10-31-2021, 10:55 PM
Integrated key remotes?
Guys, do they make any keys with integrated remotes, like zillions of other cars have? I get a little irritated having the separate key and remote. I wish it was like my old Subaru where the remote buttons are the head of the key itself. Does such a thing exist for our cars?
11-12-2021, 11:22 AM
The above listing is the same key I used. I programmed it myself and got the key cut at a locksmith. Everything works. The rear hatch button rolls the window down.
11-12-2021, 12:50 PM
It's good to hear that it worked for you. I'm thinking of buying one as well and ditching the old remote.
11-13-2021, 10:15 AM
the switchblade keys will stick out alot.
i gave that up and use another key remote combo, aslong the remote was compatible with the stock keyless, i had to take apart the switch blade remote and use that transponder chip to the combo. it works, sometimes i dont need to use my full alarm system. it still roll the window down.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
11-13-2021, 01:47 PM
Here is a picture.
11-13-2021, 07:54 PM
Real Name: Taylor
Real Name: Taylor
I have a switchblade style that I programmed myself as well. I like it way better. Sure it sticks out more than the factory key but it's not in the way of anything.
Sent from my KB2007 using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
11-15-2021, 11:08 AM
+1
It does stick out but it's out of the way and no bother at all.
It feels heavy and good quality.
One thing though is it's very easy to keep hitting that panic button by accident. I ended up opening it up and removing the little switch/button on the inside thus eliminating the issue altogether.
11-16-2021, 05:48 PM
Can you use the rear hatch button to open the rear window?
11-17-2021, 02:46 PM
this one doesn't have the aux button, it's just a blank spot w/no button. but I wasn't too concerned with that. I just wanted an extra key that I could use when wheeling that wouldn't have the extra fob swinging around knocking on the dash, haha. #firstworldproblems
J.
05 v8 Sport - K&N air filter - Toytec Ultimate front + OME 3" rear - JBA HD UCAs - Spydertrax spacers - 35" Kenati Trail Hogs - Vors v37s
11-17-2021, 08:09 PM
fair enough! I wonder if the other key fobs can be used for the rear window. But to be fair, I don't use the key fob to lower the rear window that often anyways. Mostly just to show others that I have the ability to do so!
11-18-2021, 11:14 PM
Real Name: Taylor
Real Name: Taylor
This one works perfectly on my 2003 limited. Home Depot cut the key for free, I programmed myself with the door open close/lock unlock method that can be found here on the forum. The panic button is pretty solid and I think I've maybe set it off only once or twice and I've had it for almost two years now. Oh and the tailgate button rolls down the rear window too.
Upgraded FLIP KEY REMOTE FOR TOYOTA HYQ12BBX DOT CHIP KEYLESS ENTRY ALARM FOB | eBay
I also got these stickers for it that complete the look:
NEW TOYOTA 2pcs 14mm Key Fob Emblem 3M Sticker Decal Logo Remote Badge FREE SHIP | eBay
Sent from my Pixel 3 XL using Tapatalk
