Old 09-16-2021, 10:46 PM #1
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
Overheated alternator from HKB voltage booster
In my very low miles 2003 4R, 5 serpentine belts shredded in year and a half w/o apparent causes. OEM and Bando. Last one also went behind damper and damaged crank seal.
Several times took out all pulleys, cleaned meticulously, greased, all OEM, bought new OEM ones but did not use them cause originals where perfect in all senses. Could not understand what was the problem.
In all ocassions damage to the belt occured soon after new belt installed, at the edge close to engine , not the radiator.
Called my attention after a while that the alternator pulley gradually lost its black brilliant color paint and alternator that was always clean, start staining small amount grease in the front. Alternator voltage was fine ( have amazon voltmeter/USB charger installed).
Review my notes and everything started 1 month after installing a HKB voltage to properly charged my AGM batt. I was running higher voltage 14.2-14.5v while in the road and higher than 12.2 when engine off that made me very happy.
Decided to remove booster and put original alternator fuse. End of problem. Several months now serpentine like new. Back to lower voltages
Will service alternator and buy new Denso one to have as spare for my long trips cause I may have shorten life of the original.
Any similar experience with voltage boosters?
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 09:52 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
been running the same booster for a few months now, not sure what your setup is, but i have a mechman high output 240 amp alternator, big 3 wire upgrade with 1 gauge wires, heavyduty green belt from gates and new belt tensioners and idle pulleys. didnt seen any downside of my setup since its putting out 14.6v to my dual battery setup.
the booster just tricks the alternator to give it more charge. did you verify that you at getting 14.5 or 14.6 while running? if not, then its backwards.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 12:27 PM #3
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
If you saw grease oozing out of the alternator, it has a failed bearing. That would account for all the shredded belts.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 07:34 PM #4
I believe it consequence not cause. It was not oozing initially and it is not oozing now, same alternator and zero belt problem. I do believe damage was done to bearing, new denso alternator ordered and will service the original.
Old 09-17-2021, 07:42 PM #5
As mentioned initial post, was running higher voltage similar 14.5-.6 and I was very happy for my AGM Batt. Don't have a mechan alt (I wish). It is the original Denso that came with the 4R. I do think that alternator overheated when tricked to get higher volts during long trips.
alternator , belt , oem , original , voltage
Alternator Voltage Question Texas_4Runner 4th Gen T4Rs 9 08-15-2023 05:20 PM
SOLD: Arclight LEDs Triple State Voltage Booster FoRunnuh For Sale: T4R Items 1 05-04-2021 09:01 AM
Alternator Voltage Question derekl123 4th Gen T4Rs 12 07-09-2020 01:46 PM
Bad voltage regulator on new alternator? KCscout 4th Gen T4Rs 9 06-23-2019 08:14 PM
2014 SR5 2WD Alternator Voltage Readings Lester Lugnut 5th gen T4Rs 0 07-16-2014 02:44 PM
