Old 11-04-2021, 11:05 AM #1
hawee99 hawee99 is offline
hawee99 is on a distinguished road
Just about to start installing lift
Hello,
I'm starting to second guess myself.
My plan is/was to install 5100 in front at the 2.5 setting. And reuse the stock coils. They only have 40k on them.
I will also install 5100 on the rear and add the 895e OME coils that say will add 1"
I have TRD pro wheels on the way. 17x7 with +4 and plan to mount 255/75 duratracs on them.
Does all this sound ok?
Main questions before I start the work are...
Is it ok to reuse the stock springs up front?
Is the 2.5 setting going to be ok with adding the one inch spring in the rear
Id just like some reassurance before I start
Thank you
hawee99 is offline   Reply With QuoteReply With Quote
Old 11-04-2021, 07:51 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
So you’ll likely get a 2.5/1 lift give or take which will put at level or slightly lower I. The rear. If you ever have some weight in the trunk or tow your back end will sag.
For that reason I’d go with 1.75 up front
You should be easily from stock 5th gen for free / cheap if you want to replace the front end coils. I reused mine for a year, the rear was bad towing but otherwise was ok
Old 11-05-2021, 10:37 AM #3
Finest Finest is offline
Finest is on a distinguished road
2.5" in the front will end up leveling with the 895e in the rear, if not give some negative rake with extra load in the rear or towing. I also advise on 1.75 up front. It also takes some time to settle, so the front will be most likely be higher for a few hundred miles.
Finest is offline   Reply With QuoteReply With Quote
Old 11-06-2021, 12:21 AM #4
I got the fronts installed today and it seems like I've gained 3".
I think I understand that excess can be due to the potential sagging OEM parts. I'll get the rear done tomorrow and asses.
Thank you for your response
also, I did the no compress method. Easy peazy
Old 11-06-2021, 06:54 PM #5
Complete.
I think it sits pretty good. Might be kind of hard to tell because the driveway is a bit angled, but I don't think the front is up too high
what do y'all think
Old 11-07-2021, 06:24 PM #6
timbird1219's Avatar
timbird1219 timbird1219 is offline
Real Name: Tim
timbird1219 is on a distinguished road
Real Name: Tim
Originally Posted by hawee99 View Post
Hello,
Thank you
Ya you should be all good I did 5100s on the front and rear but used newer 5th gen coils I got for cheap. It leveled mine out really well the extra inch on the rear should keep your rear a little higher than the front which will help better when towing. If you want to just make it level I’d suggest just keeping the stock coils.
timbird1219 is offline   Reply With QuoteReply With Quote
Old 11-07-2021, 07:20 PM #7
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
I used the 1.75 setting on mine, with a 1.5 spacer on the rear. I used FJ springs. I guess 5th gen springs work well, but also Tacoma springs for the front should work too depending on how easy it is to source parts.
FYI, I regularly get in the 2 degree range on the caster setting. I would think at the 2.5 setting you're pushing the caster with stock UCA's... I'm planning on getting some JBA's to get it back into the best spec. The 2-ish degree caster is noticeably touchy on the highway. With the 2.5 setting I'd guess new UCA's are a definite must have.
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 11-07-2021, 09:03 PM #8
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Congrats on getting it done
coils , rear , reuse , setting , start
Engine won't start after installing K&N Intake danhtx92 Classic T4Rs 9 12-15-2015 07:35 PM
Questions and help installing a viper remote start security system cleger 4th Gen T4Rs 10 06-24-2013 09:15 AM
How much $$$ should installing a car alarm/remote start system cost? trdrun 3rd gen T4Rs 11 05-31-2010 12:42 PM
installing remote start...have question dnbprofessor 3rd gen T4Rs 3 03-13-2010 01:26 PM
Installing a Remote Start on a '99 Toyota 4Runner maverick906 3rd gen T4Rs 22 11-16-2009 09:23 PM
