Old 12-19-2021, 01:26 PM #16
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
Rear link skids
Made these lower link skids with inspiration from mikestang.com. I cut them from 3-1/2” .25 wall square tube. I left short tails on them to extend under the mount a bit.
Hi-desert Cheapskate build thread-12e30ff5-64e7-45e6-8faf-f0e673c210f4-jpg  Hi-desert Cheapskate build thread-4a58b90c-cead-4f9d-ab56-26cd52dd2811-jpeg
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 12-20-2021, 09:57 PM #17
Real Name: Matt
Real Name: Matt
Rear sway bar end links
I played around with the rear sway bar end links. First I used 1/2Ē round tube to extend them. Ran it this way for a number of years. Second I pieced together a pair out of heims, threaded rod, misc hardware and energy suspension end link bushings.
Hi-desert Cheapskate build thread-5297da89-528b-4474-b92b-64b6b6196082-jpg  Hi-desert Cheapskate build thread-701af0ca-dd3b-40e0-b76e-7f14d4c63a31-jpeg
Old 12-20-2021, 10:32 PM #18
Real Name: Matt
Real Name: Matt
Push bar
Got a set of Smittybilt bumpers for a Wrangler for free. Sold the rear for fifty bucks, installed the front one on the 4Runner. I removed the lower grille opening and cut the lower center section of the bumper out. Mounted it directly to the crash bar using 1/2” grade 8 bolts.
Now removed
Made an aluminum filler plate to help protect the radiator out of 3/16” aluminum sheet I got for free.
Hi-desert Cheapskate build thread-0f8674db-b943-46b3-a3c8-a15e6737acfd-jpeg  Hi-desert Cheapskate build thread-13beb341-16f3-430b-8e6d-85656ffb5ec3-jpg
Old 12-20-2021, 11:03 PM #19
Real Name: Matt
Real Name: Matt
Whiteline lower control arm bushings
I replaced my lower control arm bushings in 2020 with Whiteline W53312 bushings following this tutorial by @y=mx+b .
Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures)
Old 12-20-2021, 11:09 PM #20
Real Name: Matt
Real Name: Matt
Upper control arms
I went with JBA upper control arms. I like the HD Chevy/GM style ball joint. These corrected the alignment issue Iíd had since it was lifted. It drove straight but the steering wheel was crooked. Now perfect.
Hi-desert Cheapskate build thread-598494a3-ca55-4ce1-8cf8-e2b5c12ddd56-jpeg
Old 12-20-2021, 11:16 PM #21
Real Name: Matt
Real Name: Matt
Splash guards
Made new splash guards out of rubber carpet runner from the Home Depot.
Mine had dry rotted and fallen off long ago.
Hi-desert Cheapskate build thread-e634d603-1dbf-4958-b0e1-358d09ed39f1-jpg
Old 12-21-2021, 10:31 PM #22
Real Name: Matt
Real Name: Matt
Tire carrier
I set out to build a tire carrier that I could still tow with. Iím not worried about access into the rear hatch. The motor doesnít work and isnít a high priority.
I had most of this laying around. I used 2Ē square tube, a 2-1/2Ē hitch extension, 3/16 flat stock and a repurposed spare tire mount off my old trailer. I bought M12 1.5 lug nuts and bolts from Oíreillys along with an LED lit license plate bracket.
Hi-desert Cheapskate build thread-569e0553-40db-49e5-b587-fa0293ce807e-jpg  Hi-desert Cheapskate build thread-e131a205-6ae9-4a1d-8b4a-7ff37d6ae0bd-jpg
Old 12-21-2021, 11:02 PM #23
Real Name: Matt
Real Name: Matt
Spare tire carrier
Later on I added brackets to mount my Hi-lift. I had another Hi-lift stolen off my 4Runner when I lived in Las Vegas. Iím rural now but donít trust humans that much. Made two mounting points with locks. Cross drilling 1/2Ē bolts to fit small padlocks works well. I also used small pieces of leftover UHMW body lift materials to isolate the jack and keep it from rattling.
Hi-desert Cheapskate build thread-04d2fbd2-e988-496e-98bf-d674c333f335-jpg  Hi-desert Cheapskate build thread-308ef684-6101-4cc7-801b-424dc1540206-jpg  Hi-desert Cheapskate build thread-778edbf9-ad34-4b34-9015-d7e8ff672e2c-jpg
Old 12-22-2021, 06:14 PM #24
Real Name: Matt
Real Name: Matt
Head unit
Replaced the factory head unit with a Pioneer FH-S700BS. Itís a pretty basic unit that has bluetooth and a usb on the front. At the same time I installed Crux SWRTY-61S to retain steering wheel controls. This thing sucks and rarely works. Kind of a waste.
Now time to add a sub and replace door speakers.
Hi-desert Cheapskate build thread-df2e2078-5c14-4063-b968-3cff443cd043-jpg
Old 12-22-2021, 06:22 PM #25
Real Name: Matt
Real Name: Matt
Rear diff breather
So there aren’t really any water crossings near me in the desert so I’m not sure why I did this mod but I did anyways. I guess the chance of water crossing after a monsoon or flash flood is there.
I purchased the Toyota union part #90404-51319 off of Amazon, a Dorman diff vent part #924-284, about 5’ of 5/16” fuel line, hose clamps and a few zip ties for this mod. I found out later there’s a kit for this. I zip tied the diff vent to the fuel filler neck in a few places. I didn’t extend it thru the rubber flap inside the gas filler door.
Old 12-22-2021, 10:01 PM #26
Real Name: Matt
Real Name: Matt
Dobinsons adjustable trailing arms
Replaced my lower trailing arms with adjustable from Dobinsons.
Hi-desert Cheapskate build thread-dbe30641-f362-40f1-9e7e-5a7b829d1710-jpg
Old 12-22-2021, 10:03 PM #27
Real Name: Matt
Real Name: Matt
Dirty
Youíll start to notice that my stuff is only clean when itís new. I almost never wash my truck. It also has a lot of desert pin striping.
Hi-desert Cheapskate build thread-30c0181a-606a-4d8f-a8c8-79e49c65e5bf-jpg
Old 12-22-2021, 11:30 PM #28
Real Name: Matt
Real Name: Matt
Originally Posted by TLar25 View Post
Got any current pictures of it?
Sent from my Pixel 3 XL using Tapatalk
Yes. Added some.
Old 12-23-2021, 07:45 PM #29
Real Name: Matt
Real Name: Matt
Lighting
The lighting has gone through a few changes.
Currently I have Auxbeam FT-1 H11 low beams, Auxbeam FT-1 9005 high beams and Sealight 3000k 9006 fog lights.
I’m researching new H11 low beams as I found out that these H11 LEDs are not legal according to NHTSA. Fog lights are going away once my bumper kit arrives.
I mounted a 32” curved light bar to the top of the crash bar in the lower grille opening.
I bought the 40” light bar new in box from my buddy for forty bucks. I made brackets to mount it to the roof rack.
I bought these cheap GS Power ditch light brackets for a Tacoma off of Amazon along with some cheap Nilight light pods. The fit is decent.
Amazon.com: GS Power Engine Hood Hinge Ditch LED Mount Brackets for Auxiliary Offroad Pod Work Light. Fit Cowl Panel at Windshield Base Compatible with 2005-2015 Toyota Tacoma : Everything Else
Hi-desert Cheapskate build thread-b713fe5a-3f4a-4604-835f-92b6b15d2d66-jpg  Hi-desert Cheapskate build thread-ce7b7f4e-d927-436e-b678-67f96a217f9f-jpg
Old 12-25-2021, 11:18 PM #30
Real Name: Matt
Real Name: Matt
Shifter
Made this 8 ball shift knob several years ago. Drilled the center and found out it has a metal core. Tapped it match the thread pitch. Had a chrome faucet part that covered the narrowed section of the shift lever.
Hi-desert Cheapskate build thread-5d501bd2-4a3d-4dbe-8c62-74424779b97b-jpg
build , members , progression , thread , time
My Desert Dune Demise (DDD) (re)Build Thread 3.5inmag 3rd gen T4Rs 1 09-02-2019 11:46 PM
05 V8 Desert Runner build Sam2393 4th Gen T4Rs 54 07-14-2019 09:15 PM
$10K Desert Rip-Off Build mf2kta 5th gen T4Rs 16 04-18-2018 03:45 PM
Build Thread: 2000 3rd Gen SR5 Mountain/Desert Rambler hodolla 3rd gen T4Rs 33 03-26-2018 12:18 PM
Build Thread "Desert Shadow" engaged!!! blazingshadow 3rd gen T4Rs 20 03-05-2016 03:46 AM
