Originally Posted by ddicosmo
Thanks for the advice. I haven't pulled the axles yet so I don't know what shape they are in. I'm hoping that the original OEM ones are fine so I don't have to go through the process of installing new ones...
You would most likely know if they were bad. To check the joints grasp the joint housing firmly and check for lateral play, side to side. There should be no play side to side. A little in and out play is normal. You're going to have to take the axles out anyways to get to the dust seals. Have fun! Let me know if you have a question.
