Old 11-08-2021, 03:27 PM #1
E=mc^SQD E=mc^SQD is offline
E=mc^SQD is on a distinguished road
Question Bilstein v. XREAS - error codes AND no warranty
Reading all herein, and calling Bilstein/Kalifornia to ask if their 4600 and 5100 shocks will work on my 04 4r XREAS, they say they will NOT warranty their shock on my truck, AND that I will get dash error codes after install if the XREAS hydraulic lines are not connected to anything.
HOW are people within this forum installing these aftermarket shocks (Bilsteins, OMEs, etc.) on XREAS 4rs and not having these problems, especially NO error codes?
E=mc^SQD is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 03:52 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Toyota 4-Runner X-REAS Shocks - Shockwarehouse.com
https://www.shockwarehouse.com/news/...structions.pdf
What is Xreas exactly?
Best Replacement Shocks when removing the XREAS? - Toyota 4Runner Forum - Largest 4Runner Forum
XREAS Replacement Advice
XREAS Replacement Suggestions
XREAS Replacement
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 03:52 PM #3
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
My understanding is that the X-REAS system is totally mechanical/hydraulic. There is nothing that could set a code.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 05:48 PM #4
shootersanks shootersanks is offline
shootersanks is on a distinguished road
I installed bilstein 5100 on the front and rear of my 07 with XREAS and there are no error codes showing at all. The system is hydraulic with no electrical. Whoever you talked to was mistaken.
Shootersanks
-2007 Shadow Mica SE 4Runner
shootersanks is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 06:38 PM #5
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
Maybe they're thinking of the RAS which will throw a code if the system is gutted.
I went with the high-tech solution for the flashing light; cut out a piece of the packaging from the brake light bulb I had to replace to stick over the lights on the dash. Got the warning light for the TPMS with it too.
One day I'll get around to fixing the wiring so the lights shut off... one day...
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 09:20 PM #6
dasx86 dasx86 is offline
dasx86 is on a distinguished road
My 2005 had XREAS, no rear air suspension. There's no electrical component to any of it. I ripped it all out and installed Dobinsons all the way around. All good
2005 Limited V8 4x4
dasx86 is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 09:48 PM #7
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
Whoever you talked has no clue. Period. Unless you have factory rear air suspension, then yes, you might throw a code. If your truck doesn't have it, then no worries, go ahead and get the billies.
I'm waiting for my XREAS to go and would like to replace them, but I'll most likely get OEM shocks for them (billies are too stiff for me and I hear from many that KYB shocks are stiff as well).
Good luck
CookieRoe is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 09:17 AM #8
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
@E=mc^SQD , Bilstein gave you incorrect information. The "X-REAS delete..." post linked in my sig should be helpful as it has detailed instructions for taking off your X-REAS and a link to the Toyota manual pages covering its removal.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 11:34 AM #9
Spacecadetcharlie Spacecadetcharlie is offline
Spacecadetcharlie is on a distinguished road
Agreed, I swapped my '07 Xreas (dead shocks/struts) for a simplified KYB setup (shocks in back, struts up front) based on diy instructions posted here. No codes, no problem.
I have no idea why Bilstein would deny a warranty, either. The setup is no different from any other 4Runner once the Xreas system is removed.
Spacecadetcharlie is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 02:25 PM #10
Thanks Bluesky! The one thing I did not see in your install posts was what you did or didn't do with the XREAS exposed fittings; did you plug them with something? Did you just leave them as disconnected? If you plugged the 4 fittings, what did you plug them with?
Old 11-09-2021, 03:14 PM #11
NCrunner2012 NCrunner2012 is offline
NCrunner2012 is on a distinguished road
Just remove the system completely. It's really easy to take out once you get under there.
1998 T4R Limited 4x4- Sold
2005 T4R Limited 4x4 V8
NCrunner2012 is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 03:58 PM #12
Bluesky 07's Avatar
Bluesky 07's Avatar
Glad that post was helpful. No need to plug the fittings b/c the ones at the designated disconnect points are different than those at the shock. If you disconnect at the shock, fluid under pressure may spray everywhere; the fitting farther up the line closes it off, allowing individual shocks to be replaced with new X-REAS components (theoretically at least).
I did eventually remove the rest of the tubing as @NCrunner2012 mentioned. There are a few bolts but mainly you're just pulling them out of the clips.
codes , error , shocks , warranty , xreas
Error Codes NTX4runner 4th Gen T4Rs 3 12-30-2018 02:37 PM
4R Error codes Aquabear 5th gen T4Rs 13 04-22-2018 02:59 PM
VSC / ABS new cobination of error codes 2fullgarage 4th Gen T4Rs 1 05-09-2015 05:55 PM
Multiple Error Codes spj512 Problems & Warranty Issues 0 09-21-2010 12:01 PM
error codes jamesek9 3rd gen T4Rs 5 02-22-2006 09:23 PM
