Old 11-29-2021, 12:09 PM #16
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Guys, would appreciate a little advice.
I decided to replace the flexi-hoses while I was at it.
The nut that joins the metal brake pipe to the flexi-hose is very, very tight. I am using a flared 10mm spanner, and have applied as much force as I dare to it.
I have applied heat to it and squirted with PB Blaster to see if that will help. It is getting dark here now so I have left it for today. Hopefully that will soak in overnight.
They're not reverse threaded or something are they?
If I cannot get it un-done, what is the next step? Replace the metal brake pipe?
Thanks!
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 01:45 PM #17
SurferUK's Avatar
SurferUK's Avatar
Just an update, anyone who has struggled to undo the flare line nuts, get yourself one of these. Best £20 I ever spent on tools. It allows you to get a fine jet of flame right where you need it, on the nut/thread. Three goes with this and some PB Blaster, then kept a sustained force on the spanner for 10 seconds or so, and it undid with a CRACK
caliper , calipers , common , rear , toyota
Sticking Caliper Piston, Sticking Rear Shoes, or ABS? nc-grayson 3rd gen T4Rs 1 07-05-2017 08:19 PM
Sticking caliper? Bigmd 3rd gen T4Rs 14 10-23-2016 04:05 PM
Sticking rear caliper? ASUMTNEER 4th Gen T4Rs 3 01-06-2014 12:00 PM
brake caliper sticking? 2002t4rlewis Maintenance/Detailing 8 06-28-2007 08:07 PM
Front Brake caliper sticking? r1burden Classic T4Rs 5 06-05-2005 05:15 PM
