Old 11-30-2021, 02:15 PM #1
jscott6's Avatar
jscott6 jscott6 is offline
Real Name: Scott
jscott6 is on a distinguished road
jscott6's Avatar
Real Name: Scott
Rear sway bar end link question
I have a small 1 inch lift in the rear, installing adjustable rear end sway bar links for a higher lift in the future. Should I keep the adjustable ones stock length with the current 1 inch lift or make them longer?
I do not want to remove the rear sway bar...yet.
jscott6 is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 04:06 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
You want the arms of the sway bar to be as horizontal as possible. So if you're lifting 1", then increase the link length appropriately.
Your sway bar is a torsional spring between the left and right sides. The arms of the sway bar allow the roll of the body to engage the torsional spring, and the links are what connect the sway bar arms to the frame/body.
If the sway bar arms are angled, the effective length of the sway bar arm (horizontal distance from end of arm to the bar itself) is reduced. This makes it so the body has less leverage to twist the sway bar, and will potentially result in harsher ride. Can also make it harder for the rear end to flex
y=mx+b is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 06:24 PM #3
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
If you don't want to pay for adjustable ones, the other option are either 3rd gen links of Nissan Pathfinder links. Both fit, and are longer.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
bar , end , lift , rear , sway
Sway bar end link question DCameraMan 4th Gen T4Rs 7 07-12-2020 03:45 PM
Front sway bar end link question lcbjr77 4th Gen T4Rs 1 12-20-2015 10:06 PM
Sway bar link question runner823 3rd gen T4Rs 3 07-12-2014 06:16 PM
Sway Bar Link Question chadsy 3rd gen T4Rs 14 04-07-2013 11:38 PM
Rear Suspension Question...REAR SWAY BAR LINK? sjr13 Maintenance/Detailing 1 02-25-2009 09:55 AM
