Old 10-28-2021, 07:58 PM #1
imschur's Avatar
imschur imschur is offline
imschur is on a distinguished road
imschur's Avatar
Stiff Steering with a Difference
Hello,
My girl has a 2007 4Runner Sport with 177k miles. Two weeks ago she mentioned her steering felt "a little stiff". Initially, I thought it was in her head because we had just returned from vacation which included her driving my 2018 Jeep JKU for the week.
Out of curiosity, I decided to take the 4Runner for a ride. Three things quickly became apparent:
  1. OMG was she understating the "stiffness'
  2. Vehicle is scary to drive
  3. She's much stronger than me
Off to our favorite mechanic we went. A week and nearly $4k later the vehicle is different, somewhat less stiff but definitely not right.
So far we have had the following work performed:
  1. Changed the power steering fluid
  2. Replaced the power steering pump
  3. Replaced the rack
  4. New tires & alignment
I read other threads on the site, watched the YouTube videos but we have one different scenario. The vehicle feels normal when we drive in the rain. I'm guessing that water is lubricating something that's ready to fail.
Opinions?
Thanks in advance
drew
imschur is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 08:10 PM #2
214RUNNER's Avatar
214RUNNER 214RUNNER is offline
Location: THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
214RUNNER is on a distinguished road
214RUNNER's Avatar
Did you do a suspension check? The upper & lower ball joints & tie rod ends, steering shaft joints wheel bearings for binding.
214RUNNER is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 08:16 PM #3
camion camion is offline
camion is on a distinguished road
Steering wheel got stiff on our 2007 with 216K miles. Was fully fixed and back to normal by changing the one shaft with a universal joint. It connects the steering wheel to the steering rack. This thing gets rusty. Lubrication helps temporarily. The part was about $230 and it was more labor because the rust made it so much more difficult. In any case, all was good after $650 total. I'm surprised that was not the first thing they replaced.
camion is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 08:35 PM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by imschur View Post
Hello,
Opinions?
Thanks in advance
drew
Originally Posted by 214RUNNER View Post
Did you do a suspension check? The upper & lower ball joints & tie rod ends steering shaft joints wheel bearings for binding.
Seeing that you're from the "snow/salt on the road rust belt" I also think it very well could be the intermediate steering shaft, as a simple test look under the hood on the driver's side of the engine, follow the steering shaft from the firewall down towards the rack and pinion assembly until you see a 4-way bearing/U-joint, spray it well with some good penetrating oil/spray then take it for a test drive and see if that loosens up the steering, if so now you know the culprit, the penetrating spray will only be temporary, next step to fix it is to replace the intermediate steering shaft.
This is a common failure after many miles in the rust belt, I too am surprised your "mechanic" didn't check it first instead of throwing several thousand dollars worth of parts at it!!
2004 Limited V8
Old 10-28-2021, 09:56 PM #5
imschur's Avatar
imschur's Avatar
Thank you for the replies. The mechanic might have checked the ball joints & tie rod ends and didn't mention it. I'm going to verify. I will also share the info listed here. The vehicle steering normally in the wet had me scratching my head a bit.
Most parts that face the pavement are quite corroded. My tundra frame quit with much less lol. Often in my town, the road salt is deeper than the snow.
Thanks again
Old 10-28-2021, 10:07 PM #6
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
The fluid surely isn't what's causing what you described but just want to be sure you know the 4th Gen 4Runner doesn't use power steering fluid in the system, it requires Dexron type ATF. That surprises many people, including me when I bought my truck in 2014.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 10-29-2021, 06:53 AM #7
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
What is wrong with my steering?
Steering Column U-Joint
2005 4Runner Stiff Steering - Toyota 4Runner Forum - Largest 4Runner Forum
https://www.youtube.com/watch?v=bqPF_SNueyg
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 10-29-2021, 07:56 AM #8
That Youtube video posted by @Bossman above is a very good one to watch.
Gives you a clear idea of what the problem is and a sense of how much of a pain it can be to remove it. That's why when my mechanic charged me more than he originally estimated the job at I fully understood and gladly paid him.
In theory it's straight forward but in practice a pain.
Old 10-29-2021, 12:56 PM #9
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Hello,
Opinions?
Thanks in advance
drew
It's disappointing to see that he had the rack out and did not inspect/replace the intermediate steering shaft.
As others have already mentioned, this is generally the issue for stiff steering. Replacing mine turned the 4Runner from driving a bulldozer to driving a sedan.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 10-29-2021, 01:28 PM #10
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
+1 on the above.. that's a really big shame.. sure was nice of the mechanic to start with the most expensive parts first but sounds like he was just checking off component items related to the steering system.. good thing is at least you know have a brand new pump and rack to hopefully last you the remaining lifetime of the vehicle once you get the intermediate shaft replaced.
aemravan is offline   Reply With QuoteReply With Quote
Old 10-29-2021, 04:22 PM #11
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
I have a suggestion that I have mentioned in other posts. If you have a grease gun, get a needle fitting. It looks like a needle that goes in your arm but it's for grease. Our 4runners do not have greasable fittings on the front end. Insert the needle in the boot of any of the tie rods or ball joints and pump until grease comes out.
Makes a world of difference. Fitting is about 3-5.00.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 10-30-2021, 08:55 PM #12
imschur's Avatar
imschur's Avatar
I verified with the mechanic, says he did check the steering shaft. The 4Runner is going back to the shop Tuesday. I'm going to request he replace the steering shaft regardless. Sounds like if by some chance it's not the problem it will be soon. I do believe it is the problem though. Tomorrow I'll grease the other components just for sport.
Thanks for all the helpful advice.
Old 10-31-2021, 08:42 AM #13
2003V8LTD 2003V8LTD is offline
2003V8LTD will become famous soon enough
I had a similar symptom and I had the lower intermediate steering shaft replaced. The U-joint gets rusted and swollen and very hard to turn. I shopped around; the cheapest I could find the genuine Toyota part (45203-35310) for was $145. Chinese ones are far less costly, but query the quality. It's not a particularly complicated job for a mechanic to do except that it's apparently a bear to get the splined slip fittings separated on the old one. Steering is so, so much smoother now.
I don't know if this would help in your case but apparently it's a very common malady in 4th-gen cars.
Hello,
Opinions?
Thanks in advance
drew
2003V8LTD is offline   Reply With QuoteReply With Quote
Old 09-21-2022, 01:53 PM #14
twa318 twa318 is offline
twa318 is on a distinguished road
Another success story replacing the intermediate shaft & yoke.
My steering had been stiff for the last year or so, I had been putting off replacing it since it was a minor annoyance but it was getting to the point where it almost felt like I didn't have power steering.
First step was to do a power steering fluid flush (with ATX fluid, not PS fluid as per the manual) and that didn't help.
After replacing the intermediate shaft it felt like new again. I didnt realize just how bad/stiff the steering had become until after it was replaced, now I'm kicking myself for not repairing it years ago.
'99 SR5, 2007 Sport
twa318 is offline   Reply With QuoteReply With Quote
Old 09-21-2022, 02:17 PM #15
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
That's almost a dead giveaway that it's the steering shaft and joint. When it gets wet, the water lubricates it, and then it works (sort of) normally.
You might want to consider changing mechanics.
Too Stroked is offline   Reply With QuoteReply With Quote
power , steering , stiff , vehicle , week
Stiff Steering t4rFL 3rd gen T4Rs 23 01-07-2019 11:18 PM
Stiff steering anonymousgromers 4th Gen T4Rs 5 12-14-2018 02:09 PM
Stiff steering drallan 3rd gen T4Rs 9 07-10-2015 01:29 PM
Stiff Steering. BunchDub11 4th Gen T4Rs 6 12-01-2014 07:25 PM
Replace u-joint on steering linkage to fix stiff steering? sibanez 4th Gen T4Rs 2 09-30-2014 08:28 AM
