Old 12-19-2022, 10:23 PM #106
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by Hi-desertT4R View Post
Something I’ve been working on for quite some time here and there is repurposing an old metal work table into skid plates. This rusty chunk of 1/4” plate was free. I’ve been loosely following the diy by @y=mx+b . I faced a number of challenges, first not having a 3 prong 240v outlet then my air compressor not being able to keep up with the Cornwall tools plasma torch my buddy let me borrow, then the torch barely being able to cut 1/4”. I had the basic parts and pieces made for a while. I used some 3/16 u channel for the core support. I used 2x2 1/4 wall square tube and 3/16” flat plate for the two front stand offs and made some small spacers for the rear engine crossmember from UHMW. The transmission crossmember stand off is 1x2 rec tubing which was part of the frame of the table I cut up for this. The rest of the 1x2 will be the t-case crossmember. I still need some bracing and side fillers but otherwise I love how this is turning out.
Looks great dude!
y=mx+b is offline   Reply With QuoteReply With Quote
Old 12-26-2022, 09:39 PM #107
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
Wife got me a Viair 300p compressor for Christmas. Went out and made good use of it on some trails over the long holiday weekend.
Hi-desert Cheapskate build thread-705a4212-1a5d-4ab6-b678-c0e7d55e5f73-jpg
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 01-18-2023, 10:42 PM #108
Real Name: Matt
Real Name: Matt
The wife surprised me with an ARB Speedy Seal 2 tire plug kit. A couple Glue Treads and a Colby Valves and I think I might ditch the spare.
Amazon.com: ARB 10000011 Speedy Seal 2 - Universal Heavy Duty Tire Repair Kit For Car, Truck, RV, Jeep, ATV, Motorcycle, Tractor, Trailer. Flat Tire Puncture Repair Kit Fix Punctures and Plug Flats 50 String Plug : Automotive
Amazon.com: GlueTread All-in-One Deluxe Kit Sidewall Tire Repair Kit Puncture Repair Anywhere No Need to Remove Tire for Off Road Vehicles : Automotive
Amazon.com: Colby Valve Permanent Valve Stem Replacement - installs from Outside of The Wheel : Automotive
Old 01-18-2023, 10:48 PM #109
Real Name: Matt
Real Name: Matt
Got my Sealight RGB rock lights installed after fabricating some brackets.
Hi-desert Cheapskate build thread-7a771354-8f3f-4b6d-98d8-396c71320b59-jpg
Old 01-25-2023, 03:36 PM #110
Real Name: Matt
Real Name: Matt
Purchased a Smittybilt XRC Gen2 9500 winch and True North Fab recovery points with frame tie-ins. For ease of installation and time I mounted the control box on the side. It contacts the hood release in the center so that won’t fly. On the side it allows the best access to the control lead. I plan on making a custom aluminum mount for it once I have a little more free time. And I know, my wiring looks like ass.
Hi-desert Cheapskate build thread-a62b8dd7-f60b-4061-8e16-06d967b6ba77-jpg  Hi-desert Cheapskate build thread-268b4c8b-9660-4b45-b88e-77dd584cbeb6-jpg  Hi-desert Cheapskate build thread-b09293a3-c4f0-4279-8aa2-2e3156460d2a-jpg
Old 02-12-2023, 11:55 AM #111
Real Name: Matt
Real Name: Matt
Scored a set of used Bilstein 6112’s and 5160’s for a 5th gen for a great price. Swapped out the current front set ups for the 6112’s. The lower eyelet on the 5th gen shock is about 3/16” wider than a 4th gen. Two minutes with a flap wheel on my grinder and good to go. Installed YotaMafia extended ss brake lines up front too. Did a full brake system flush with synthetic dot 3. I still need new reservoir clamps for the 5160’s before I can use them. I’ll probably just keep them as backups when I have to rebuild the Icon 2.0s.
Hi-desert Cheapskate build thread-4f6b0c56-fd00-4838-a5d6-67c9eda561d8-jpg  Hi-desert Cheapskate build thread-5b4a89d5-b7ae-4c5a-a68e-e5c054b8b826-jpg
Old 02-13-2023, 10:51 PM #112
Real Name: Matt
Real Name: Matt
Just ordered some Icon 2” rear coils. PN 52700.
Old 02-18-2023, 10:35 AM #113
Real Name: Matt
Real Name: Matt
Swapped out the 3” Toytec springs for 2” Icon springs.
Hi-desert Cheapskate build thread-e449a38a-72b5-4afb-b799-65ee095dfe9a-jpg
Old 02-19-2023, 09:08 PM #114
Real Name: Matt
Real Name: Matt
Got the Icon springs installed. Went out for a test and man what a huge difference. 3” 400+ Lb spring definitely don’t flex like these. My suspension as a whole is night and day difference over the Toytec 3” springs on 5100’s with their top spacer and 3” hd rear springs. The heavy springs were awesome when hauling firewood or my side by side but suck for wheeling. I actually bottom out on the rear bumps now. Time for Durobumps in the rear.
Hi-desert Cheapskate build thread-2e051d52-f1b5-4280-a5f6-f1d96e419a7b-jpg  Hi-desert Cheapskate build thread-910c1ec9-e4f0-4984-8101-6ba32e9aad38-jpg
Old 02-28-2023, 11:03 PM #115
Real Name: Matt
Real Name: Matt
The splash guards I made started to fall apart. Made some new one-piece ones out of some 60 mil hdpe sheet I have.
Hi-desert Cheapskate build thread-60547a03-ac30-453f-847a-673129fbdbdf-jpg  Hi-desert Cheapskate build thread-81391fb6-e83f-413a-8f31-064b4a252f3c-jpg
Old 03-04-2023, 10:47 AM #116
Real Name: Matt
Real Name: Matt
Rear upper control arm bushings were wasted. Swapped out with Moog factory style replacements for now.
Hi-desert Cheapskate build thread-54fa40da-c3d2-4573-b150-4556663ced61-jpg  Hi-desert Cheapskate build thread-1165fd8f-ccf2-4710-8354-fe00a3fd42ce-jpg
Old 03-04-2023, 09:36 PM #117
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
Was it easy to relocate that control box?
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 03-05-2023, 11:46 AM #118
Real Name: Matt
Real Name: Matt
I haven’t relocated the box yet. I just mounted it off to the passenger side using the supplied brackets.
Old 03-05-2023, 01:30 PM #119
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You can remove your old control arm bushings at your leisure now and install some Super Pro or comparable bushings. I went Super Pro.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 03-05-2023, 01:52 PM #120
Real Name: Matt
Real Name: Matt
Along with beefing up the bar between the eyelets that’s my plan exactly.
build , members , progression , thread , time
My Desert Dune Demise (DDD) (re)Build Thread 3.5inmag 3rd gen T4Rs 1 09-02-2019 11:46 PM
05 V8 Desert Runner build Sam2393 4th Gen T4Rs 54 07-14-2019 09:15 PM
$10K Desert Rip-Off Build mf2kta 5th gen T4Rs 16 04-18-2018 03:45 PM
Build Thread: 2000 3rd Gen SR5 Mountain/Desert Rambler hodolla 3rd gen T4Rs 33 03-26-2018 12:18 PM
Build Thread "Desert Shadow" engaged!!! blazingshadow 3rd gen T4Rs 20 03-05-2016 03:46 AM
