Old 10-07-2021, 03:49 PM #1
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
tpms- 4 OR 5 SENSORS REQUIRED?
My son has after market wheels (KMC) with no sensors. I'd like to get the system to actually work. Do I need 4 or 5 sensors?
Thanks
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 10-07-2021, 05:48 PM #2
caeavesrsx-s caeavesrsx-s is offline
caeavesrsx-s is on a distinguished road
Do you have four or five wheels? The spare does have a sensor.
caeavesrsx-s is offline   Reply With QuoteReply With Quote
Old 10-07-2021, 05:56 PM #3
Real Name: Kevin
Real Name: Kevin
I do have a spare but if the system would work with only 4 sensors I wouldn't spend the $50-$60 for the spare.
Old 10-11-2021, 09:24 PM #4
YOKBB YOKBB is offline
YOKBB is on a distinguished road
From what I've read, the TPMS light will turn on if any of the 5 sensors (including spare tire) show "low" pressure (not sure what PSI it activates at). My TPMS light is on, but personally I'm planning on getting an aftermarket TPMS system that displays the pressure of each individual tire, and removing the TPMS light bulb from the dash. There are easier ways to disable the TPMS light, but I'm planning on changing the dash to LEDs so I'll be taking it apart anyway.
YOKBB is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 11:02 AM #5
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I’m curious about the answer to the OP’s question, that hasn’t been answered here yet.
If there are only 4 sensors, i.e., no spare wheel/tire, will the TPMS system work?
I’ve read about people putting a 5th sensor in a pressurized canister, but I don’t know if that would be needed in a 2003-2009 4Runner.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 08:57 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
This is not a answer to the 5th sensor question....but I would speculate that since the sensors need to be programmed into the TPMS that maybe if only 4 were programmed then it may work with just 4, but again that just a guess.
2004 Limited V8
Old 10-14-2021, 11:34 AM #7
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Thanks
I have an 08. I believe you can just use 4 sensors. Reason being is when I used an Autel TPMS tool to relearn another set of OEM sensors on my truck it asked me whether I was using a spare or not. I chose yes and proceeded to relearn all 5 sensors. I would image it would work for 4 though.
zguy1 is offline   Reply With QuoteReply With Quote
Old 10-14-2021, 03:29 PM #8
RTRSPRFTR RTRSPRFTR is offline
RTRSPRFTR is on a distinguished road
fyi oe are denso/pacific for ~$30ea. pn 550-0103
RTRSPRFTR is offline   Reply With QuoteReply With Quote
Old 10-15-2021, 12:27 AM #9
Real Name: Kevin
Real Name: Kevin
Thanks, it looks like these are for allow wheels I sure hope they fit the KMC wheels I have. I'll first try 4 and see what happens.
Thanks again
Old 10-15-2021, 01:08 AM #10
Real Name: Skip
Real Name: Skip
Thanks again
I'm not finding the Denso sensor for $30 each, but Rockauto does have them for $31.79, which pretty close.
2004 TOYOTA 4RUNNER 4.7L V8 Tire Pressure Monitoring System (TPMS) Sensor | RockAuto
Also keep in mind any new sensor will still have to be programmed after being installed.
2004 Limited V8
Old 10-15-2021, 02:59 AM #11
Thanks again
ya definitely keep us updated. when i last looked into this i was told 4th gens required 5 tpms. even putting all 0's for spare didn't work (this hack would work with 5th gens only because most years and trims except for limited just had 4 tpms). so alt was to put 5th tpms in pressurized canister or to just forget it and bypass system entirely (Write-up: How to Disable (Bypass) the TPMS)
also to program new tpms yourself as well as to perform other functions w car, def look into bootleg techstream. more info here: How-To: TechStream In 5 Minutes | IH8MUD Forum
also in case others end up exploring techstream, depending on cable you buy, after doing edits in techstream vsc trac and vsc off lights often light up. if so, you'll need to perform zero point calibration (on level ground) within techstream as well.
Old 10-18-2021, 11:10 AM #12
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
it's best to use all 5 sensors if your son rotates the spare too. it's pointless not to rotate the spare since it's alloy wheels too. you can use 4 sensors only if you want to save a few bucks.
Thanks
4r-4ever is offline   Reply With QuoteReply With Quote
Old 10-20-2021, 01:03 PM #13
randyjohnsonstl randyjohnsonstl is offline
randyjohnsonstl is on a distinguished road
Tire store said all 5 were needed, kinda happy they are as my spare kept losing air due to corrosion
randyjohnsonstl is offline   Reply With QuoteReply With Quote
kmc , sensors , system , tpms- , work
5 TPMS sensors? Sky 5th gen T4Rs 15 12-17-2019 08:49 PM
TPMS sensors DEF4Runner 4th Gen T4Rs 14 12-05-2017 10:13 PM
TPMS Sensors Geosh 4th Gen T4Rs 0 02-23-2012 12:33 PM
Tpms sensors Lakland5 For Sale: Suspension/Wheels/Tires 2 02-05-2012 11:02 PM
tpms sensors camjake2119 General Discussions 1 07-08-2011 11:20 AM
