Old 11-10-2021, 04:20 PM #1
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
Rust Advice/Suggestions
since i was under the truck today replacing the fuel guage sensor, i decided to take pictures of the rust damage i have. Thoughts/suggestions of how to go about this would be greatly appreciated.
also the picture of the driveshaft, found a drop of might be tranny fluid as was red, coming from that spot, i dont have any drops on the driveway that i know of, so gonna keep an eye on it. any ideas suggestions?
Rust Advice/Suggestions-image0-2-jpg  Rust Advice/Suggestions-image1-2-jpg  Rust Advice/Suggestions-image2-2-jpg  Rust Advice/Suggestions-image3-2-jpg  Rust Advice/Suggestions-image4-2-jpg  Rust Advice/Suggestions-image5-2-jpg  Rust Advice/Suggestions-image6-2-jpg
daprotege5 is offline   Reply With QuoteReply With Quote
Old 11-10-2021, 05:01 PM #2
MikeinNH67's Avatar
MikeinNH67's Avatar
Pictures 1,2,3 & 6...ouch. That looks terminal to me as it would take lots of time and $$$$ to fix it properly. I've welded up multiple places on mine but did it as I found the holes when they were smallish so wasn't too bad. Pull off your rear bumper and I'll bet the frame corners are gone too. Also look at the front crossbar where the tow points are.
You can look into SafTCaps, maybe give you an extra year or two. If you can find a southern frame and have the time and knowledge to swap it that would be best.
4 Runner 2003-2009 4th Gen Archives - autorust.com
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 11-10-2021, 05:04 PM #3
Shiftless Joe's Avatar
Shiftless Joe Shiftless Joe is offline
Shiftless Joe is on a distinguished road
Personally, I would junk that thing if it was mine. It's beyond the norm for rust, and likely unsafe to drive,
Shiftless Joe is offline   Reply With QuoteReply With Quote
Old 11-10-2021, 07:02 PM #4
Syr4RinNC's Avatar
Syr4RinNC's Avatar
AGree with above. Im generally not an alarmist with rust and think most who dont deal with it worry way too much about it - but with significant rust holes like that its time to move on- i know in NY that would not pass inspection and most repair shops wont want to put that on a lift . Certainly other concerns about the structure of the vehicle in a crash etc
unfortunately, may be time to trade it in
Old 11-10-2021, 07:26 PM #5
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Speaking as one who has lived in the rust belt for his whole life, the fluid leak is the least of your problems. Sad to say, but that frame is beyond economical repair and is actually unsafe to drive.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 11-10-2021, 08:54 PM #6
Crazy it had a 21 pt inspection, 2 yrs ago at Toyota dealer, where they definitely would have seen that damage. As it had the transmission serviced and cooler lines repaired.
Old 11-11-2021, 10:51 AM #7
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Yea - I had a shop pass my state inspection, then 3 months later told me they wouldnt put it on a lift to do a repair because of the rust
Old 11-11-2021, 11:53 AM #8
Point number 22 must have been to "Check for massive amounts of clearly visible corrosion possibly leading to frame failure." Heck, anybody could have missed that. Not!
Old 11-11-2021, 05:10 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
I think they failed to do their own inspection properly. These often rust from the inside out so what you see is the tip of the iceberg.
Curious, are you in Florida? Just going by the Altamonte Springs in your info section. Maybe the former owner liked to drive it in the ocean?
Mike
03 4runner Limited
Old 11-11-2021, 05:14 PM #10
Yes in Florida but records from the car from New Jersey.
Old 11-13-2021, 04:03 PM #11
dskof dskof is offline
dskof is on a distinguished road
That looks pretty bad, I'd look into a replacement frame.
I had a few spots that a local place welded up for me. Wasn't cheap though.
Here is an option - SafeTCap(R) Kits - autorust.com if the rust is confined to only an area or two.
dskof is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 04:36 PM #12
Nitrosanity Nitrosanity is offline
Nitrosanity is on a distinguished road
New here, is there a sticky rust repair group? Just got my 4runner this past weekend and for sure need to clean and treat ASAP.
Nitrosanity is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 05:02 PM #13
Syr4RinNC's Avatar
Syr4RinNC's Avatar
no but theres plenty of threads on it. shoot some pics and people will help out. I assume if its a texas truck - it probably just surface rust and will mostly be cosmetic as opposed to an actual problem, but let us know.
general is wire wheel/ sand/ sand blast what you can, apply a rust converter, paint/ undercoat as deired and then use fluid film or rust prevention going forward
coming , fluid , red , rust , tranny
Help I need some rust advice cnpellegrino 3rd gen T4Rs 6 11-14-2018 01:59 PM
Advice on rust / 4th gen theory6 4th Gen T4Rs 5 07-17-2016 04:30 PM
Rust Advice PhdNPrerunners 3rd gen T4Rs 15 05-04-2015 09:15 PM
Rust rot on rear drum backing plate. Suggestions? hamiltonshmamilton 3rd gen T4Rs 2 09-14-2014 11:39 PM
BajaRack rust/scratch repair suggestions? Ryan_S 5th gen T4Rs 20 04-18-2012 03:03 PM
