Old 11-13-2021, 09:25 PM #1
Tuyrunner's Avatar
Tuyrunner Tuyrunner is offline
Tuyrunner is on a distinguished road
Tuyrunner's Avatar
Vibration is driving me crazy!
Hey folks. I am chasing down a vibration currently that happens between 60 and 70 mph. It’s somewhat feels like I am driving on a rumble strip just not quite as bad. It is not a shimmy like a tire out of balance. I have literally replaced all of my suspension components in the front including CV axles and have also done new u joints And made sure everything in the driveline is properly lubricated. I am starting to run out of options for things to check. Has anyone had this sort of issue before?
Tuyrunner is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 09:37 PM #2
COhailtr4 COhailtr4 is offline
COhailtr4 is on a distinguished road
I’m chasing down this exact situation. I can not figure it out and one shop hasn’t had any luck figuring it out so I’m at a loss.
COhailtr4 is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 10:07 PM #3
Tuyrunner's Avatar
Tuyrunner's Avatar
Dang. Haven’t had it at the shop yet but might have to have them look at it if I can’t figure anything out in the next little while.
Old 11-14-2021, 10:23 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Have either of you had the drive shaft inspected/looked at for being out of balance, most if not all driveshafts have a weight/bit of metal welded on it to balance it, similar to how a tire is balanced, if that weight has broken off it could result in the issue you describe.
2004 Limited V8
Old 11-14-2021, 01:20 PM #5
Tuyrunner's Avatar
Tuyrunner's Avatar
Mine still has the weight welded on and I just did new u joints yesterday. Might have to take it to a driveline shop and see if maybe it got bent or lost a weight somewhere else that I didn’t notice.
Old 11-14-2021, 02:22 PM #6
Wardbird's Avatar
Wardbird Wardbird is offline
Wardbird will become famous soon enough
Wardbird's Avatar
My F150 did something similar. In that case it was two things; corroded lines for the trans cooling lines leaking fluid and there was an ignition coil going bad that showed itself until certain loads but never threw a code.
Wardbird is offline   Reply With QuoteReply With Quote
Old 11-14-2021, 05:59 PM #7
Tuyrunner's Avatar
Tuyrunner's Avatar
Hmm those are two things I hadn’t thought of. Might have to check that out. Did it do it under the same load at different speeds or just at a certain speed?
Old 11-14-2021, 06:50 PM #8
Wardbird's Avatar
Wardbird's Avatar
It generally happened between 45-65 mph or that was at least when it was most pronounced. A vibration or a stutter. These things can be difficult to pin down because sometimes they only happen under certain loads or within certain harmonic ranges. LOL. It's like tuning a guitar or bringing a multi-engine airplane to all be in sync with one another. You just know when it isn't there.
Old 11-14-2021, 07:56 PM #9
Tuyrunner's Avatar
Tuyrunner's Avatar
That’s exactly what’s driving me crazy! I can’t pinpoint it yet but I know something’s wrong! Thanks for your help!
Old 11-14-2021, 08:46 PM #10
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Don't know what to tell you, wheel bearing? Whatever you find please let us know.
Old 11-14-2021, 11:26 PM #11
vicho09 vicho09 is offline
vicho09 is on a distinguished road
Its the brake rotors! i have heard this multiple times. Take it to a honest brake shop and check if they are warped. That should do it.
vicho09 is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 07:28 AM #12
Tuyrunner's Avatar
Tuyrunner's Avatar
I guess that could be! Might just swap out the rotors for new ones and see if that fixes it.
Old 11-15-2021, 09:18 AM #13
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Rotors warped enough to cause a vibration when not braking should give a severe shake under braking shouldn't they?
Old 11-15-2021, 01:53 PM #14
haro's Avatar
haro haro is offline
haro is on a distinguished road
haro's Avatar
I'm having the same problem. took it the a hunter road force balance, than I was told that my tires were old, I replace them, the problem still there. the mechanic looked under checked the drive shaft and didnt find anything.
The funny thing is today I drove 1:20 hr I hit 53mph for about 3 min and about 10 min later I was doing 60 min for about 4 min. and the entire trip no vibration
2003 4RUNNER LTD V6 4X4
SILVER
haro is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 01:57 PM #15
SurferUK's Avatar
SurferUK SurferUK is online now
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
My experience today says check you don't have a sticking caliper!
At 30mph roll-off it felt like something was off with the transmission (Shudder) or driveshaft
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is online now   Reply With QuoteReply With Quote
axles , driving , iphone , joints , vibration
Help me fix this vibration. Driving me crazy tom5191 4th Gen T4Rs 1 11-10-2015 10:54 AM
Vibration is driving me crazy! T4Rscott 3rd gen T4Rs 12 01-28-2013 02:57 AM
This is driving me crazy #2... Mr. Sonora 5th gen T4Rs 2 04-05-2011 08:09 PM
Vibration noise (Driving me crazy) John Majorossy Problems & Warranty Issues 3 07-15-2003 11:58 PM
