Old 10-29-2021, 08:11 AM #1
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Air recirc defaults to ON
I'm not sure if this just a peculiarity of a JDM vehicle, but does anyone know if there is a combination of buttons, or a setting in the Toyota diagnostics software, to turn off air re-circulation unless I manually press the button?
With LO temp selected it defaults every time the ignition is switched on.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 10-29-2021, 08:22 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
My '03 Limited does the same.
Old 10-29-2021, 08:57 AM #3
SurferUK's Avatar
SurferUK's Avatar
It would make sense if the air con was on, but it's just daft otherwise! If I forget to turn it off, the windows start steaming up.
Old 10-29-2021, 10:37 AM #4
Spacecadetcharlie Spacecadetcharlie is offline
Spacecadetcharlie is on a distinguished road
Am also curious... my '07 Sport does the same and I would like to change it if possible.
I had a VW that did this as well. It is just plain irritating. I don't need my hand held.
Spacecadetcharlie is offline   Reply With QuoteReply With Quote
Old 10-30-2021, 12:00 PM #5
SurferUK's Avatar
SurferUK's Avatar
Well I got my laptop out and hooked it up to Techstream...nothing available under customisation for Air Conditioner, and it doesn't seem to think there are any AC ECUs, so that's that!
Might have to go old school and just...unplug the flap motor!
Old 10-30-2021, 02:40 PM #6
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
It is normal operation, there are a ton of threads about this. Both Toyota and Lexus cars/suvs/etc do this. The computer reads the humidity level in the cabin and adjusts (open/closes) the recirc door accordingly to best maintain the temperature inside. If you don't like it, just press the recirc button. No techstream or nonsense required.
CookieRoe is offline   Reply With QuoteReply With Quote
Old 10-31-2021, 09:55 PM #7
Cookie, I appreciate the explanation but of course the point is that this is both irritating and unnecessary.
The question is whether this is modifiable to *default* to not automatically turning itself on. I want all functions of my air system to be managed manually. That’s my personal preference.
Old 11-01-2021, 10:31 AM #8
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Surfer, my '08 SR5 (United States) won't default to recirc on start-up provided that both of these conditions are met:
AC on/off switch is off when engine shuts down
Recirc is off when engine shuts down
Secondary method:
If defrost is selected, the recirc function is off and is not even available for manual selection.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 11-01-2021, 10:54 AM #9
SurferUK's Avatar
SurferUK's Avatar
Secondary method:
That's interesting - I've ruled out the first two already as I don't use AC as a matter of course, don't really need to over here in autumn, but I'll try leaving it set to windscreen and see if that stops it defaulting.
Thanks!
air , defaults , manually , software , time
A/C only works on recirc rfuree11 4th Gen T4Rs 3 08-12-2016 09:18 PM
recirc defaults to outside air cbreze 5th gen T4Rs 4 12-04-2013 10:23 PM
Problem with climate control - It sometimes defaults to AUTO CZ Eddie 3rd gen T4Rs 6 03-10-2010 10:53 AM
Recirc Air Button rockwall 4th Gen T4Rs 14 06-23-2008 11:04 AM
Temp Low=Automatic Recirc On Mafster 4th Gen T4Rs 15 06-26-2007 02:35 AM
