Old 11-10-2021, 10:00 PM #16
Runnin on E Runnin on E is offline
Runnin on E is on a distinguished road
Axles
Originally Posted by tuborg_15 View Post
Get your front axles checked too. I was experiencing the same issue in my 2004 4runner and couldn't figure it out. Finally found out that my axles were worn and they had a lot of play in them. Got those changed and that wandering feeling is gone now.
Don't do this. Do the steering rack adjust as explained above. FFS axles were worn?
Runnin on E is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 12:04 AM #17
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
Originally Posted by weaves View Post
To do it properly, you'll probably want to remove the steering rack because there's not a lot of room underneath there. The service manual says to back out the 24mm hex guide cap until the guide spring pressure is completely relieved. Then tighten the cap until it takes 6.2 - 13.3 in/lb of force to turn the splined shaft on the rack that connects to the steering shaft. I didn't want to go through removing the rack again so I just kind of winged it by feel.
Before you turn the guide cap, mark the current position of the cap to the body of the rack so you have a frame of reference.
Remove the outer lock nut with a pair of large channel locks or a large crescent wrench. Use a 24mm hex bit socket to turn the cap approximately 15-20 degrees (~1/16th turn). I didn't have a 24mm hex bit socket so I just used the head of a 24mm bolt I had laying around to turn the cap using vice grips. A 5/8" rod coupling nut from Home Depot will also fit and you can use a wrench to turn it.
It doesn't take much to bind the steering rack so make very small adjustments at a time. If the steering wheel doesn't return to center after you turn, then your preload is too tight. It took me about 3 tries to find the sweet spot.
Very interesting. I also just found a video by Timmy the Toolman replacing this guide on a 3rd gen. I've had the same steering issues. Figured I need new UCA's. I probably still do (I get about 2.x degrees caster when it gets aligned) but at 260k miles, I feel it's likely that there is wear in the rack. Seems like an easy/cheap fix to try first. My question is why not just try to tighten it a little bit? Rather than loosen per the FSM procedure... Or is that how you approached it, and I read your post wrong? I see where the 3rd gens had a procedure where the guide cap gets tightened to 18 ft. lbs, then back off 19 degrees.
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
4runner , caster , great , improvement , steering
RPMs at highway speeds? gloch 4th Gen T4Rs 12 01-11-2020 09:34 PM
Loose steering at highway speeds? dcTR4 4th Gen T4Rs 33 12-24-2018 05:23 PM
Please help! bucking at highway speeds Dagobah 3rd gen T4Rs 53 10-28-2017 11:50 PM
Highway speeds tstx92 4th Gen T4Rs 8 09-26-2017 10:17 AM
