Old 10-13-2021, 10:23 AM #16
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Originally Posted by Jakeepoo3 View Post
That forest looks so fun! Pick up trash if you see any. That's how I contribute to the problem. That will have a much greater affect on nature than a straight pipe!
Definitely clean up what you see... Absolutely.
But, I don't want to smell anyone's exhaust out in the woods, on the trail, or around the campsite either.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 10-13-2021, 08:02 PM #17
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Me either that's why I always go solo. I think after your project is complete and TUNED you'll know what fully combusted gas is. Most Exhaust pollution is caused by ignorant people that don't understand combustion and organic chemistry including the mechanics they trust. This bring me back to my college days. Here is the real science, all you need to know. Fully combusted. Fuel (CxHy) + oxygen (O2) + spark>water (H2O) + carbon dioxide (CO2) + heat. The product compounds are odorless. 😽 Let's put catalytic converters composing of rare earth metals on greenhouses too, tearing up the earth some more.
Tell your friends and help the problem at it's root source. No more myths to pass along.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 10-14-2021, 09:55 AM #18
Me either that's why I always go solo. I think after your project is complete and TUNED you'll know what fully combusted gas is. Most Exhaust pollution is caused by ignorant people that don't understand combustion and organic chemistry including the mechanics they trust. This bring me back to my college days. Here is the real science, all you need to know. Fully combusted. Fuel (CxHy) + oxygen (O2) + spark>water (H2O) + carbon dioxide (CO2) + heat. The product compounds are odorless. �� Let's put catalytic converters composing of rare earth metals on greenhouses too, tearing up the earth some more.
What do you mean by tuned? Other than OrangeVirus, I don't know of anyone offering real tuning for these trucks... And even then, OrangeVirus is just in beta at the moment.
Old 10-14-2021, 09:09 PM #19
Jakeepoo3's Avatar
Jakeepoo3's Avatar
There are a hundred different variables involved. The only two things that matter for tuning are timing and a/f ratio. Modern scanner like the SCT Raptor and an ACCURATE, REPEATABLE & CONSISTENT AIR FUEL RATIO DEVICE. More expensive Horiba, ECM or Powertrain Dynamics Dyno sensors are required. I'm sure you can find a good Dyno tune shop.
Old 10-15-2021, 07:59 PM #20
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
That's great, is there a specific manufacturer you'd recommend for a tuning device for the 4.7L V8?
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 06:06 PM #21
dcraddo03's Avatar
dcraddo03 dcraddo03 is offline
Real Name: Daniel
dcraddo03 is on a distinguished road
dcraddo03's Avatar
Real Name: Daniel
Sorry, I didn't mean 'meh' from you... 'Meh' info in some of the replies from others.
I initially went to Shorties from OEM (long story, but it was due to fabrication issues that I got rid of the shorties and went to LTs), and noticed it was actually quieter than the OEM manifolds.
But, I've also got the Vibrant Ultra Quiet resonator to help with the drone.
Here's a quick cold start video from right after I got it all back together: 09 4Runner V8 Long Tubes + Magnaflow Catback.
It's a tad louder/more droney in the cabin than before due to deleting the resonators in the DT y-pipe, but it's tolerable. The worst part is the drone. Nice low rumble at idle, mellow tone while driving around normally, but really opens up when you get on it.
So, to recap...
I'm looking at DT Long Tube headers with a DT y-pipe. I'll need 2 cats (looking at magnaflow 54956) to replace the resonators in the y-pipe by cutting & welding. After that I'll need O2 bung plugs & O2 bungs to weld downstream of the cats on the y-pipe.
Sounds right?
'06 Sport V8 RWD | OME 885's on Bilstein 5100's | JBA UCA's | Doug Thorley Long Tubes w/ Magnaflow Catback | Satoshi Grille Mod | Oracle Halo Kit | TRD Pro FJ Wheels | Sony XAV-AX100 w/ Rockford Fosgate 10" Punch Subwoofer | BF Goodrich KO2's (275/70/17) | 15% Tint | 282xxx miles
dcraddo03 is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 07:26 PM #22
2003V8LTD 2003V8LTD is offline
2003V8LTD will become famous soon enough
Originally Posted by dcraddo03 View Post
Currently have a CEL for low catalyst efficiency. I figured I'd go ahead and replace my cracked manifolds while I'm doing exhaust work, so I started looking back into a pair of Doug Thorley headers, which are something I've had my eye on for a long time.
I want to keep catalytic converters on both sides -- I really really don't want my truck to smell. I'm also a little unfamiliar with the exhaust system layout for my model 4Runner and can't find a helpful diagram. Will the long tube headers bolt straight to the cats (assuming I get direct-fit cats from Magnaflow or somewhere else), then the cats to the y-pipe? If not, how can I fit 2 cats into my exhaust system? Should I go for the short headers and weld universal cats to the headers?
I suppose I can run an O2 Simulator if I need to, but I won't run without any cats.
I had my RHS exhaust manifold replaced a couple weeks ago. After looking at all the options including the DT headers (hard to find, but still available in a coupla places), and in consultation with my mechanic, I just decided to get a normal genuine Toyota manifold/cat. It took about 110k miles for mine to crack, so if I get another 110k before I have to replace that one, it's not too terrible.
The mechanic asked me what I like best about the V8. I said, for sure it's the huge amount of torque available at very low rpms, like 1-2k (even on the highway, I rarely if ever see 3k rpm). He said, then stick with the OE part because while the headers would surely be more free-flowing and ultimately increase peak torque and hp, they will most likely shift the torque curve to the right. So you'd get more torque but higher up. Impossible to tell how much without a dyno, but point taken.
At any rate, the car is soooooo much quieter now, especially on startup.
2003V8LTD is offline   Reply With QuoteReply With Quote
Old 10-18-2021, 02:07 AM #23
dcraddo03's Avatar
Real Name: Daniel
dcraddo03's Avatar
Real Name: Daniel
Originally Posted by 2003V8LTD View Post
I had my RHS exhaust header replaced a couple weeks ago. After looking at all the options including the DT headers (hard to find, but still available in a coupla places), and in consultation with my mechanic, I just decided to get a normal genuine Toyota manifold/cat. It took about 110k miles for mine to crack, so if I get another 110k before I have to replace that one, it's not too terrible.
I'm sure your mechanic is right. From what I've been reading, the short tube headers = +++low-end torque. The long tubes = +++peak power (shifting the curve to the right).
With that being said, OEM parts are more expensive than they should be. I'd rather drop what I have saved on parts that won't crack, will sound better, and will ultimately save a little $$ with some extra mpg.
I understand that my 4Runner is no race machine.. I do use it to tow but it's got an excess of low-end torque that I rarely use, so I'm willing to give that up for the LT headers.
Old 10-18-2021, 09:17 AM #24
So, to recap...
Sounds right?
Yup. Here's what I used:
Plug: https://www.summitracing.com/parts/stw-o2p
O2 Bung: https://www.summitracing.com/parts/kok-9002s-c
Old 11-26-2021, 10:50 PM #25
Jrrrrr Jrrrrr is offline
Jrrrrr is on a distinguished road
Has anyone accomplished a true dual exhaust on a 2020 5th gen 4Runner?
Jrrrrr is offline   Reply With QuoteReply With Quote
cats , exhaust , headers , long , system
FS: Doug Thorley Headers 4th Gen V8 Bryan1 For Sale: T4R Items 0 03-30-2019 03:21 PM
Doug thorley headers. Slowerthanyou Classic T4Rs 4 04-21-2015 10:33 PM
