Old 10-01-2021, 02:17 PM #1
ddicosmo's Avatar
ddicosmo ddicosmo is offline
Real Name: Dave
ddicosmo is on a distinguished road
ddicosmo's Avatar
Real Name: Dave
Should I replace seals if rebooting both CV Axles?
My 2008 SR5 V6 4x4 has 120k miles on it and both inner CV boots are torn. I've decided to pull the original axles and get the Toyota CV kit on Ebay for about $60 each and reboot both sides. I'm wondering if I should also order and replace the seals on the differential side as well. The originals don't seem to be leaking. I haven't done this work before so I'm wondering if I should tamper with the seals or not. Are the seals easily replaceable without having to use specialized equipment (ie. seal pullers?). Looking for any advice on this. Thanks,
Dave.
ddicosmo is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 04:29 PM #2
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
I just replaced my axles at 100 thousand miles due to a slight steering wheel vibration under acceleration. Also I notice one of the dust seals just started dripping slightly after some off roading a couple days before I changed the axles. After cleaning the dust seal good I could see that the actual rubber seal and springs that keep pressure on the axle shaft were in brand new shape. The OEM seals are excellent quality. Under closer inspection I could see that the seal was a tiny bit cock eyed. I tapped it back into flush. No more drip. If they aren't leaking and the rubber areas look good then they are fine. You can get them out by prying carefully with a long screwdriver without touching inside the diff.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 04:36 PM #3
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
If you choose to replace the front axle seals at the diff note that they do NOT sit flush. They must be set at a certain depth. Ask me how I know....
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 04:54 PM #4
Jakeepoo3's Avatar
Jakeepoo3's Avatar
That's correct I misworded that. I set it back so it was not slightly cock eyed. Make sure you note where they sit before you replace them. Too far you'll be breaking a new seal out.
Old 10-01-2021, 07:20 PM #5
ddicosmo's Avatar
Real Name: Dave
ddicosmo's Avatar
Real Name: Dave
Thanks for the advice. I haven't pulled the axles yet so I don't know what shape they are in. I'm hoping that the original OEM ones are fine so I don't have to go through the process of installing new ones...
Old 10-01-2021, 08:21 PM #6
Jakeepoo3's Avatar
Jakeepoo3's Avatar
You would most likely know if they were bad. To check the joints grasp the joint housing firmly and check for lateral play, side to side. There should be no play side to side. A little in and out play is normal. You're going to have to take the axles out anyways to get to the dust seals. Have fun! Let me know if you have a question.
Old 10-01-2021, 08:35 PM #7
ddicosmo's Avatar
Real Name: Dave
ddicosmo's Avatar
Real Name: Dave
One final question. Do you know where I can get good quality cotter pins for the tie rod castle nut as well as for the axle nut? Are zinc or stainless better?
Old 10-01-2021, 09:58 PM #8
Jakeepoo3's Avatar
Jakeepoo3's Avatar
I prefer stainless steel cotter pins. The zinc plating could possibly wear off and lead to rust.
axles , replace , seals , tamper , wondering
Replace Rear Seals - Charleston, SC johnsIslander 3rd gen T4Rs 1 10-10-2019 07:08 PM
replacing front axles - which seals should I replace? moodle 4th Gen T4Rs 4 08-04-2017 01:11 PM
Lessons learned - front CV axles, seals, tools alia176 4th Gen T4Rs 4 01-23-2017 07:48 PM
FS: 4th Gen CVJ Axles and seals, JBL OEM Sub Enclosure - Charlotte NC youngr For Sale: T4R Items 13 08-05-2015 11:43 AM
FS (SC): F+R Open 4.10 Axles, BNIB transfer case seals clemson4r For Sale: T4R Items 10 06-09-2014 07:25 AM
