Old 10-13-2021, 10:12 PM #1
MikeinNH67's Avatar
MikeinNH67 has a spectacular aura about MikeinNH67 has a spectacular aura about MikeinNH67 has a spectacular aura about
MikeinNH67's Avatar
Replaced hatch latch assembly
So I just replaced the hatch latch assembly with the one below from Amazon. Now I finally have a working rear hatch which seems odd as it's been broken for 3 years or so. We'll see how long it lasts but the price was right to try it. I kept the old one in case something like a motor fails. Pretty easy swap.
Amazon.com: Bicos 69110-35090 69110-35062 Rear Tailgate Liftgate Lock Latch Actuator Assembly Compatible with To yota 4Runner 2003-2009 Replacement# 69110-35060 6911035090 : Automotive
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 10-14-2021, 09:11 AM #2
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
Toyota should have recalled all of them worthless motor powered hatch opening and closing devices, they were poorly designed and have caused problems from day one.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 10-15-2021, 03:59 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
It is an odd system but I'd rather have a frame that doesn't rust inside out.
Mike
03 4runner Limited
Old 10-15-2021, 04:11 PM #4
Syr4RinNC's Avatar
Syr4RinNC has a spectacular aura about Syr4RinNC has a spectacular aura about
Syr4RinNC's Avatar
regularly apply wd40 or your favorite rust prevention. similarly for the spare tire winch
2008 SR5 4WD Black. Bilstein 5100, 5th gen coils/ rear springs. 265 70 17 AT for everyday use. Victory Sliders. headunit upgrade. Back up camera install. Expert at replacement rear hatches
Old 10-15-2021, 05:06 PM #5
SurferUK SurferUK is offline
SurferUK will become famous soon enough
What happens if it fails? Is the hatch permanently open?
It does seem to be a solution to a problem that doesn't exist...I had a van with a huge tailgate and that still didn't have a motor assembly, just a catch.
2007 4.0 V6 - Jap import in the UK
SurferUK is offline   Reply With QuoteReply With Quote
Old 10-15-2021, 09:43 PM #6
MikeinNH67's Avatar
MikeinNH67's Avatar
Some seize closed and have to be forced open which I think is what the previous owner did on mine. They had it held closed with a ratchet strap. I freed up the mechanism and but a toggle switch tied straight to the motor to latch and unlatch. That does get kinda old fooling with though.
It seems to be a 3 step thing, the motor pulls the hatch in, the latch goes far enough to lock into place then the motor releases. The common issue is the 2nd step seems to fail so when the motor releases it is no longer latched and will open.
Mike
03 4runner Limited
Old 10-16-2021, 08:04 AM #7
Thanks for the info. I am amazed to see there seems to be one in the UK, I might just get it as a spare. Does this look correct? (The part I mean, sometimes descriptions aren't correct, and I wouldn't know until I had to change the old one!)
GENUINE TAILGATE LATCH LOCK MOTOR FOR 2003 - 2009 TOYOTA 4RUNNER BACK TRUNK DOOR | eBay
Old 10-16-2021, 02:59 PM #8
TLar25's Avatar
TLar25 TLar25 is offline
Real Name: Taylor
TLar25 will become famous soon enough
TLar25's Avatar
Real Name: Taylor
Mine started to malfunction a while ago and the latch wouldn't open all the way up at times, so that when I went to close it the door would slam against the closed locking mechanism and not shut. I could just open the lock with my finger and then it would close, but I sprayed some CLP all over and that has done the trick for a few months now. But thanks for the link, I've got 260k+ miles so I'm sure I'll have to replace this at some point soon.
Sent from my KB2007 using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
TLar25 is offline   Reply With QuoteReply With Quote
Old 10-16-2021, 03:33 PM #9
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
The part number is correct, (Lock Assembly, With Motor B - Toyota (69110-35090), here's a link to the latch/motor assembly for a 2007 T4R (the same for 2003 to 2009 T4Rs) from a Toyota dealership in the USA.
2003-2010 Toyota Lock Assembly, With Motor B 69110-35090 | Toyota Parts
2004 Limited V8
Old 10-16-2021, 03:52 PM #10
Cheers! I'm sure Toyota know how to design a quality electric door latch, but in this case they could learn from Lotus, "Simplify then add lightness"
Old 10-17-2021, 09:10 AM #11
I just have to wonder why Toyota Engineers and Designer's, thought buyers needed motors to latch closed their 4Runners rear hatch.
Old 10-17-2021, 11:52 AM #12
Real Name: Skip
Real Name: Skip
It's not nearly as complicated as many new rear hatches where you never touch the hatch, you push a button on the fob to open and close the hatch!!
2004 Limited V8
Old 10-18-2021, 05:25 PM #13
MikeinNH67's Avatar
MikeinNH67's Avatar
Looks correct to me. Looks like it even has the piece of string mine had that went to the manual unlock. Dunno why that is needed so I removed it as it was in the way.
Mike
03 4runner Limited
Old 10-19-2021, 06:41 AM #14
jwong1208 jwong1208 is offline
jwong1208 is on a distinguished road
if you really wanted a manual system, i tied a bunch of string against the tailgate and attached it to the manual release latch in the back of the trunk door for a few months before finally deciding to replace the latch. my typical procedure to open the hatch would be to drop the rear glass, pull the string, close the rear glass, release.
genius. ha
jwong1208 is offline   Reply With QuoteReply With Quote
Old 10-19-2021, 09:19 AM #15
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough
Real Name: Armando
Knock on wood, but my hatch has been operating without any issues for almost 17 years. I would say it is a robust system if it's been without any issues for that long.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
assembly , hatch , lasts , latch , replaced
Hatch latch. patkelly4370 General Discussions 3 11-25-2019 01:43 PM
3rd Gen Hatch latch Kryptoroxx Want to Buy/Trade 3 09-24-2018 07:48 AM
1997 hatch latch terryjh6 Want to Buy/Trade 1 11-17-2011 05:51 PM
Hatch\Latch Problem Noloc Problems & Warranty Issues 3 07-30-2005 07:28 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
