04-13-2014, 11:28 PM
Real Name: Alex
Real Name: Alex
Tow Hitch Bolts
Well, I met up with
@ rinkman07
today, really nice guy, and I picked up a weight distributing tow hitch. Sadly, when he removed it, he had a lot of seized bolts on it, and broke a few. (Not baggin' on you man!) Does anyone know the size of the bolts? I've looked at what I'd think to be pertaining to this on villagetoyotaparts, as well as a bit through the FSM, and can't find what size bolts it uses! Any help would be great. Thanks.
2004 Toyota 4Runner SR5 PreRunner - A slow but steady build!
GOODϟYEAR Wrangler Silent Armors, K&N Air and Oil Filters, Borla PROXS Muffler, Mobil 1 Full Synthetic Oil, and a few other things
- Helpful DIY Videos
04-14-2014, 12:02 AM
Real Name: Leonard
Real Name: Leonard
What part, the hitch to the frame or the part that goes to the trailer?
Having fun's build
04-14-2014, 09:20 AM
Real Name: Alex
Real Name: Alex
To frame, sorry should have been clearer.
04-14-2014, 01:06 PM
Tow Hitch Bolts
Your talking the bolts that hold the hitch to the frame, right? Is so I think they were M8 or M10 x 1.25. I might have one at home and I can check tonight.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
04-14-2014, 01:20 PM
Real Name: Alex
Real Name: Alex
Thank you! Side note: this is for the weight distrib hitch not the one held up by 2 bolts.
04-14-2014, 02:40 PM
Yeah. The one from the v8. The threaded holes are already in your frame. If you have a old skid plate bolt see if it fits. Those are M8x1.25.
04-14-2014, 02:41 PM
Real Name: Leonard
Real Name: Leonard
The ones he's checking for you will be the right ones. 3 per side for after market hitches.
Not sure, but, they might be the same size as the ones holding the recovery hoop on the rear also.
You can pull one and check, just might need longer though.
Having fun's build
04-14-2014, 02:57 PM
Real Name: Alex
Real Name: Alex
I believe it's the OEM with the steel tubes. It came on his, however, being that he bought it last year and it's an '05, I'm not too sure.
04-14-2014, 03:05 PM
Real Name: Leonard
Real Name: Leonard
All the class 4 & 5 hitches bolt in the same location on the runners frame.
Did this on my 04 & 08.
Having fun's build
04-14-2014, 03:06 PM
Doesn't matter which hitch, doesn't change the pre tapped holes in the frame. 3 on each rail.
04-14-2014, 03:19 PM
Real Name: Alex
Real Name: Alex
Alright, so it's just the 3 on each rail.
@ ebg18t
, keep me posted with the bolt type, wanna go pick some up and get it on today.
04-14-2014, 03:40 PM
I don't have the tools laying around to take the bolts off at home right now, but knowing Toyota they are most likely M10x1.25 but they could also be M8x1.25; I would just grab a couple of each, one of the two sizes should fit. The Bolts that hold the rear tow hook are going to be bigger and I can't remember what size we use for those bolts as those are probably M12's
04-14-2014, 04:36 PM
Real Name: Alex
Real Name: Alex
m8/m10 is head and 1.25 is bolt diameter right? If so, what length will I need?
04-14-2014, 04:44 PM
Tow Hitch Bolts
M8 & M10 are the metric size, 1.25 is the pitch. Measure the thickness of the hitch, add a washer and the thickness of the frame so you get complete thread bite. Probably a 25-30mm will be fine. But measure it.
I won't be home till 7pm ish. If you go to ace, but a M8 and M10 x 1.25 see which fits then go back in and get the rest. Should be $0.50 each + washer
04-14-2014, 04:50 PM
Real Name: Alex
Real Name: Alex
Okay, will do. I guess I'm on my way now.
