Old 10-01-2021, 04:06 PM #1
CO4x499 CO4x499 is offline
CO4x499 is on a distinguished road
What differentail and transmission fluid are you using? Do you enjot it?
I need to put new fluids in the truck and am curious what fluids everyone is running.
CO4x499 is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 04:20 PM #2
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
The manual says to use 75w-85 but I use 75w-90 on both differentials and transfer case.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 05:22 PM #3
riverwolf riverwolf is offline
riverwolf is on a distinguished road
Mobil 75w-90 Synthetic. I'd need to check my records to confirm, but pretty sure I've got 100k+ miles on the Mobil without issues, but I don't tow or do any significant offroading (occasional beach driving and farm roads...some concrete curb hopping when needed).
FWIW, the normal service schedule suggests that Toyota considers the gear oil to be "lifetime"...not that I really believe in lifetime fluids, but gear oil would probably be one of the products closest to achieving it, IMO. I've been intending to change mine again, but like a lot of things on an 18 year old rig, it's easy to put off until another day since it still works and isn't really hurting anything... :-)
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 05:27 PM #4
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Fuchs 75W-90 Semi Synthetic Driveline Oil all round.
As I don't know if they have ever been changed before, I intend changing again in 30,000 miles or so, and might switch to fully synth then.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 06:15 PM #5
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
Valvoline 80-90 Rear diff. 2WD. 15K miles. No tow. No issues so far.
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 06:21 PM #6
montijo505's Avatar
montijo505's Avatar
Mobil 1 in the differentials and Toyota OEM WS in the tranny
Old 10-01-2021, 06:39 PM #7
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
75w90 up front and transfer case. Cant remember the brand. I think front is Walmart Supertech and transfer case is Mobil 1 Delvac (good stuff).
Amsoil Severe Gear 75w140 in the rear because of my Spartan locker.
Transmission is a mix of Amsoil Signature Series ATF and Toyota type-iv. I have the 4speed.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 10-01-2021, 08:29 PM #8
Jakeepoo3's Avatar
Jakeepoo3's Avatar
I changed mine at 100 thousand. Oil was clean and no burnt smell. Check your magnets! Fine baby powder is normal. Shavings bad!
Old 10-01-2021, 08:49 PM #9
josephp732 josephp732 is offline
Real Name: Joe
josephp732 is on a distinguished road
Real Name: Joe
- Amsoil Severe Gear 75w90 for the front and rear differentials
- Royal Purple Synchromax for the transfer case
- Ravenol ATF Automatic Transmission T-WS Lifetime Fluid for the transmission
2019 White 4Runner Limited - NJ
2019 Black 4Runner TRD Off Road - NJ
2019 Silver 4Runner Limited - FL
josephp732 is offline   Reply With QuoteReply With Quote
Old 10-02-2021, 03:24 AM #10
Bagels's Avatar
Bagels Bagels is offline
Bagels will become famous soon enough
Bagels's Avatar
This is the way
2008 4Runner
Mod List: Daystar 2.5"/1.5" Lift, BF Goodrich KO2 275/70r17, TRD Pro Rims, Spidertrax 1.25" in front and All Pro 1.5" in rear, Katzkins Seat Leathers, 15% ceramic tint, Joying 10.1" Head Unit, Remote Start, DRL Mod, Map Light Mod, Dash Cluster LED Upgrade, Area Camp Lights.
Bagels is offline   Reply With QuoteReply With Quote
Old 10-02-2021, 09:32 AM #11
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
Originally Posted by Bagels View Post
This is the way
I second this
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 10-02-2021, 12:28 PM #12
valvoline synthetic in front/rear dif's & xfer case.
MAXLIFE in trans...
Old 10-03-2021, 01:47 AM #13
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Mobil-1 synthetic 75w90 in diffs and T-case and Toyota ATF-WS in transmission. Not sure if they were ever done by previous owner (doubt it) so changed everything at 150k and will likely change it again in another 50k
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 10-03-2021, 12:09 PM #14
WMU53's Avatar
WMU53 WMU53 is offline
WMU53 is on a distinguished road
WMU53's Avatar
Not certain how I would enjoy transfer case oil. Hahaha.
I use the TOYOTA brand @ $25 a quart. It has all the chemistry required to lubricate and ensure seals do their job.
When you are running off road - serious shyte man - you want the vehicle to perform without lubrication issues. Example being I use mobile grease 28 on the u joints. It is aircraft landing gear grease that it clay based. Sticks like cat shit to a blanket. After mud/water holes, gravel/tall grass and water the u joints remains greased. Ensure you use a separate grease for the sliding yokes EH!
WMU53 is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 08:32 AM #15
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Changing it only once every 100k miles, I dont mind spending more for premium lube. I use Amsoil severe gear in diff, transfer and Amsoil WS trans fluid.
Gear lube $15/qt
Trans fluid was $140 for 10 qt jug (fluid exchange)
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
curious , differentail , fluids , put , truck
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
Transmission Fluid (tricky situation) (muddy fluid) hairpin 3rd gen T4Rs 16 10-31-2020 09:25 PM
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
