Originally Posted by funkerama
If you can't tell, I'm not a car guru
Not sure if this is related to my other post: Electrical Issue? Alternator? or if this is a uniquely separate deal.
The driver's side headlight appears to be discoloring and/or burning...not sure why or how or what's up. Any thoughts or suggestions?
Link to Image: IMG_5025.JPG - Google Drive
I just looked at your photo of the headlight, I have never seen UV damage that looked like that, something else has caused that.
Did it look like that when you bought it, or did it happen after you got it?
I also would only recommend OEM replacement....BUT I would find out what caused it before risking a new OEM headlight.
I would do a little test to see if the discoloration is on the outside or the inside, try sanding a small spot with some 200/fine grit sandpaper and see it you can remove some of the discoloration, if you can than the damage is not the inside, which it would be on the inside if caused by some electrical issue from the bulb.
