Old 09-24-2021, 10:06 PM #1
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
Prep for Cali Emissions Test
I could use your advice, I have a 2008 4.0 with a new used engine. I ran the Non Continuous monitors and all test PASSED but the emission test failed. Any thoughts? I would like to get the smog test done ASAP.
Thanks!
Prep for Cali Emissions Test-img_5714[1]-png  Prep for Cali Emissions Test-img_5704[1]-png  Prep for Cali Emissions Test-img_5706[1]-png
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 04:05 PM #2
MikeinNH67's Avatar
MikeinNH67's Avatar
Do you have any active codes? Is the check engine light on? I can't tell by the app you are using if it's code related or just not enough drive cycles.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-27-2021, 09:58 PM #3
Real Name: Kevin
Real Name: Kevin
Good question, no codes.
I may have driven the truck 12-16 times since the replacement engine install was completed. Maybe 120 miles. Its a good thing we waited because I found out the AFE cold air intake is not CARB compliant so I put in an offer for a used system on ebay for local pick up.
Old 09-27-2021, 10:26 PM #4
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Did you get an air/fuel ratio tune after your cold air intake. Could cause running rich or lean. Anyways to pass the dumb test install dummy downstream o2 sensors. Use your existing ones and wire in proper resistor and capacitor to send proper signal regardless of the root problem. Test with propane torch and multimeter to ensure proper values.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
emission , failed , passed , test , thoughts
Have Cali emissions: can I delete one cat?? RussToy 3rd gen T4Rs 17 05-07-2018 12:56 AM
Cali vs Fed emissions ECU for Manual trans swap Drew76 3rd gen T4Rs 0 01-07-2018 12:05 PM
3rd gen Cali exhaust and emissions Nimic13 3rd gen T4Rs 15 08-29-2016 09:13 AM
need to confirm I have cali emissions 4runner lhsoulrebel 3rd gen T4Rs 4 02-02-2011 01:13 PM
any one runny a urd sim on cali emissions t4rn?? 99Yotarunner 3rd gen T4Rs 4 11-12-2010 07:24 PM
