Old 11-30-2021, 11:23 AM #16
L4Time L4Time is offline
L4Time will become famous soon enough
Originally Posted by Bundutrailer View Post
Great cheap way, thanks
Thanks! It worked out really well.
fwiw, it took me about an hour to disassemble and stow the components. It occupies a storage space of about 2' x 2' x 4', including the mattress.
2008 Sport V6 ~100K miles, Eibach Pro-Truck Lift Kit, TRD Off-Road Premium wheels (5th gen), Michelin Defender LTX M+S 265/70R-17
L4Time is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 08:11 PM #17
trdxyr trdxyr is offline
Real Name: John
trdxyr is on a distinguished road
Real Name: John
Great work, thanks for sharing!
trdxyr
trdxyr is offline   Reply With QuoteReply With Quote
Old 12-01-2021, 11:04 AM #18
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
i guess it just have the right amount of space, a place to sleep and you can drive it anywhere. it's not too big or too small in my opinion. if you needed more space, you can always install something on the roof for your extra luggage.
Originally Posted by Ripper238 View Post
It's been great!
Is it just me or do these 4Runners have an aura of adventure and creativity that rubs off on its owners?
4r-4ever is offline   Reply With QuoteReply With Quote
Old 02-23-2022, 01:41 AM #19
Bundutrailer Bundutrailer is offline
Bundutrailer is on a distinguished road
Originally Posted by L4Time View Post
Post 1/3
After reading many accounts of people using their 4Runners as mini-campers, I decided to give it a try. I’ve just gotten back from my second 3 night trip, and I am pleased as punch with the results.
For anyone else out there who has been curious about this, I thought I’d post a brief write up of how I did it and add a list of materials. You should be able to build something like this yourself in a few hours after work for less than $250. (However, if you don’t already have basic camping equipment such as sleeping bag/pad, stove, etc., (like me), you’ll need to buy all that stuff as well. That all added up to about another $500. I’ll add my final equipment list at the end.)
I happen to have a 2008 Sport, but my impression is that this approach may be a good option for newer 5th generation 4Runners, too.
Attachment 387134
Project Parameters
These days, I don’t have access to a garage or a collection of power tools, so I needed a solution that I could build using off-the-shelf components and hand tools. Since my 4Runner is also my daily driver, I also wanted to avoid any permanent modifications to the vehicle, and the camper elements had to be easy to store, install, and remove for last minute camping weekends.
So my priorities were:
1. Sleeping comfort for one adult
2. Privacy and security in campgrounds
3. Good ventilation
4. Inexpensive
5. Easy to install, remove and store
6. No major alterations to the vehicle
7. Light weight materials for MPG and ease of storage
Additional Notes:
1. This probably isn’t the best design if you are planning on doing serious overland camping, but I’m sure clever people can improve on it.
2. The end result is a small space. If you are claustrophobic, bigger than 6’/200lbs, or not very limber, this solution may not be for you.
Interior Components
I decided to build the bunk space the same width as the larger of the two fold down rear seats, which is about 32” wide in my 2008 4th Gen. This promised a comfortably wide sleeping area, and I could use the folded seat to support the head of the bunk. I could also leave the other rear seat in place where it acts as a “living room” and entry point for the bunk.
Sleeping Platform
For this, I used standard ClosetMaid 48” x 16” wire shelf sections. When zip-tied together, and properly supported using 8” lengths of ½” PVC pipe, elbows and #12 hose clamps, they can form a remarkably strong and lightweight platform. I didn’t plan it this way, but I found that wire shelving sections have enough “give” to feel like a box spring, making the sleeping surface very comfortable.
Two 4’ sections zip-tied back to back form the upper end of the bunk. Another 4’ section is attached crosswise to them spanning the cargo area to support the legs. One last section is added at the rear and loosely zip-tied to the spanning section to support the feet. This also allows the rear-most section to slide forward, and both spanning sections can be tipped up for access to the storage area underneath.
I placed a cheap 6’ yoga pad on the shelving section to protect a sleeping pad/air mattress from any sharp points. This would also be important as insulation under an air mattress. I opted for a more expensive 3” memory foam mattress, and I’m very glad I did.
Attachment 387142
Attachment 387136
This results in quite a lot of storage space under the platform.
Attachment 387137
Attachment 387138
Attachment 387139
The left rear seat becomes a useful and fairly spacious area with the drivers seat moved forward.
Attachment 387140
Adding a privacy screen up front, stick-up AAA lights and a rechargeable fan makes it comfy.
Attachment 387141
Good ideas here, I bought a portable awning from moonshade to compliment.
Bundutrailer is offline   Reply With QuoteReply With Quote
Old 02-25-2022, 10:07 AM #20
I was considering that, too. I decided to try the simple tarp solution first to see how it works out.
Plus I'm cheap!
Old 02-28-2022, 01:32 PM #21
Rapidrob Rapidrob is offline
Real Name: Rob
Rapidrob is on a distinguished road
Real Name: Rob
Thank you for posting the idea. looks great for the every-now-and-then camping weekend.
Rapidrob is offline   Reply With QuoteReply With Quote
Old 03-01-2022, 08:31 AM #22
x-77-x x-77-x is offline
x-77-x is on a distinguished road
my kids just slept in the back with the seats down on a blanket... =P
x-77-x is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 10:35 AM #23
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I did something similar in mine, just not elevated. Also on the wider passenger side.
Used a piece of scrap wood siding left over from our barn. Hinged at where the seats fold so that it can be folded so the seat can be raised. Two 2"x3" boards as leveling spacers (5th gen). 2" by seat, 3" by rear hatch.
I used it once. Then took it with me on a road trip but didn't use it.
Sent from my SM-S908U using Tapatalk
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 08-14-2022, 08:18 AM #24
Flybynight's Avatar
Flybynight Flybynight is offline
Flybynight is on a distinguished road
Flybynight's Avatar
I camp in mine all the time but I just fold the seats down and use a sleeping pad + sleeping bag. I put the cooler in the passenger seat and I have a tupperware bin with all the camping stuff that fits under the rear of the rig so it wont get wet if it rains. I tie/bungee a small tarp off the roof racks to a tree.
It works, is simple and tears down in minutes for a quick getaway when you get sick of camping after 2-3 days
Flybynight is offline   Reply With QuoteReply With Quote
area , rear , seat , section , sleeping
Best/Comfy way of exiting 4Runner TRD84Runner 5th gen T4Rs 28 09-04-2019 11:42 AM
Seat problems....and not the typical its not comfy Vwright14 5th gen T4Rs 5 09-19-2014 10:32 AM
Comfy shocks and springs for pavement driving? nicolachel 4th Gen T4Rs 8 10-27-2011 03:17 PM
Convert CA exhaust to 49 States? Convert 2 Cats to 1? jdp 3rd gen T4Rs 2 10-22-2011 02:33 PM
Possibly convert from Fj to 4Runner Underoath 5th gen T4Rs 14 09-14-2010 08:56 PM
