Old 03-10-2022, 11:18 PM #61
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
Chevy blazer washer nozzle mod
Factory washer fluid nozzles were piss poor. Read about swapping them for Chevy Trailblazer nozzles. Quick easy and cheap upgrade. Fan type spray vs streams.
Amazon.com: Direct Replacemnt Adjustable Windshield Washer Nozzle Mist Spray Type for 2002-2004 Oldsmobile Bravada, 2002-2009 GMC Envoy, 2002-2009 Chevrolet Trailblazer, Replace OE for 15878745 : Automotive
Found mod in this thread post #7 Windshield Washer nozzle mod?
Also a really good write-up by @ Bluesky07 post #39 in his build thread here Tales of the Silver Beast: Bluesky 07's Long Overdue Build Thread
Hi-desert Cheapskate build thread-9640bf1e-74e5-4a76-bcad-c6d726733201-jpg
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 03-11-2022, 10:59 PM #62
Real Name: Matt
Real Name: Matt
I didn’t like how exposed the core support was. I modified the filler plate I had made previously. It’ll do for now but I need to replace the skids. It stood out too much as bare aluminum. I rattle canned it flat black.
Hi-desert Cheapskate build thread-f25bbf4a-1dde-4a5c-a42d-e362c25b3c33-jpg  Hi-desert Cheapskate build thread-7cb6540b-b803-4c9c-b4fa-cf2936f14445-jpg
Old 03-21-2022, 07:45 AM #63
Real Name: Matt
Real Name: Matt
Plasti-derped the grille. The chrome center bar is broken in one spot and it’s days are numbered until I go full Satoshi.
Felt like the bumper mounted light bar looked out of place. Removed it and plan on installing pods in the tube wings of the bumper.
Hi-desert Cheapskate build thread-304c2db1-8011-4c06-80a8-ac841c43c71a-jpg  Hi-desert Cheapskate build thread-d9fb9704-0fcb-44ff-83d3-a5a1cd2fe465-jpg
Old 04-05-2022, 08:47 AM #64
Real Name: Matt
Real Name: Matt
Added some cheapie Nilight led pods to the bumper.
Hi-desert Cheapskate build thread-4516c046-6683-483b-8665-df34c0afa4b5-jpg
Old 04-10-2022, 11:39 PM #65
Emgbc Emgbc is offline
Emgbc is on a distinguished road
Do you have any pictures of how you ran your ditch light wiring from the pods? I just installed mine and trying to figure out the best way to run the wires from the pods to the relay near the fuse box. I started by running them behind the little rubber corner between the fender/a pillar. Trying to figure out how to get it across the plastic down to the firewall without interfering with the hood hinge. Thanks for any insight you can provide.
Emgbc is offline   Reply With QuoteReply With Quote
Old 04-12-2022, 09:03 PM #66
Real Name: Matt
Real Name: Matt
Sorry I’m a shitty picture taker haha.
I pulled the corner filler pieces out and haven’t bothered to put them back in. I thought about drilling some holes in the fillers and stabbing the wires through those. Maybe some day. I just ran the wire under the edges of the plastic cowl piece and split the power wire and ran in across through the cowl in wire loom.
Hi-desert Cheapskate build thread-099ba7ae-7820-41ef-bc49-96f34d262b6c-jpg  Hi-desert Cheapskate build thread-b7749f0c-ff5c-4183-bc5e-a49df385b6b6-jpg  Hi-desert Cheapskate build thread-15627fa0-6353-4a51-a4d0-a949feb1a0d3-jpg
Old 04-12-2022, 11:06 PM #67
Thanks for sharing this - appreciate the help.
Old 04-13-2022, 03:42 AM #68
thewellcon4 thewellcon4 is offline
thewellcon4 is on a distinguished road
top seo companies
top seo companiesI’ve been searching for some decent stuff on the subject and haven't had any luck up until this point, You just got a new biggest fan!..
thewellcon4 is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 08:43 AM #69
Real Name: Matt
Real Name: Matt
Um, ok yeah man. Thumbs up
Old 05-30-2022, 10:20 PM #70
Real Name: Matt
Real Name: Matt
Repairs and maintenance at 139200
Over a couple days I completed some much needed repairs and maintenance.
Mileage was at 139200.
I completely flushed the power steering with Valvoline Maxlife ATF. I greased both driveshafts and UCA’s. Checked fluid levels in the T-case and rear diff. Removed the roller bearing in the diff. Felt like it had a lot of play but wasn’t broken. Installed an ECGS solid bushing. A torn CV boot turned into a CV replacement. One of the bearings fell off the tripod upon removal. Stretched the inner boot.
Lowered the Bilstein 5100’s from 1.75” down to .85”. Wish I would have done this months ago.
After all that I found both 4hi green light and Diff lock yellow light flashing and wouldn’t engage the front diff. Pulled the A.D.D, soldered the motor and micro switch connections.
Write-up No 4WD 4hi and center lock flashing
Hi-desert Cheapskate build thread-93771f0f-f032-4775-8752-14dfc2224da1-jpg  Hi-desert Cheapskate build thread-42044ef8-4d2d-46a1-93a3-09dcef586fa4-jpg  Hi-desert Cheapskate build thread-27491e1f-3e59-4cab-a80f-136cb7abfffc-jpg  Hi-desert Cheapskate build thread-c4cb3dc1-d35f-478d-8fec-9b8d62a6c076-jpg
Old 07-05-2022, 09:21 PM #71
Real Name: Matt
Real Name: Matt
Installed this ScanGauge II. I need to find a better mount for it than Velcro strips.
Hi-desert Cheapskate build thread-474b1af7-e5d3-4a06-8b81-e1a447a95bd1-jpg
Old 07-07-2022, 11:01 PM #72
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
great spot for it, I would recommend double sided tape or magnets. 3M
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 07-08-2022, 07:21 AM #73
Real Name: Matt
Real Name: Matt
Yes, it sits perfect right there and doesn’t block any gauges. I like the idea of magnets because I want to easily be able to swap it over to my Scion. Thanks for the suggestion!
Old 07-08-2022, 08:56 AM #74
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Great looking build!
It's amazing Toyota is still using and having problems with that bearing 20 years later. Never understood why they didn't go to the bushing since it's been a proven fix. If you take into account just the Tacomas that have done this mod, ECGS has probably made a couple bucks with the sales of those bushings and SST over the years.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 07-08-2022, 08:43 PM #75
Real Name: Matt
Real Name: Matt
Thank you sir! Truthfully I didn’t even know it could be an issue until within the last year haha. My bearing was in ok condition but I have peace of mind with the solid bushing in there. I do plan on keeping this rig for life. I wonder if ECGS has made more off of the bushing or the puller?
build , members , progression , thread , time
My Desert Dune Demise (DDD) (re)Build Thread 3.5inmag 3rd gen T4Rs 1 09-02-2019 11:46 PM
05 V8 Desert Runner build Sam2393 4th Gen T4Rs 54 07-14-2019 09:15 PM
$10K Desert Rip-Off Build mf2kta 5th gen T4Rs 16 04-18-2018 03:45 PM
Build Thread: 2000 3rd Gen SR5 Mountain/Desert Rambler hodolla 3rd gen T4Rs 33 03-26-2018 12:18 PM
Build Thread "Desert Shadow" engaged!!! blazingshadow 3rd gen T4Rs 20 03-05-2016 03:46 AM
