Old 11-06-2021, 08:51 AM #16
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
I am still struggling to see how a solid rear axle could have that type of tire wear on only one tire that is properly balanced and inflated.
What about the hub or bearing at that location? Maybe there is an issue there.
zguy1 is offline   Reply With QuoteReply With Quote
Old 12-03-2021, 09:34 PM #17
elykrunner elykrunner is offline
elykrunner is on a distinguished road
They were new, balanced, and aligned tires before the last trip.
I don’t feel any wobble in any of the wheels and spinning them sounds fine. A few people have mentioned the hub, bearings. Upon research its a part people don’t really replace.
I don’t notice any obviously rear axle damage, or frame damage with my unexperienced eyes.
A friend said it could be my gears are worn out in the rear diff.
Its probably an impossible fix without anything being actually obvious. I know my shocks and struts and things are not in the greatest condition, but my 3rd gen was older and I never touched anything on it for 15 years and the tires wore out normal.
elykrunner is offline   Reply With QuoteReply With Quote
Old 12-04-2021, 01:39 PM #18
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie has a spectacular aura about Teamoatmealpie has a spectacular aura about
DIY: Transfer Case Actuator Repair
Transfer case leak - Page 12 - ClubLexus - Lexus Forum Discussion
The above to link might help with your transfer case.
Link #1 deals with a common 4th gen issue. If the 4x4 is not engaged frequently it locks up and just won't work. To fix this you have to open the actuator cover- little plastic box at the back of the transfer case. If the previous owner opened this up to get the 4x4 working again he may not have sealed the box correctly and it will leak. I had this issue as the rubber O ring on the lid didn't want to seat correctly. Took a few times taking it off before I got it positioned correctly. If you do this be prepared for gear oil to spill out, maybe 1/4-1/2 cup, also one of the gears may or may not want to slide out. Hard to tell from your pic but typically when gear oil leaks of course it sprays backward and not so much forward/onto the back of your transfer case, so the actuator cover may not be it. When mine leaked it did not get on the transfer case but only showed on the actuator box itself.
If that's the case if may be leaking from the actuator arm seal. See link #3 - it's from a Lexus forum but I believe the parts are all the same.
I would clean it all up with contact cleaner and get a better idea of locating the source of the leak.
Regarding your back tire. Just guessing, but personally I doubt any of the front end/rack or rear gears or shocks diagnosis. Your frame is bent and you already know it's been in a rear end collision. Frame shop and/or have a buddy drive behind you see it's visible. I 've see more than a few trucks going down the road visibly sideways, the rear clearly not tracking straight. Makes me wonder what their tire budget is.
Hope you get it sorted. I have 290k on mine V8 like yours owned since new and has been a reliable rig.
Teamoatmealpie is offline   Reply With QuoteReply With Quote
4runner , fast , rear , tire , wearing
Help! What damage did I do? Rear tire wear very irregular stapes4 4th Gen T4Rs 14 07-07-2020 09:12 PM
Unusual rear tire wear St Runner 3rd gen T4Rs 10 07-18-2019 08:25 PM
Cause of Rear Drivers Inner Tire Wear? flsurf 4th Gen T4Rs 0 08-07-2018 11:51 AM
What's causing my rear tire wear? Ukraine Train 4th Gen T4Rs 23 02-10-2018 01:05 AM
inside tire wear and window rear/tailagate motor mn2ndgen Classic T4Rs 5 11-09-2010 12:16 AM
