Old 10-04-2021, 09:25 AM #16
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
T-Case I used Mobil-1 at whatever weight was called for. Front and Rear I used Chevron Delos because its full synth and cheap.
Transmission I used Maxlife back when it was available from Wal Mart. I could get it 20$/gallon instead of 25+/qt. If you have a Toyota dealership locally that prices WS reasonably its worth getting the real stuff. However, around here dealers charge an arm, leg, and first born for everything.... So Maxlife it is.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 10:57 AM #17
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
I got WS for around $11/qt but only because I found an online dealer that had it for that much. I think my local dealer wanted like $16/qt but they were willing to price match
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 12:05 PM #18
ddicosmo's Avatar
ddicosmo ddicosmo is offline
Real Name: Dave
ddicosmo is on a distinguished road
ddicosmo's Avatar
Real Name: Dave
Is it ok to mix different differential oils? I had my front and rear differential fluids changed at a Toyota shop about 2 years ago. I have to replace my two front axles and therefore will loose some diff fluid in the process. I have some Mobil1 Synthetic and Valvoline Synthetic 75-90 fluid. I don't know what is in the diff but is it ok to top it off with synthetic (ie. mixing different fluid types)?
ddicosmo is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 12:07 PM #19
completely compatible with each other.
Old 10-04-2021, 12:09 PM #20
maxlife is still available at walmarts, never heard of them not carrying it. & its still <$20/gal & $4.50/qt... where do you see it for $25+/qt???
Valvoline MaxLife Multi-Vehicle Full Synthetic Automatic Transmission Fluid (ATF) 1 GA - Walmart.com
Old 10-04-2021, 03:31 PM #21
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
Diffs, transfer case, and engine are all Amsoil. Transmission is Toyota WS.
Work fine for me.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 10-03-2022, 11:12 PM #22
BradB's Avatar
BradB BradB is offline
BradB is on a distinguished road
BradB's Avatar
Sorry to drag up this old thread but I recently got an 08 4R and wanted to change the diff and transfer case fluids.
I’ve had a gallon of Mobil 1 Delvac 75w90 sitting in my basement for a couple years. Is Delvac ok to use? I’m not sure how it’s different from the standard M1 75w90. Can they be mixed?
I’m assuming that the age is no issue.(?)
Thanks!
‘23 Toyota 4Runner TRD ORP / ‘96 Porsche Carrera 4S / ‘14 Porsche Carrera S / ‘17 Audi TTS / ‘17 Porsche Macan GTS / ‘21 Honda CRF300L / ‘23 BMW R1250GS / ‘23 Husqvarna Norden / ‘22 Honda CB500X / 1959 Radio Flyer
BradB is offline   Reply With QuoteReply With Quote
Old 10-06-2022, 11:29 AM #23
2003V8LTD 2003V8LTD is offline
2003V8LTD will become famous soon enough
Originally Posted by CO4x499 View Post
I need to put new fluids in the truck and am curious what fluids everyone is running.
For this type of thing I would absolutely, positively use OEM fluids. There may well be aftermarket ones that work fine but for a few $$ why risk it?
2003V8LTD is offline   Reply With QuoteReply With Quote
Old 10-06-2022, 04:47 PM #24
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
Valvoline full synthetic in t-case and both diffs. Almost fifteen years and no issues. Yes, it’s been changed several times in that span.
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 11:57 AM #25
Iceman710 Iceman710 is offline
Iceman710 is on a distinguished road
Ran mobile 75w-90 stock now lucas 85w-140 on 4.88.
Iceman710 is offline   Reply With QuoteReply With Quote
curious , differentail , fluids , put , truck
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
Transmission Fluid (tricky situation) (muddy fluid) hairpin 3rd gen T4Rs 16 10-31-2020 09:25 PM
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
