Old 10-04-2021, 09:25 AM #16
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
T-Case I used Mobil-1 at whatever weight was called for. Front and Rear I used Chevron Delos because its full synth and cheap.
Transmission I used Maxlife back when it was available from Wal Mart. I could get it 20$/gallon instead of 25+/qt. If you have a Toyota dealership locally that prices WS reasonably its worth getting the real stuff. However, around here dealers charge an arm, leg, and first born for everything.... So Maxlife it is.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 10:57 AM #17
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
I got WS for around $11/qt but only because I found an online dealer that had it for that much. I think my local dealer wanted like $16/qt but they were willing to price match
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with Icon 2" Spring | Steal Custom Series GEN5 Wheels | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 12:05 PM #18
ddicosmo's Avatar
ddicosmo ddicosmo is offline
Real Name: Dave
ddicosmo is on a distinguished road
ddicosmo's Avatar
Real Name: Dave
Is it ok to mix different differential oils? I had my front and rear differential fluids changed at a Toyota shop about 2 years ago. I have to replace my two front axles and therefore will loose some diff fluid in the process. I have some Mobil1 Synthetic and Valvoline Synthetic 75-90 fluid. I don't know what is in the diff but is it ok to top it off with synthetic (ie. mixing different fluid types)?
ddicosmo is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 12:07 PM #19
completely compatible with each other.
Old 10-04-2021, 12:09 PM #20
maxlife is still available at walmarts, never heard of them not carrying it. & its still <$20/gal & $4.50/qt... where do you see it for $25+/qt???
Valvoline MaxLife Multi-Vehicle Full Synthetic Automatic Transmission Fluid (ATF) 1 GA - Walmart.com
Old 10-04-2021, 03:31 PM #21
Flesh Eater Flesh Eater is offline
Flesh Eater is on a distinguished road
Diffs, transfer case, and engine are all Amsoil. Transmission is Toyota WS.
Work fine for me.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
curious , differentail , fluids , put , truck
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 10 06-29-2021 12:24 AM
Transmission Fluid (tricky situation) (muddy fluid) hairpin 3rd gen T4Rs 16 10-31-2020 09:25 PM
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 7 01-11-2019 07:27 AM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
