Old 10-25-2021, 11:39 PM #1
sk8pastu sk8pastu is offline
sk8pastu is on a distinguished road
08 Ltd 4X 18 inch rims or 17 inch?
Guys, I just bought a 2008 V8 Limited 4X4. I am going to put on some new wheels and rubber. Do you have any opinion on whether to use 17s or 18s on a limited? I know they come stock with 18s. any advantages or disadvntages? Thanks!
sk8pastu is offline   Reply With QuoteReply With Quote
Old 10-26-2021, 02:17 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
So would be helpful to have an idea what you plan to do and are hoping for tire wise. I like the 18 inch options of the 265 70 18 tires or 275 70 18 personally.
Old 10-26-2021, 06:31 PM #3
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
For something that might see any off-road use, I prefer the smallest rim that will clear the calipers. Leaves more room for sidewall.
For street use, it doesn't matter, your preference.
Old 10-27-2021, 10:16 AM #4
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
As others have mentioned, it'd be good to know what you use the truck for. If your wife drives it to get groceries and to work, putting 18's and LT tires isn't a great option.
17's will be the best "truck" tire, generally speaking. More compliance to road handling and better offroad due to more sidewall flex available.
18's will make the truck feel more responsive onroad... but bumps that the 17's would remove will rattle the occupants around a bit. Depends on a lot of variables of course, like suspension / sway bars, tire type, etc. Generally speaking, the 18's will make you feel closer to the road, for all that's good and bad about that.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 10-27-2021, 12:17 PM #5
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
I'm on 275/65/18 XL Ridge Grapplers and love them. (This size also requires a lift.)
Shopped around, and it was about the lightest tire I could find in the approximate similar sizes. I started on the OEM 18's, and it felt a bit sloppy when responding to steering input.
I found a deal on some 18x9, which straightened out the sidewalls and it's a lot better.
Yeah, they're not a comfortable offroad as 17s would have been but I'm not doing anything hardcore. Air them down to 15-18 and it really helps offroad.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
17s , 18s , inch , limited , opinion
Cornfed 2 inch front and 1 inch rear kit Raleigh, NC 150.00 jpaws For Sale: Suspension/Wheels/Tires 4 12-31-2018 12:29 PM
Stacking toytec 1/2 inch and 1/4 inch spacers: ideas for top plate studs ? mikeng 4th Gen T4Rs 4 06-08-2014 07:13 PM
WTB.. 2 inch or 2.5 inch Used/New rear coil spacers 90-94 4runner borninabarn For Sale: Suspension/Wheels/Tires 2 06-27-2013 10:26 PM
One inch leveling lift using ½ inch spacer (Pics) Even Steven Off-Roading 22 05-25-2008 01:02 PM
