Old 09-30-2021, 11:45 PM #1
404NotFound's Avatar
404NotFound 404NotFound is offline
Real Name: Chase
404NotFound is on a distinguished road
Real Name: Chase
Head gasket concerns
I noticed the other day that my coolant reservoir was really low, as in nothing in the tank. Got a little concerned because I don't know if 05 1GR was before or after the redesign and I'm not sure if anyone knows it for sure. So I topped it off and the next day, back to almost nothing. I had Toyota flush the coolant at around 205 thousand, and what's in there is still pretty and pink. Oil changes aren't cloudy, just did a cold start and there was no puff of white smoke either. And the glycerin I smell I think is because I didn't use a funnel when pouring new coolant so I spilled a bit in the engine bay. I'm at 231,000 now and the only symptoms I'm having are the coolant loss and when I start it It sounds bubbly in the dash, but the AC is always on too. Not running hot, no sluggishness, just the coolant loss and bubble sound that I've witnessed.
I know they make tests for this situation but I'm currently on a tight budget and I'm hoping that the stress involved with that is just causing me to psych myself out. Especially knowing that the head gasket failure really isn't that common from what I can tell.
Galactic Grey Mica 2005 4Runner SportEdition 4WD 4.0L - C4 Fab lo-pro bumper - Smittybilt winch - Rigid ditch lights - 5100/OME lift - 2017 TRD Off Road Wheels w/ Falken Wildpeak AT3 - Pioneer 8500NEX - 06+ LED Taillights - aFe intake - Weathertech mats
404NotFound is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 06:36 AM #2
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
I would start by pressure testing the cooling system. Don't focus on the head gasket until you rule out a simple coolant leak elsewhere. And don't drive much until you do this as driving around with low coolant levels can lead to an overheat - which leads to much more costly issues.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 11:08 AM #3
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
i don't think it's a head gasket. how fast does it leak? check any area with pinkish crust. also, you can have your oil tested just to make sure it's not leaking inside. it could be leaking just behind your water pump. do you smell a foul odor inside the cabin?
4r-4ever is offline   Reply With QuoteReply With Quote
Old 10-07-2021, 05:20 PM #4
Real Name: Chase
Real Name: Chase
It can drain the reservoir in no time. The weird thing is that there is always some coolant left in the bottom of the reservoir, which makes me believe it's not the head gasket and the leak is in the reservoir itself. But it only happens when it's driven.
coolant , gasket , head , loss , start
Head Gasket or Cracked Head 02 4runner - Colorado any mechanics out there? vanderwiel 3rd gen T4Rs 9 09-26-2021 09:10 PM
Valve cover gasket change pics. Any concerns with the condition of these internals? jlaw904 4th Gen T4Rs 5 03-16-2021 02:16 PM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
New T4R - concerns - P0022 and head gasket mooch91 4th Gen T4Rs 1 11-06-2017 11:42 PM
1994 head gasket concerns 1337 Classic T4Rs 2 09-17-2008 08:04 PM
