Old 10-09-2021, 07:17 PM #1
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Napa CV Axles update (w heavy duty boots)
Just wanted to share an update on how my replacement Napa CV axles with the heavy duty boots are doing. I installed them in March and have driven about 18,000 miles since.
I just got back from a road trip and while I was doing an oil change and tire rotation, I noticed that one of my inner boots has a slight tear in it. There is some grease coming out at as well. I have to say that I am a bit disappointed that there is already an issue. I didn't expect Toyota longevity but maybe just a bit more life than 18,000 mile over 6 months.
Even though they are warrantied through Napa, I will not be replacing it at this point. I will only change it if I hear some noises or have another maintenance job which has me working near there.
I still stand by my decision to go aftermarket considering that I do not need to pay a mechanic to install or replace them. However, if you are thinking about aftermarket axles and need to pay someone to install them, then I think it is worth considering a higher quality option like CVJ.
Just my 2 cents...
zguy1 is offline   Reply With QuoteReply With Quote
Old 10-09-2021, 08:28 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Does your 18K include some offroading? I've had a NAPA CV axle on since 2015 and 45K with no problems yet, but I'm all on road.
Old 10-09-2021, 09:18 PM #3
zguy1's Avatar
zguy1's Avatar
No, nothing like that. Just some occasional dirt and gravel roads. Maybe I just got a bad one.
Old 10-10-2021, 12:29 AM #4
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
I replaced mine with A1 Cardones. I off road a lot. The boots felt and looked exactly the same as the OEM. They've been riding smooth no problems. I kept my OEM set for trail emergency. Did you keep your original set? Just reboot it.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 10-10-2021, 12:36 AM #5
zguy1's Avatar
zguy1's Avatar
The axles I replaced were aftermarket so I didn’t reboot them nor could I use them as cores for rebuilt ones from CVJ.
Old 10-11-2021, 09:51 AM #6
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Get 5th gen OEM Remans. Wish I had known about them when I did mine, but they are identical to the 4th gen CVs, but since they are reman they cost about half.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 10:08 AM #7
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
I had a small tear in one of my CV boots as well, leaking some grease and I used some of the Toyota FIPG sealant on mine and it has stopped the grease from leaking out of the boot. The FIPG stays pliable so it's holding well after nearly a year of driving on it. Probably 8-9k. Worth a shot and can't hurt.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 04:08 PM #8
MikeinNH67's Avatar
MikeinNH67's Avatar
Hmm, I may need to try this. I just noticed one of my 3 year old aftermarket shafts now has a torn boot. Blah.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 10-14-2021, 11:38 AM #9
zguy1's Avatar
zguy1's Avatar
I know the 5th gens are the same, however I didn't check for remans at the time. Where can you get those at?
Ah, good to know. May try that this time around. thanks.
Old 10-14-2021, 02:40 PM #10
McGeorge and most other online parts retailers have them. Part is 43430-60061-84.
Really wish I'd known this 2 years ago when I paid 800 for OEM new to replace the crappy parts store ones that the previous owner put on.
Old 10-14-2021, 03:42 PM #11
RTRSPRFTR RTRSPRFTR is offline
RTRSPRFTR is on a distinguished road
to add-on check online parts store of your local dealer. will be cheaper than calling in or ordering in-person. can do local pickup when ordering online for many. note there will be added $75 core charge refundable when returning old oem part.
RTRSPRFTR is offline   Reply With QuoteReply With Quote
Old 12-22-2021, 10:29 AM #12
slixx1320 slixx1320 is offline
slixx1320 is on a distinguished road
Old post but when buying remans do you need a core exchange?
slixx1320 is offline   Reply With QuoteReply With Quote
Old 12-22-2021, 11:57 AM #13
thegame7 thegame7 is offline
thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice
They charge a $75 core fee for OEM remans. You get that back when you return your old one.
Also that OEM reman part number must be the same for 5th and 4th gens. I came up with the same number when looking for the 4th gen number.
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
thegame7 is offline   Reply With QuoteReply With Quote
Old 12-22-2021, 12:52 PM #14
ggreyrunner ggreyrunner is offline
ggreyrunner is on a distinguished road
Last year when I was looking for replacement options I checked NAPA's heavy duty ones. When I pulled up the warranty, it was a Cardone warranty. It looks like that is not the case anymore. I ended up buying the Cardone's off of Amazon. They have been on a little over a year, no off roading and one has a small split in it all ready. Very disapointing. I am going to try to seal it.
ggreyrunner is offline   Reply With QuoteReply With Quote
Old 12-22-2021, 01:10 PM #15
Do they take any core in exchange or just OEM as core? I want to purchase 1 reman but don't want to give up my OEMs. I have 1 non-oem I prefer to give as core. My OEM are still good so I want to keep as a back up.
Also I noticed there are two PN. The other one is 43430-60082-84. Would this be for different years?
axles , bit , boots , install , napa
If you have used NAPA cv axles please reply NOT ME OR SOMEBODY 3rd gen T4Rs 83 09-11-2023 06:40 PM
Heavy duty CV axles...worth it? AMLOR 5th gen T4Rs 13 07-09-2021 02:12 PM
Replace Axles with OEM Boots or Extended Boots Rock_Rat 3rd gen T4Rs 79 11-10-2020 06:44 PM
Napa CV Axles Dous 3rd gen T4Rs 29 01-18-2019 11:44 PM
Looking For Heavy Duty Cv Boots spcn 4th Gen T4Rs 1 09-01-2007 10:16 AM
