Old 12-14-2014, 05:16 PM #1
manp0899's Avatar
manp0899 manp0899 is offline
manp0899 is on a distinguished road
manp0899's Avatar
Worse gas mileage after changing O2 sensor
So I got the code for a bad cat. Instead of replacing it I decided to get a URD dummy sensor, where it connects to the downstream sensor and sends a good signal back to the car so I dont get that pesky check engine light disabling my VSC. About a year later and decided that my gas mileage has been sign worse and instead of changing the cat I wanted to replace the O2 sensor for a cheaper solution. After changing the o2 sensor I noticed that my mileage was worse than before. Anyone had a similar situation or solutions that would break the wallet?
manp0899 is offline   Reply With QuoteReply With Quote
Old 12-14-2014, 08:55 PM #2
Chaz526's Avatar
Chaz526 Chaz526 is offline
Chaz526 is on a distinguished road
Chaz526's Avatar
Somebody correct me if I'm wrong, but can't a bad cat cause your MPG to suffer?
Chaz526 is offline   Reply With QuoteReply With Quote
Old 12-14-2014, 11:04 PM #3
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Unhook the battery for 30 minutes. Hook the battery back up and let it idle for 30 minutes.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 12-14-2014, 11:26 PM #4
Jeremy556's Avatar
Jeremy556's Avatar
So, you knew you had a bad cat a long time ago, decided to do a mod to ignore that fact, then when you undid the mod your mileage got worse? Did you do anything to diagnose the problem that caused the clogged cat in the mean time?
Old 12-15-2014, 04:15 AM #5
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
@#3 comment, 10mins is ok both ways..30 mins idle is way too much
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 12-27-2014, 12:37 PM #6
manp0899's Avatar
manp0899's Avatar
I did not undo the mod. My fear is that the VSC will turn on and in the winter I want to make sure I have my 4wd available. I will most likely try it this spring and see if the Check Engline light turns on then.
I just decided that instead of changing the CAT i try to 02 sensors first. I took the car to the dealership and another mechanic. Other than OBD2 sensor im not sure if they did anything else to diagnose the problem further.
Old 10-01-2021, 12:12 AM #7
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Same thing my cats started going bad right at 100 thousand miles. Truck ran like crap and gas mileage was suffering. Obviously this needed fixed before I could get to removing the exhaust system to get trash can cats out and straight pipe them. I used my existing downstreams and wired in the correct resistor and capacitor to send correct values back to computer. Test with propane torch. Relearned the air fuel ratio. Completely fixed until I get bad cats out. Gas mileage went up almost three mpg.
Worse gas mileage after changing O2 sensor-screenshot_20210904_161851-png
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Think I have my worse-than-normal fuel mileage licked Nuke 4th Gen T4Rs 3 05-05-2014 07:48 PM
What's the worse that could happen? Changing steering components... JWaldz 3rd gen T4Rs 11 10-05-2012 06:45 AM
Worse mileage after K&N?!?? MtnBkr 4th Gen T4Rs 16 09-28-2012 08:01 PM
Problem even WORSE after cleaning MAF sensor airbag 3rd gen T4Rs 16 11-05-2009 02:03 AM
Why do bigger tires cause worse mileage? HuntRunner 4th Gen T4Rs 38 01-09-2006 11:47 AM
