09-15-2021, 08:04 AM
Does the 4th gen 4.7l V8 use a timing belt, or chain? ...
And is it an interference engine? Looking at some 4Runners like this and curious
Thanks very much in advance!
09-15-2021, 08:19 AM
Real Name: Ron
Real Name: Ron
Belt. No.
09-15-2021, 08:52 AM
Great, thanks very much.
09-15-2021, 09:40 AM
Belt and YES.
09-15-2021, 10:01 AM
Originally Posted by rdruss
Belt. No.
I'm almost certain it is an interference engine.
09-15-2021, 10:41 AM
Real Name: Taylor
Real Name: Taylor
Yeah definitely interference. Might get lucky though if it snaps and it won't ruin the engine.
Sent from my KB2007 using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
09-15-2021, 12:31 PM
Real Name: Sean
Real Name: Sean
Belt, Interference
2008 V8 4Runner Limited- Stock
1999 3rd Gen Limited
2020 TRD ORP
09-15-2021, 01:48 PM
Real Name: Ron
Real Name: Ron
Yes, there appears to be varying "opinions" on whether the 4.7 is an interference engine or not, I don't particularly want to find out from experience, but one account I read where the belt shredded and allowed one bank to go out of time 180 degrees but resulted in no apparent damage. replaced belt and it ran fine. So if it is an interference it must need just the 'wrong' conditions, i.e., high rpm at time of failure or something.
Whether it is or isn't it's still a fine engine, just make sure you change out the belt close to the recommended interval.
09-15-2021, 06:34 PM
Real Name: Skip
Real Name: Skip
@ speedmaster
PLEASE read all of the replies the general consensus is that the V8 is indeed an interference engine.
2004 Limited V8
09-15-2021, 07:02 PM
It’s a belt and just replace it …
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
09-15-2021, 07:07 PM
Belt and needs replacing every 90k, costs about $1000-$1300 to replace.
09-15-2021, 07:25 PM
Originally Posted by AuSeeker
@ speedmaster
Thanks VERY much!
09-16-2021, 04:40 PM
I did mine at 80K and then 170K. Yeah, around $1,200 or so. At this post-Covid rate of driving (no office again, ever I hope) I may never live to see the next change.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
09-16-2021, 07:09 PM
I've the 4.3 in my LS430 and the 4.7 in my runner, lucky me 2 pesky timing belts.
Both are interference engines. Do the pump and idlers on the second go round.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
