Old 11-29-2021, 08:28 PM #1
S p a r k y's Avatar
S p a r k y S p a r k y is offline
Real Name: Mark
S p a r k y will become famous soon enough
Real Name: Mark
Shimmy and a shake. Help please.
Help with the diagnosis please!
Two weeks ago while driving down the interstate, the 4runner started vibrating under a load, "gas pressed" when in neutral or coasting there is no vibrating.
After some looking into, I have replaced all 4 U-joints. Being that I am v8 and 4wd all time, I thought this might do it. Unfortunately I am still vibrating under a load.
1. Possibly tires, the Ridge Graps have been on for 70k. They need some replacing. But since it only shakes under load and not all the time I am ruling this out for now. I have a set of at3w's in the garage. Just haven't put them on.
1. Caliper seized, None of them are hot after driving, and that wouldn't be under load.
1. Diff's and transfer case oil, all full and good.
1. Slip yokes and u joints. All new grease is each
1. My next thought is possibly an axle?? They are Advance auto axles, been in there for years.
Anyone have any other suggestions?? Thanks for the consideration!
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
S p a r k y is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 10:06 PM #2
Real Name: Mark
Real Name: Mark
Update: grabbed my driver axle again while on ground. I can physically move it slightly and it make a noise. So, something is up with that. New CV tomorrow!
'04 Sport V8
Old 11-30-2021, 02:14 PM #3
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
if the axle ends up not being the issue it wouldn't hurt to go over and check your tie rods and alignment. That was the source of my shudder/shake under acceleration: bad alignment with the toe being way out and worn out tie rods allowing lateral movement.
aemravan is offline   Reply With QuoteReply With Quote
load , possibly , thought , time , vibrating
Steering shimmy and shake arehman11 5th gen T4Rs 8 06-13-2018 11:50 AM
Vsc, shimmy shimmy shake rattle & buzz lcbjr77 4th Gen T4Rs 3 01-14-2016 05:47 PM
The dreaded highway shimmy/shake/vibration = fixed Golfinz 3rd gen T4Rs 18 03-04-2014 10:23 PM
'06 V8 4Runner Shimmy & Shake shoot4boge 4th Gen T4Rs 1 09-24-2010 08:06 AM
'95 2WD: brake shimmy betelnut Classic T4Rs 6 01-01-2010 12:31 AM
