Old 10-20-2021, 07:19 PM #1
tduy87 tduy87 is offline
tduy87 is on a distinguished road
Fuel Injector Cleaner Clear CEL Temporary!
Good afternoon,
My 04 4runner SR5 had a CEL code p0420 for a year now. I have replaced downstream o2 sensor, replaced spark plugs, pcv valve, cleaned MAF and throttle body. None of these fixed my CEL. However, it appeared that a bottle of fuel injector cleaner temporary clear this code and CEL will return after a week to a month. I have done this three times and the code still returns. Is my catalytic converter dead? What are my options now?
tduy87 is offline   Reply With QuoteReply With Quote
Old 10-20-2021, 09:13 PM #2
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
Originally Posted by tduy87 View Post
Good afternoon,
I had the same problem you have & tried the same things. Started around a year around last Christmas. Then I realized the p420 code came on only after I filled the gas tank. The code goes away after the fuel gauge drops to 3/4 full or less.
Still scratching my head over this one.
Hunter61 is offline   Reply With QuoteReply With Quote
Old 10-21-2021, 05:44 PM #3
Cadams84 Cadams84 is offline
Cadams84 is on a distinguished road
Any chance the gas cap may be causing this?
Cadams84 is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 03:46 PM #4
My CEL came back on again today with the same code p0420. I believe a bad gas cap will give a different code related to evaporative emissions. I have contacted a mechanic to replace the bank 1 catalytic converter. Will see if this fixes the issues.
Old 10-29-2021, 01:39 PM #5
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
I'm assuming you're clearing the code after putting in some fuel injector cleaner? Regardless, its just a temporary fix, its staying off for a while probably due to a different fuel mixture reading the O2 is seeing with the cleaner mixed in.
Yes, more than likely your cat is clogged/dying/dead. You could try and run some cat cleaner (don't have any links but saw some people mention it previously) but that is more than likely a waste of time an money too.
You have 3 options as far as I'm concerned, ranging from free to very expensive.
1. Option 1 -Free (for off road use only ;) ) : since P0420 is only for the second bank, you can get some wire and tap into the signal of the Bank #1 O2 sensor. This will feed the same reading from bank 1 to bank 2. I've run this fix for quite some time this year with 0 issues.
2. Option 2 - $12 (for off road use only ;) ) : this is my current fix and has worked so far like a charm. I can't claim this fix as my own as its been done time and time again and I found previous pages with this fix. Buy yourself some Doorman spark plug non foulers and drill them out with a 1/2" drill bit to screw the 02 sensor into it before placing it back on the car. This effectively spaces the O2 sensor out of the exhaust stream just a bit and reduces the reading it puts out. I started by stacking 2 of the adapters but that put it too far out and it wasn't picking up enough of a reading and threw a code. I removed one adapter and have been driving for 4 weeks now with all system initialized with 0 issues. Spark Plug Non-Fouler Dorman 42009
If you scroll through page 17 on my build thread you'll see what I'm talking about : aemravan's build thread - project TacoRunner
3. Option 3 - An Arm and a Leg (only CORRECT street legal fix) - replace the cats.
aemravan is offline   Reply With QuoteReply With Quote
cel , code , fuel , injector , replaced
Locus fuel injector cleaner? brillo_76 Polls 6 12-09-2019 10:45 PM
Fuel Injector Hose leak - best temporary fix btruong25 4th Gen T4Rs 5 02-25-2016 05:11 PM
My 2000 4 cylinder is getting bad gas mileage....fuel injector cleaner a good idea?? lance317 3rd gen T4Rs 4 07-27-2013 01:17 AM
Fuel injector cleaner spongerx 3rd gen T4Rs 3 05-31-2008 12:54 PM
fuel injector cleaner on 1992 3.0 cdmasm Classic T4Rs 4 03-29-2006 12:26 PM
