Old 10-17-2021, 06:54 PM #1
won4run won4run is offline
won4run is on a distinguished road
A/C Compressor cycling after recharge
I have an 04 4.7L V8 Limited with 205K.
My A/C generally cools OK, but the compressor cycles on and off frequently (5-10 seconds). Over the past couple of years, I've had to add refrigerant a couple of times to get it to cool well. I now have access to an A/C machine so I decided to recover the refrigerant and start from zero to get the right charge.
I recovered 1.50 lbs and 3 oz of oil from the car and evacuated it for 30 mins. I left vacuum on it overnight and it held, so I decided to recharge.
Per the placard, the min charge is 1.21 lbs and the max is 1.43. I put in 3 oz of PAG 46 and charged it to 1.43 lbs.
Temps are around 60F today. Static pressure is around 60 psi. When I turned on the A/C, the compressor kicked on and the high side climbed up to around 105 psi while the low side dropped to almost 10 psi before the compressor kicked out. The cycle continues indefinitely. I tried replacing the relay with no change. Thinking the pressures were too low, I added another 0.2 lbs of freon. The pressures increased, but the cycling continued.
Looking for any ideas on what to check. Right now, I recovered and evacuated the freon again.
won4run is offline   Reply With QuoteReply With Quote
Old 10-18-2021, 09:10 AM #2
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Use the sight glass on the high side. I had the same issuse and just needed to add a few more ounces. But the sight glass makes it easy.
A/C Compressor cycling after recharge-7ce43451-4b8e-42bf-b33a-deb8d96dea31-jpg
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 10-18-2021, 09:15 AM #3
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Cycling is a part of how A/C systems work...otherwise they would just build pressure indefinitely. But I gather from your post you know a little about A/C systems. 5-10 seconds sounds like short cycling. It could be from a low charge (perhaps the scale in the AC machine you used is not working properly)... I would keep adding 2 tenths of a pound until you get the low side to about 25psi and the high side at 135 on a 60* day. If it still isn't cool at those pressures, or it is still short cycling you have another issue. Here are the charts I use when diagnosing A/C systems.
A/C Compressor cycling after recharge-temp-pressure-chart-33776f1-jpg  A/C Compressor cycling after recharge-ac_diagnosis_chart-gif
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 09:07 PM #4
Thanks for the information. I ended up recharging it to the max charge level and just running it for a few days. So far it seems to be cooling ok. Maybe the cycling was a function of the temperature. After checking the charts, the pressures seem to line up. Thanks for that!
a/c , compressor , lbs , low , psi
AC cycling on and off, hot and cold peixinho 4th Gen T4Rs 45 04-14-2022 08:08 AM
AC compressor on limited cycling evey 5 seconds amir_gh 5th gen T4Rs 5 04-27-2021 12:08 PM
2006 v8 low/ cycling idle lightemup67 4th Gen T4Rs 20 03-17-2020 12:47 PM
AC Compressor is not cycling alp 3rd gen T4Rs 3 07-23-2018 08:37 PM
A/C Temperature Question - Compressor Cycling unixadm 4th Gen T4Rs 12 02-24-2018 07:28 AM
