Old 09-19-2021, 06:02 PM #16
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Originally Posted by Toystory2 View Post
My 2007 4WD had been clunking and squeaking when I would roll over a bump or hit a dip in the road.
But now that I have replaced both front upper and lower control arms, and front/rear shocks, it is still clunking!
Any idea what to check for next??
Only thing I can think of is sway bar bushings.
Don't forget the expensive 1/2 steering shaft replacement. Mine was $275 from Toyota and was one of my last clunks that I fixed last year and completely worth it.
gaber6 is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 08:16 PM #17
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
That’s interesting. I didn’t suspect the sway bar initially because I didn’t think it would generate that loud of a clank. I just ordered new bushings, so I’ll take it off and give it a good check when I put those on. If it still squeaks, I guess the sway bar links are next.
The links can seize up, which will lead to them breaking. Or the ball joints can fail, giving them wiggle room to not transmit forces into the bar.
You'll be able to tell that the links are failing. Moog links are much better than OEM Toyota links. They have a larger diameter shank and a better design for installation/removal.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 10:00 PM #18
Toystory2's Avatar
Toystory2 Toystory2 is offline
Toystory2 will become famous soon enough
Toystory2's Avatar
Gosh, I hope I can hold off on that for at least a couple more years!
Toystory2 is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 10:02 PM #19
Toystory2's Avatar
Toystory2's Avatar
Thanks, I’ll check into Moog if it ends up being the links. Sure they’ll be cheaper than OEM.
Old 09-22-2021, 03:58 PM #20
MikeinNH67's Avatar
MikeinNH67's Avatar
Thanks, it actually is more of a thunk sound… and it’s not every bump, but more of the big ones.
Come to think of it, we may have tightened the arms in without load on the suspension….
If that’s the case, how would you fix that? Undo and retighten under load?
Thunk is most likely a sway bar issue as mentioned. I actually loosened mine shoved some bicycle tube in there to prove it was those bushings. It was and that tube is still in there a couple years later.
On the arms, you just need to loosen the nuts, let them settle and tighten them back up. You can do it whichever way works for you, using a jack or with the tires on if you can fit.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-22-2021, 06:06 PM #21
CJFONNER CJFONNER is offline
CJFONNER is on a distinguished road
Still squeaking after suspension refresh
Something you may not have thought to check...the gaskets between the different sections of the exhaust system.
I had an elusive metallic clunk/squeak on large bumps as you describe. Replaced every single suspension component (it was due anyways at 150k miles). Clunk/speak persisted. Got out the spray bottle with soapy water. The gasket between the y pipe and the main cat had deteriorated enough that that joint would move when I hit a big enough bump. Replaced that gasket and noise was gone and hasn’t come back.
It’s a conical gasket that aligns the two sections as the joint is tightened.
I would check there - it may be your culprit.
CJFONNER is offline   Reply With QuoteReply With Quote
check , clunking , front/rear , shocks , squeaking
‘14 TE hit 100k mi - Suspension Refresh? Throwback 5th gen T4Rs 5 03-22-2021 03:11 PM
All original suspension need refresh! T4R416 4th Gen T4Rs 6 07-09-2020 08:51 PM
Suspension refresh kit? dcTR4 4th Gen T4Rs 6 11-28-2018 02:22 PM
suspension refresh: more confused than ever mhenks05 4th Gen T4Rs 10 01-30-2018 09:08 AM
Suspension refresh on 05 SR5 ThatSickRip 4th Gen T4Rs 7 12-21-2017 09:06 PM
