Old 12-02-2021, 01:17 AM #1
GBagwell's Avatar
GBagwell GBagwell is offline
GBagwell will become famous soon enough GBagwell will become famous soon enough
GBagwell's Avatar
First attempt at On Board Air
I normally post on “what did you do with your Runner today” but this effort took a couple days.
I decided I was tired of digging out my pump from its bag and getting setup to air up. I researched a number of pumps but when I was able to pick a Harbor Freight pump for $50, I decided it would do for now, but I would make a mount that would handle an upgraded pump. And I wanted to know I could create what I wanted before making any big investments.
I’ll let the pictures tell the story. But because there may be questions. I did remove the handle and handle brackets as they weren’t not going to serve any purpose. And I also pulled off the restrictive and proprietary hose connection and added a more common fitting.
My bracket was created with some steel I had laying around and has 3 solid mounting points and is well insulated. I think it is sufficient and I could easily add a 4th mounting bolt.
I’ve created a 2 tire inflating deflating & balancing system with pressure gauge that I can connect to the on board air.
First attempt at On Board Air-7ecd2c63-ab56-422d-a3ec-ba3359b28f8d-jpg  First attempt at On Board Air-3463001b-39dc-49e1-99bc-75b27076626d-jpg  First attempt at On Board Air-1618102d-8ecc-4854-bcc8-252c3f1a6f22-jpg  First attempt at On Board Air-aa2ff0af-b859-4827-bad1-7b0311bed6a8-jpg  First attempt at On Board Air-6ac2e159-53bf-4991-8270-6ad6c14b0293-jpg  First attempt at On Board Air-6e80e9bf-e66e-488a-8a67-307ba85ce9d2-jpg
86 4Runner, 91 4Runner, 97 4Runner Limited, 2003 4Runner V8 4x4 Limited (current ride - Original Owner)
GBagwell is offline   Reply With QuoteReply With Quote
Old 12-02-2021, 10:48 AM #2
Humble Leader's Avatar
that looks really clean. nice bracket. are you going to run the alligator clips to the battery and manually hook them up each time? I have a 5th gen and was thinking about the exact same type of setup, keeping the alligator clips in case I wanted to take the compressor out.
only problem I have is I have a wire harness that runs right across the the mounting surface that I don't think has enough play to move to the fender side. I think that is unique to the 2010-2013 4runners as I've seen people have that wire harness mounted on the fender side from factory. what did you use to paint the bracket?
Old 12-02-2021, 11:46 AM #3
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Tidy job! Are you going to use it for air lockers?
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 12-02-2021, 09:59 PM #4
GBagwell's Avatar
GBagwell's Avatar
Hey Humble Leader, For power I currently have a lead to the battery for connecting a trickle charger. I also have a set of tiny LED lights I wired up on a string and have tiny super magnets attached to. They function as under hood trouble lights and I can also attach via the magnets to provide light for camping or maintenance in the dark. They as well connect to the charger lead. What I like about the lights is they provide good illumination from multiple angles preventing shadows.
So I wired the same connection to the air compressor and thats how I make the power connection prior to operating the pump. See photo.
I used rust-oleum “hammered” paint, it provides good coverage and hides imperfections while providing an interesting appearance.
And FYI, I have no airlocker.
Thanks.
First attempt at On Board Air-dbe7558a-84ec-4b8b-acce-3cc6e446437f-jpg  First attempt at On Board Air-da4d2c17-d87f-41db-a83e-2b75e47657a5-jpg
Old 12-03-2021, 09:59 AM #5
Thanks.
thank you that is a nice setup
air , created , handle , mounting , pump
AEM FIC-6: Professional Tuner's First Attempt T4RunnerSteve 3rd gen T4Rs 9 12-11-2018 02:02 PM
Possible Break-in attempt? EEEliminator 5th gen T4Rs 16 12-02-2015 01:07 PM
First attempt patching rust Moustache Classic T4Rs 6 01-05-2011 02:39 PM
Lift Install Help Attempt #2 pbcolt 3rd gen T4Rs 19 11-21-2010 01:04 AM
How much should I attempt on my own? billstark Problems & Warranty Issues 3 01-12-2008 08:07 PM
