Old 09-25-2021, 06:25 PM #1
4runnerlexky's Avatar
4runnerlexky 4runnerlexky is offline
4runnerlexky is on a distinguished road
Brake lines, bleeding issues, abs light fix
Hello Lads,
There was a slight problem with brakes and I changed the fronts. Upon doing so I snapped the brake hard line going to the caliper. This halted production of all four since the store was closed.
Next day found a brake line 8 inches. Please get a pipe bender. I know you say you can do it yourself, but $4.88 will add up when this was also with caliper replacement.
My suggestion but brake line and then just get a flaring tool. The flaring kit at AutoZone is not too bad on price. They have fittings there too! Just get some thread tape.
During the back bleeding to get it out of the shop it blew the back line after I attempted to bleed it. Made more brake line bended, but realized air got in my abs.
Luckily there is a code scanner with an auto abs bleed option. Key on set up press brake it will auto bleed. Saves you a trip to the dealership and also saving yourself from taking the dare to bleed them with another buddy manually.
Final thoughts:
Youre going to snap bolts replacing the back brakes line hangers. Just drill tap and use any bolt that matches to the hex size. I believe it's 12 or 14mm. If rusty get backout sockets and replace bolts. I would suggest getting a induction tool. Heat these bolts. If anyone has done exhaust work I'm sure that would be good during a manifold job. I have attached the tools and links for your 4runner.
Induction tool: Amazon.com: Ductor Magnetic inducing Heater Kit For Automotive Flameless Heat Tool Automotive Flameless Heat Tool Hand-held Thread-lock Compound Nuts Design : Automotive
Flaring tool: https://www.googleadservices.com/pag...BAgBEBE&adurl=
Proper Tap and Die Set. #1 rated: Amazon.com: Muzerdo 86 Piece Tap and Die Set Bearing Steel Sae and Metric Tools, Titanium Coated with Metal Carrying Case : Industrial & Scientific
Code scanner ABS bleeder: Amazon.com: Autel MaxiCheck Pro ABS Autobleed OBD2 Diagnostic Tool, with ABS/SRS Airbag, Oil Reset, SAS, EPB, BMS for Specific Vehicles, Lifetime Free Update, Affordable Ideal Service Tool for Technicians/ DIYers : Automotive
Sent from my SM-N986U using Tapatalk
4runnerlexky is offline   Reply With QuoteReply With Quote
abs , bleed , brake , line , tool
Rear brake lines exploded while bleeding brake fluid benztech82 4th Gen T4Rs 3 08-11-2017 08:16 PM
Brake bleeding issues thardy 3rd gen T4Rs 0 01-28-2015 09:25 AM
Help, brake pads replaced but bleeding issues. toy-runner 3rd gen T4Rs 54 08-30-2011 10:11 PM
brake bleeding issues. hopleaf Classic T4Rs 8 08-23-2010 05:50 PM
Brake Light on after bleeding ryani 3rd gen T4Rs 11 02-18-2010 10:56 PM
