Old 10-19-2021, 12:57 PM #1
bassmacka's Avatar
bassmacka bassmacka is offline
bassmacka is on a distinguished road
bassmacka's Avatar
Steering wheel shake saga ongoing
I have had a steering wheel shake for a very long time and I was considering doing new brakes but I wanted to figure out exactly what was going on .my mechanic suggested new brake rotors in the front which I went ahead and did still very shaky when braking above 40 mph. He then suggested we do a full brake bleed and also swap the pads. Still shaking alot! He then suggested that it might be a series caliper so we went ahead and swapped the one on the left which seemed a bit tight. Still shaking. I then went and got new tires to eliminate the possibility of the unbalanced tires causing the issue.
After new tires still shaking.
At this point there's only one thing left to change on the front brakes which is the caliper on the right if this doesn't work then I'm really at a loss I don't see how shaking in the steering wheel while braking could be coming from anywhere other than the brakes in the front.
bassmacka is offline   Reply With QuoteReply With Quote
Old 10-19-2021, 05:57 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Have you checked the wheel bearings for any play?
2004 Limited V8
Old 10-19-2021, 06:26 PM #3
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Upper ball joints?
Upper control arms were the last old thing I replaced on front suspension which caused all sorts of random shakes at different speeds.
One day I leaned down and grabbed the top of the tire and pulled out and could see and feel how shot they were
gaber6 is offline   Reply With QuoteReply With Quote
Old 10-23-2021, 08:24 PM #4
2003V8LTD 2003V8LTD is offline
2003V8LTD will become famous soon enough
I had this pretty bad, and the fix was not cheap but 100% effective:
- new tires, w/wheels ultra carefully balanced
- alignment
- new axles and cv boots -- mine had totally perished and there was no grease in there
- lubed driveshafts
Car drives smooth as glass now.
2003V8LTD is offline   Reply With QuoteReply With Quote
Old 10-24-2021, 07:40 AM #5
Real Name: Skip
Real Name: Skip
- alignment
- lubed driveshafts
"new tires, w/wheels ultra carefully balanced"
Exactly how were your tires/wheel balanced, what type of balancing was used?
2004 Limited V8
Old 10-24-2021, 10:32 AM #6
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
[QUOTE=bassmacka;3682027]
At this point there's only one thing left to change /QUOTE]
Yes. Your mechanic. This guy has no clue how to go about performing diagnostic procedures, so he's just throwing parts at the problem at your expense.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 10-31-2021, 08:32 AM #7
All I know is that it was "road force balancing", whatever that means. I sought out a place that was known for meticulous work and it really did the trick. I didn't know what was up with the front suspension but to their credit it does drive like a new car now.
Old 10-31-2021, 08:47 AM #8
Real Name: Skip
Real Name: Skip
Thanks, I have a similar issue and numerous regular wheel balancing hasn't solved the issue, "Road Force Balancing" is the best and I was guessing that what they did to solve your issue, just wanted to confirm, unfortunately no one in my immediate area offered this service as it takes specialized and expensive equipment to do the job and not all garages want to make the investment, looks like I'm going to have a drive a ways to get it done.
What did you have to paid for the balancing if you don't mind saying?
2004 Limited V8
Old 10-31-2021, 01:04 PM #9
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
When you say shake and replacing all sorts of brake component’s, is your shake only when breaking ?
Replacing rotors without doing pads, especially suggested by a mechanic, is a waste of money and would potentially only make the issue worse.
I had a shake that came about when braking, my issue was a combination of worn out outer and inner tie roads and shot rotors, even though they were pretty new. I didn’t follow proper break in procedure and they didn’t last. Replaced tie rods, did an at home alignment, and replaced the pads and rotors with nice brembos and did a proper break in and no issue so far at all. And this is on 35s that proper need to be balanced after the last few off-road trip.
Always makes me mad hearing about “mechanics” just throwing parts at a problem to see what will fix it.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
front , shaking , steering , suggested , wheel
Steering wheel and car shake Duke562 5th gen T4Rs 16 10-08-2016 09:42 AM
Ongoing P0171 saga...new info...HELP! 4'running'26 3rd gen T4Rs 14 06-22-2016 07:31 AM
Steering wheel shake, need help sina518 4th Gen T4Rs 11 12-19-2012 05:46 PM
Steering Wheel Shake r3dh3ad84 4th Gen T4Rs 1 06-12-2009 02:26 AM
steering wheel shake rayny1014 3rd gen T4Rs 1 09-17-2007 09:39 PM
