relatively easy. (both wheels in the air, of course) And then go for a drive. If that doesn't fix it, check your wheels again, maybe a wheel weight came loose?
Finest is offline   Reply With QuoteReply With Quote
adjuster , brake , rear , rotor , vibration
First time: replacing rear calipers, rotors, and pads...advice? dammit_collins 4th Gen T4Rs 14 08-16-2019 07:45 PM
5th gen swap, best calipers? Rotors? Oem pads already HIMILESV8SPORT 4th Gen T4Rs 2 04-04-2018 05:43 PM
What are the best rotors, calipers and brake pads davidsg 4th Gen T4Rs 20 02-14-2018 11:06 PM
Calipers, rotors, pads oh my! Jaden78 4th Gen T4Rs 7 12-25-2012 12:17 AM
Pads ... Pads and Rotors ... Pads, Rotors, and Calipers?? lamber74 Maintenance/Detailing 15 07-05-2011 10:26 PM
