Old 11-02-2021, 01:22 PM #1
Bill Meyer Bill Meyer is offline
Bill Meyer is on a distinguished road
Wandering steering at highway speeds, more Caster?
So I've been fighting this for years now on my 06. Steering isn't terrible, but on long cross country trips it's just tiring, the constant corrections, it just doesn't center well. .. and it wind, forget about it, my wife won't even take a turn at the wheel going across windy Kansas.
We're at 105K miles, but this has been an issue since we got it at 40K. The only thing that helped a bit was having an alignment tech specifically dial in 1/8th toe in for the front and close to max caster at 3.8. That was maybe a 50% improvement, but it's still not great. For comparison, my 98 4runner was a perfect travel companion, tracked great.
I see aftermarket upper control arms that increase caster, meant for lifted vehicles.. wondering if I could fit these and go beyond factory specs, to say like 5?
Not sure what else to look at.. somebody suggested maybe firmer springs/shocks could help.
Bill Meyer is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 02:58 PM #2
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Yes, more positive caster.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 03:15 PM #3
GBagwell's Avatar
GBagwell GBagwell is offline
GBagwell will become famous soon enough GBagwell will become famous soon enough
GBagwell's Avatar
I would also ask what wheels you are running. And tire size. If the wheel offset is different than factory it can effect the Steering Axis Inclination. That will induce bump steer as well as require more correction input when dealing with wind and stuff.
86 4Runner, 91 4Runner, 97 4Runner Limited, 2003 4Runner V8 4x4 Limited (current ride - Original Owner)
GBagwell is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 03:41 PM #4
Truck is totally stock, so 17's.
I've always wondered if the soft suspension of the 06 is to blame, my 98 was much firmer. Seems the front geometry and parts and fairly similar between the two, so..
Old 11-02-2021, 03:47 PM #5
GBagwell's Avatar
GBagwell's Avatar
And you verified no worn out tie rod ends or ball joints etc. ?
Old 11-02-2021, 04:42 PM #6
Yes, steering is very tight. Latest alignment specific shop checked everything closely, said it was good. This was a problem when near new.. I guess I wouldn't say a problem, just not a great driver. Love the truck, so looking to see if others have dealt with it.
I'm starting to wonder if it's just inherent in the Gen 4's, so starting to think out side the box a bit, with maybe aftermarket solutions. More caster and a firmer set of shocks/springs.
Old 11-02-2021, 06:26 PM #7
chompster4runner chompster4runner is offline
chompster4runner will become famous soon enough
Mine is lifted but for years I chased this problem and threw everything at it including adjustable uppers with 4.5 casters. Not much changed. What made a drastic difference was tires. I had KO2s at that time and then replaced with general grabbers atx. 99% highway wandering and darting are gone.
2022 Toyota 4Runner TRD OFF ROAD PREMIUM
chompster4runner is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 01:52 PM #8
Interesting. I've had Firestone destination LE's on it the entire time, was going to try AT next.
Old 11-03-2021, 06:36 PM #9
weaves weaves is offline
weaves is on a distinguished road
I've been dealing with this for as long as I've owned my 4runner. I tried multiple alignment settings including maxing out the caster which had very little impact on the wandering. I replaced the steering rack (reman) which saw the greatest improvement but it was still difficult to drive in windy conditions. I ended up adjusting the pre-load (tightened) on the steering rack and that solved the issue completely.
weaves is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 07:01 PM #10
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
K02's. Truck wandered badly
unrelated issue was a bad wheelbearing, had that replaced.
Shop inspected the suspension & alignment, found no issues.
It occurred to me while driving down the highway that it's the rack bushings. I had a friend sit in the driver's seat while parked and work the steering wheel back and forth. The rack moves without the wheels. Obviously this was the problem.
It left me wondering what the shop inspected... Destination Toyota put in a new rack (and intermediate steering shaft and high pressure hose)
Regardless, your problem is probably in the rack not the alignment/suspension, per weaves comment above.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 11:09 PM #11
Please explain the process of tightening the pre load. Heard about this but didn’t want to mess with it. Wandering definitely 99% gone. Occasionally, strong winds will push it around.
Old 11-04-2021, 02:27 PM #12
To do it properly, you'll probably want to remove the steering rack because there's not a lot of room underneath there. The service manual says to back out the 24mm hex guide cap until the guide spring pressure is completely relieved. Then tighten the cap until it takes 6.2 - 13.3 in/lb of force to turn the splined shaft on the rack that connects to the steering shaft. I didn't want to go through removing the rack again so I just kind of winged it by feel.
Before you turn the guide cap, mark the current position of the cap to the body of the rack so you have a frame of reference.
Remove the outer lock nut with a pair of large channel locks or a large crescent wrench. Use a 24mm hex bit socket to turn the cap approximately 15-20 degrees (~1/16th turn). I didn't have a 24mm hex bit socket so I just used the head of a 24mm bolt I had laying around to turn the cap using vice grips. A 5/8" rod coupling nut from Home Depot will also fit and you can use a wrench to turn it.
It doesn't take much to bind the steering rack so make very small adjustments at a time. If the steering wheel doesn't return to center after you turn, then your preload is too tight. It took me about 3 tries to find the sweet spot.
Wandering steering at highway speeds, more Caster?-4th-gen-rack-jpg
Old 11-04-2021, 02:35 PM #13
Mr_Dobalina Mr_Dobalina is offline
Mr_Dobalina will become famous soon enough
I used to hate driving my wife's 07 as I experienced the same wandering as you describe.
I don't know what tires we took off of it, but I do know that we bought Michelin Defender LX M/S and the problem instantly went away.
Timely post, as I just bought/installed a new identical set yesterday.
Also, the only good thing about Mavis Tires is they will price match. I was looking online and I found a set of 4 for about a 100 bucks less than they were priced at.
You have the option to have them price match online. They ask you for the website and price. I had someone call me back in about 4 minutes telling me they would match the price.
Mr_Dobalina is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 05:16 PM #14
tuborg_15's Avatar
tuborg_15 tuborg_15 is offline
tuborg_15 is on a distinguished road
tuborg_15's Avatar
Get your front axles checked too. I was experiencing the same issue in my 2004 4runner and couldn't figure it out. Finally found out that my axles were worn and they had a lot of play in them. Got those changed and that wandering feeling is gone now.
tuborg_15 is offline   Reply With QuoteReply With Quote
Old 11-10-2021, 06:45 PM #15
Good to know. My CV boot on one side is cracked now, so maybe..
4runner , caster , great , improvement , steering
RPMs at highway speeds? gloch 4th Gen T4Rs 12 01-11-2020 09:34 PM
Loose steering at highway speeds? dcTR4 4th Gen T4Rs 33 12-24-2018 05:23 PM
Please help! bucking at highway speeds Dagobah 3rd gen T4Rs 53 10-28-2017 11:50 PM
Highway speeds tstx92 4th Gen T4Rs 8 09-26-2017 10:17 AM
