Old 09-13-2021, 08:20 PM #1
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
Soft/Quiet Tires for Pavement
Looking for tires that soften the ride going over rocks, bumps, small objects in the road. Right now I Michelin that are very firm, I feel every bump and uneven concrete bumps. I had a mechanic tell me that Michelin are hard sidewalls, and that different tires would help with this. I believe he recommended Bridgestones.
I have the 265/65R17 currently. I wouldn't mind an increased tire size, but it's not needed. Most importantly, just a good road tire that can handle these random objects in the road and is fairly quiet. Bonus if they look cool, but again that is 3rd on the priority list.
Appreciate any relies.
meltdowner is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 10:14 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Im not sure that ive heard that before about a tire brand. Are you running the recommended 32 PSI? Otherwise, you want to look at the ratings of the tire (std load/ light truck etc), how many ply its rated (4 vs 10 etc)
Old 09-14-2021, 10:01 AM #3
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
A lot of different factors to consider here. Suspension, speed, PSI, etc.. Different mfgs do have some proprietary material compounds but that is likely negligible. Typically the biggest difference comes from the tire type like a winter/all-season/AT with winter tires being the softest to maintain grip.
Although a little pricey, I have been running the BS Revos the last couple years. originally tried the Revo 2's and was very impressed so I opted for the Revo 3s last fall. So far so good for a daily with a little weekend flexing. Very quiet for an AT tire.
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 10:16 AM #4
Flyer Flyer is offline
Flyer will become famous soon enough
What PSI are you using? What rating are you Michelins? If they are P/Passenger rated and you are running around 32 PSI, they should be fine. I hear that the Copper AT3s ride nicely but the Michelins should too. Check your tire rating and the PSI. If you're running 35-40, it is too high anyway and will result in a crappy ride.
I have run many tires (Revos, AT2s, DurTracs, KO2s) and since the 4R no longer sees any off-road duty, the Michelins and Coopers are at the top of the list. I never felt that Michelins had overly stiff sidewalls. The KO2s do have slightly stiff sidewalls while the DuraTracs were softer at the same rating and PSI. They became super loud though.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
Flyer is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 11:38 AM #5
riverwolf riverwolf is offline
riverwolf is on a distinguished road
Noise is mostly subjective perception. What I find bothersome, you may not and vice versa. Even an attempt at measuring SPL with a meter when driving will include contributions from tire, wind, engine, etc. so narrowing the source down to just the tires will be tough. IMO, above about 45mph, the main noise contributor is probably wind given the less than aerodynamic shape of the 4R. Rumor had it the glass thickness was actually increased as a running change after the first year or two in an attempt to reduce wind noise.
That said, Tirerack does include owner's noise perception as a review category for tires they carry. However, one has to remember this is a subjective rating and most folks are also comparing their new tires to the worn out set they just replaced. Our auditory memory is very very short in reality (recovered audiophile, here).
I've been running a set of Michelin Defender all seasons for a number of years now...long enough that I should probably check to make sure they haven't aged out at this point...with an 80K tread warranty and the 4R splitting time with the convertible during good weather, I'm not close to wearing them down yet. Anyway, they've been the quietest tire I've tried...previously were factory Bridgestones and then a couple of sets of Continentals (can't remember which model). I do run my pressure around 35-36 psi, tending to prefer a firmer ride (I also upgraded teh 4Runner with stiffer springs/shocks as well as doing the same for my convertible, which already came with a factory sport suspension). Intuitively, I would expect higher pressure to actually make for a somewhat quieter ride (less contact area) while increasing firmness/decreasing comfort somewhat.
Will all of my tires, I've found the actual road surface seems to have the biggest impact on tire noise. Can't remember much about the factory Bridgestones, but the Contis and Michelins noise could be non-existent on some surfaces and then roar like an AT on others.
Good luck!
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 11:48 AM #6
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I have been running Michelin Defenders, stock size at 37 psi for several years and have no complaints about noise or ride suppleness. As suggested, what psi are yours? Some people think they need to be at 44psi all the time ... NO!
Old 09-14-2021, 10:18 PM #7
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
The one thing I haven't seen mentioned yet is....how old are your shocks, usually feeling every bump in the road points towards worn out shocks.
2004 Limited V8
Old 09-16-2021, 04:43 PM #8
Since my 4R does not have to endure any off-roading anymore, I think I may go with the Defenders this time. Michelin makes a good passenger type of tire. Too bad their ATs are barely ATs and they don't do MTs.
Old 09-19-2021, 12:55 AM #9
Real Name: Tim
Real Name: Tim
Thanks for the replies
I had my current Michelins at 38 PSI. Theyre about 4 year old tires. My suspension is new, BP51 up front with fox 2.5 in rear. The ride improved Alot with just that, but i still want a nice tire in addition tk the suspension improvements.
I spoke with another mechanic who has been doing work in the field for 32 years, and he suggested a touring tire. Sounds lame but I may give it a shot. Not sure yet
Old 09-19-2021, 08:55 AM #10
josephp732 josephp732 is offline
Real Name: Joe
josephp732 is on a distinguished road
Real Name: Joe
On my ORP I run PIRELLI SCORPION ALL TERRAIN PLUS they are a pretty good and low noise on the highway, handle bumps well.
On my Limited I have BFGOODRICH ADVANTAGE T/A SPORT LT, these are a great tire for on-road use. My Limited rides very nice on the highway - smooth and straight tracking with these tires. - 5 star rating on Tirerack.
2019 White 4Runner Limited - NJ
2019 Black 4Runner TRD Off Road - NJ
2019 Silver 4Runner Limited - FL
josephp732 is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 01:25 PM #11
Real Name: Joe
Real Name: Joe
My sliver Limited with BFGOODRICH ADVANTAGE T/A SPORT LT's
My black OR with PIRELLI SCORPION ALL TERRAIN PLUS
Soft/Quiet Tires for Pavement-20200702_182923a-jpg  Soft/Quiet Tires for Pavement-4runner-1a-jpg
Old 09-19-2021, 08:42 PM #12
Real Name: Tim
Real Name: Tim
Thanks a lot Joseph! The photos are very nice. Those Pirelli look really nice!
Old 06-08-2022, 03:59 PM #13
UURunner UURunner is offline
UURunner is on a distinguished road
I was reading that Advantage T/A Sport LTs by BF Goodrich were loud. Like hilariously loud! Are yours getting loud? Honestly my truck is older so I don't expect super quiet running, but I don't want to contribute to really loud road sounds, ya know?
UURunner is offline   Reply With QuoteReply With Quote
Old 06-08-2022, 04:12 PM #14
The Scorpions are quite good in all areas. Even on the Jeep, I run MTRs which are the quietest high-performing MTs I know of. Some are obnoxiously loud...like I can't stand being in vehicles with them on. I got rid on some new Nittos in 3 days once. Dick Cepek and all those MTs are just freaking annoying. KO2s are decent for aggressive ATs.
Old 06-08-2022, 04:18 PM #15
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
You didn't say which Michelin tire you're driving and if it's a P or LT rated tire. All of which will contribute to harshness of ride and possible noise.
38psi seems a bit high for a stock size tire, given that the placard calls for about 32psi. Also you didn't mention how worn your tires are, feathering will cause noise and vibrations as your driving.
The best you can do is find a tire that will have a sound profile that you can live with. The pitch and frequency of the sound is what most people notice/complain about (think the drone from big MTs at freeway speed or the howl of an aggressive AT or RT tire). But realistically you're likely looking at very soft tires that will likely wear very quickly.
BlackWorksInc is offline   Reply With QuoteReply With Quote
bumps , michelin , objects , road , tires
Relatively quiet tires BlacknTan 5th gen T4Rs 41 02-27-2020 11:06 AM
Best Current QUIET 33" OffRoad Tires bagelsjustbagels 4th Gen T4Rs 22 02-27-2020 08:36 AM
Best tires for pavement/highway driving??? RHINO-99 4th Gen T4Rs 31 10-28-2011 02:43 PM
Quiet but still agressive tires. JoeDuke 3rd gen T4Rs 25 04-30-2010 09:02 PM
Quiet All Terrain Tires for '96 4Runner? mugatu22 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-15-2008 12:00 AM
