Old 09-17-2021, 02:38 PM #1
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Managing Fill-Ups with the Trip Odometer
The whole "when to fill up" question seems to come up regularly given that the light comes on pretty early and the range mileage isn't entirely unreliable. Here's what I do, but YMMV - literally in this case. ;-)
I have an '07 Sport and here's the math:
Fuel capacity = 23 gal
My average MPG = ~17 (based on years of recording miles traveled/gallons to fill)
So:
1. Reset trip odo at each fillup
2. True range should be ~391 miles (23 gal x 17 mpg), but reduce each figure to be conservative: use 22 gal x 16 mpg = 352 miles
3. Watch needle & light but use trip odo to determine when to refuel
4. Put in 15 to 18 gallons and think, "I really have to cut my safety margin" but never do it for fear of being "that guy" who runs out of gas in a vehicle with a light and a generous reserve after it comes on.
Do this for a bit and you'll get a great feel for when you need to stop for gas. For example, I was watching MPG in real time via OBD Fusion on one road trip and knew the average was up around 20 on that leg. The trip odo was 405 or so when I ran out of nerve (not gas!) and filled up even though I knew I had at least 450 miles of range. And yep, still had ~3 gal in reserve, though you wouldn't have known it by the way I was sweating driving down I-24 with the light on for 45 minutes and the gauge needle buried below E.
Other times, for instance if I've been offroading, I know the average will be lower so I'm more conservative.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 05:02 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
With my truck, when the needle is at E, I have 3 gallons left. On roadtrips, for quick math multiply that by 11mpg and you get a conservative 33 miles to find a fuel stop.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 11:10 PM #3
Racso Racso is offline
Racso is on a distinguished road
I have been keeping track of my mpg and the highest I’ve gotten is 19.66/gallon on a V8. I use the trip odometer and divide that by the gallons I put. I always fill my tank all the way every time I get gas. Once I get bigger tires I just might stop keeping track of the mpg.
Racso is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 06:58 AM #4
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
tire size will make the mileage off a little.
im not sure what im getting for mpg, i have 32 inch tires and speedo healer installed, not sure if that is even make my mileage accurate. my drone app and odometer do read a little differently.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 10:37 AM #5
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
If you have the speedo-healer installed and your speedometer agrees with GPS on flat level land, your mileage on the odo and trip meter is correct as well.
It'll help make the computer milage estimates more accurate, but mine are still off anywhere from 1 - 3 mpg on any given tank.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 01:28 PM #6
Whamola Whamola is offline
Whamola is on a distinguished road
This Summer was wild...I was getting over 400/tank. Once got to about 450, but was running interstate wide open no stops for 4-5 hours a leg. Sure wish that v8 had any sort of City fuel economy. I'm normally about 315-325 / tank.
Whamola is offline   Reply With QuoteReply With Quote
average , gal , light , miles , trip
98 analog trip odometer broken fastolds 3rd gen T4Rs 1 04-21-2018 02:11 PM
2016 Trail Premium - is there a trip odometer? BilboSchwaggins 5th gen T4Rs 10 08-06-2017 03:02 PM
trip odometer riceandpho 4th Gen T4Rs 3 01-29-2014 12:30 AM
Trip Odometer AtlantaVillan 5th gen T4Rs 3 10-14-2012 01:00 AM
Trip odometer quit working Skrimz 3rd gen T4Rs 0 06-01-2011 04:11 PM
