Old 10-17-2021, 12:56 PM #1
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
CV Axel Rubber keeps cracking
I went through two CV axel's in the past 1-2 years. One only lasted a year before the grease starting spraying out of the boot. Is this a common issue? Anyone know what can be done to fix these crapping "rubber" boots that are filled with grease?
meltdowner is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 07:47 PM #2
metramm metramm is offline
metramm will become famous soon enough
Are you using aftermarket axels or OEM?
I have remanned OEM's with Toyota boots from CVJ that I installed 6 years ago and they are in perfect shape still with over 100,000 miles on them.
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
metramm is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 07:50 PM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Are the ribs rubbing when driving in a straight line? Or is it from UV degradation? If the ribs are rubbing eachother you could massage the boot a little or extend the clamp possibly.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 10-17-2021, 08:10 PM #4
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
With the vehicle sitting on level ground, get under there and look at the axle angle at the inboard joint leaving the differential. Sagging suspension will have the axles angled upward significantly where they leave the tulip joint, causing the inboard rubber boot to rub against itself. The friction and abrasive dirt will cause the boot to fail more quickly than one operated at normal geometry, with spacing between the boot bellows.
waypoint is offline   Reply With QuoteReply With Quote
Old 10-18-2021, 10:53 AM #5
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
If you have any notable lift, the bellows can touch.
It's a more common problem on 3rd gens, this is a pretty good thread that talks about what to see and what to do:
Stretch your CV boots
Hope that helps.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 10-19-2021, 02:18 PM #6
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Another thing to add. When you part your car for the day make sure your wheels are straight. Less stress on the boots.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 10-20-2021, 12:54 PM #7
Mr_Dobalina Mr_Dobalina is offline
Mr_Dobalina will become famous soon enough
My dealer will only sell a complete inner and outer boot set and i think he said 170 bucks. I just need the outside one.
Is there a better brand of aftermarket boot?
Mr_Dobalina is offline   Reply With QuoteReply With Quote
Old 10-22-2021, 08:45 AM #8
waypoint's Avatar
waypoint's Avatar
I have a spare brand new outboard boot (thermoplastic) I didn't use from my kit, PM me a reasonable offer and it's yours.
Here's the Toyota boot kit including both inboard and outboard boots, grease, and clamps at $48:
2003-2009 Toyota Boot Kit 04427-60141 | McGeorge Toyota Parts
Old 10-23-2021, 11:16 AM #9
Forum148 Forum148 is offline
Forum148 is on a distinguished road
or either take the dive on new CVJ's or get CVJ replacement boots.
CVJ Axles - CV Axles & Steering Racks for all your needs
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 10-23-2021, 11:31 AM #10
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
OEM boots will last far, far longer than a year. Aftermarket? Who knows... A boot kit from the parts counter should NOT be over 100, not even over 50. I think my kit was about 30.
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 10-23-2021, 11:50 AM #11
adrian_cast adrian_cast is offline
adrian_cast is on a distinguished road
OEM or gtfo
adrian_cast is offline   Reply With QuoteReply With Quote
Old 04-23-2022, 03:12 PM #12
Kaplar Kaplar is offline
Kaplar is on a distinguished road
04427-60141 CV boot does not fit my 2004 T4R axle
I need OEM 4438-60030 kit which are 300 $ Can in Canada and almost impossible to find here. Any quality aftermarket solution that will fit this kind of axle please?
CV Axel Rubber keeps cracking-cv-axle-jpg
Kaplar is offline   Reply With QuoteReply With Quote
Old 04-23-2022, 03:46 PM #13
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
The part number you posted is an old part number that has been superseded have you tried to get the parts using an updated part number, the part number in the post you quoted is the correct up to date part number , which is..... Boot Kit - Toyota (04427-60141), just an FYI the old part number you posted is missing a number the first 5 numbers should be 04438, what you posted is missing the 0 as the first number.
2004 Limited V8
Old 04-24-2022, 09:49 AM #14
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Yeah my OEM boots are in perfect condition after 100,000. The inner joint went out before those boots.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 09:53 AM #15
Jakeepoo3's Avatar
Jakeepoo3's Avatar
You might find some bad OEMs with good boots.
boot , common , grease , issue , rubber
Car speakers cracking jman11788 3rd gen T4Rs 10 02-27-2014 01:51 PM
Dash cracking? salsabx 4th Gen T4Rs 5 01-03-2010 12:24 AM
Dash Cracking Kro781 Problems & Warranty Issues 4 05-21-2007 07:49 PM
Cracking noise behind dash WARTHOG LRV 4th Gen T4Rs 3 01-15-2007 02:19 PM
My Seat material is cracking! webshot Problems & Warranty Issues 8 05-08-2006 08:11 AM
